Question about ViewSonic VX922 19" Monitor Flat Panel
Viewsonic problem Viewsonic VX922 its about about 1.5 years. Recently started blinking upon boot up. when I boot up the orange light turns green and blinks continuously while featuring a blank screen. the computer boots okay;, but nothing shows on screen. i unplug monitor for 5-10 secs and everything is ok... could it be backlight inverter or capacitors or inverter board... Any help would be greatly appreciate as calling Viewsonic is a dead end..thanks
  • 6 more comments
  • ZCarlos Jul 11, 2008
    Same exact problem 2 years
    old and just a green LED blinking on boot up, works every 3-5 times.
    Solder iron is hot,
    Carl
  • Anonymous Jul 14, 2008
    occasionally comes on but for the most part it just blinks green and then fades to yellow.
  • Anonymous Aug 19, 2008
    Mine passed 2 year in july..I found another forum and there was mention
    it happens when they changed resolution.I tried and black screen
    appeared again..It seems to be soemthing wit this monitor went wrong :)
    Im going to return this monitor .
  • ChiII Sep 14, 2008
    Oh yes... I have the same problem. Had the VX922 for two years now and a few weeks ago, the power button started blinking and XP logon screen is black. I have to turn the power off then on to display the logon screen. I checked all hardware, including video card, and software but I did not solve the problem. Still searching searching for a solution. Viewsonic's website does not offer much help in this area. All PC systems that I have owned carry are viewsonic CRTs and/or LCD monitors. I had planned on purchasing a new one this month but I think I'll look elsewhere. If this is a hardware problem, I'm passed my warranty. By the way, where do you find the scaling?
    I found the "display scaling" on the NVIDIA control panel. Changed it to NVIDIA scaling. Don't know if it works yet but usually during reboot the power button does not blink. It's during a cold boot that I get the problem. In both the reboot and the cold boot, I've noticed the screen goes dark and fades in and out for sometime before reaching the xp logon screen. This has been going on since the blinking of the power button. The changes I did with the scaling did not change this "routine". The icons took forever to load and the desktop photo I had dissapeared. At the next cold boot, I'll test if the scaling worked.
  • Anonymous Sep 26, 2008
    same problem here man i hate this **** idk if its a nvidia driver update since june maybe but lets see
  • Anonymous Nov 09, 2008
    exactly the same problem here...
  • Anonymous Dec 10, 2008
    Hello everyone,
    Same problem here, with VX 922.... close to 2.5 yrs old.
    I can verify the same issues:
    a) fades in and out, progressively until it dies. Not able to render a DOS screen.
    b) Higher resolutions are the worst.... if it's "fresh" it will work at lower ones, but slowly will die.
    c) I RMA'd the company, sent it and got it back...... They sent a new, refurbished unit inside the old case..... It died in 4 days.
    d) I'm sending it back again, hopefully to get a replacement this time.
    No easy solution folks!
    Marcos
The problem gets progressively worse until the monitor completely dies. I solved my problem by returning (Ask for an RMA) the monitor to Viewsonic. Warranty is 3 years. I shipped it out and they returned a refurbished one. Warning: They didn't return the cables I sent with the monitor when I sent it to them in California.
Posted on Oct 18, 2008
VS VX922
Known issue:
ViewSonic VX922 monitor - black screen - green power light flashes.
It is time for ViewSonic to acknowledge that this is an issue that
requires a recall of this product. The transportation to and from
an authorized repair facility and a thorough report that includes
the part description and and ALL of the part identifiers (not, simply,
a ViewSonic designation, but the entire industry identifier).
The report needs to include the "functional" description and where
within the circuit the part is used. A complete "standard notation"
schematic and pictorial diagram set should accompany all repaired units.
If, in the future, it is determined that this is a recurring failure,
it may be in the best interest of all parties that are involved for
ViewSonic to consider replacing the failed product.
Repaired units should carry additional warranty coverage for this
specific issue.
  • Beyond Upset Oct 18, 2008
    VS VX922
    Known issue:
    the part description and ALL of the part identifiers (not, simply,
    should be the responsibility of ViewSonic.
    specific issue.
    Please read this post and disregard the previous one. it is missing
    a line or two... Well, I tried. re: solution #2 above
I RMA'd this probablem as well. They asked the usual questions -- try it alone, check the connections, are you using VGA or DVI... blah blah. Eventually they could give me an RMA.
They have customer support via phone on Sundays in the US, which is nice. Total time from calling to RMA was about 20 minutes.
Posted on Sep 14, 2008
If you can get into windows, which can sometimes be done by leaving the monitor switched off until windows has fully booted, try checking that the lcd panel scaling is not set to "use panel/display scaling" or something along those lines. Rather set it to "adapter scaling" or the graphics card scaling.
This may only give temporary relief, but it seems that the problem in some cases is worsened by the monitor having to switch between resolutions/timings, such as from the bootup screens to windows logged on. My guess is using the adapter scaling allows the monitor to remain at its preferred resolution.
I think this only works on monitors where this problem is fairly recent (fresh)
Posted on Sep 12, 2008
Get the RMA, I had no problems whatsoever with thecustomer service folks. They answered email within 1 business day, shipped off the monitor last week...
Posted on Sep 08, 2008
My monitor dont come on, and green light flashng, viewsonic vp930b.
If your ViewSonic LCD monitor has stopped working with a blinking green power button, It typically means that there is one or more failed capacitors in the monitor. It would be best to send the monitor in to Viewsonic for service or to purchase a new monitor.
Mar 11, 2011 | ViewSonic VP930b 19" LCD Monitor
Viewsonic Optiquest Q20wb green blink light
It's an issue with the power supply, most likely the Capacitors (one or more) may be shot. Open it up if it is out of warrenty, look at the capacitors (they look like cans), if they are bulging at the top or even sides they are bad. This is a common problem with this monitor. Crappy Caps used in manufacturing. Replace all the caps with same rated caps and you should be good. Do your research on how to desolder the old ones off and proper installation of the new ones.
Aug 18, 2009 | Computers & Internet
View sonic flat screen monitor trouble
I have a Viewsonic Flat Screen - recently I turn it on and all I see is like tye dye colors across the monitor with a slight ghost images of windows trying to boot-up. What can I do to fix this. The monitor is about 1 1/2 year old.
Sep 08, 2008 | Computers & Internet
Viewsonic vp930b-3
MY VP930b has the same problem.
It takes a very long time (5-10 minutes) before it becomes normal.
Aug 04, 2008 | ViewSonic VP920b 19" LCD Monitor
Viewsonic VX922 19" Green Light Blinks when booted, no picture
I have the same problem with my VX922 as do MANY others. The problem seems to be caused by leaking/bulging capacitors on the circuit board. The only solution is to replace the faulty capacitors either on your own (which is fairly easy if you're good with a soldering iron) or send it to Viewsonic and have them fix it.
May 21, 2008 | ViewSonic VX922 19" Monitor Flat Panel
I have a VeiwSonic Monitor model VA712b that went blank.
sell it.. the product and sevice from viewsonic in my opinon sucks nothing but problems tv less then a year old want to ship it back and forth to fix it piece of s**t
Feb 26, 2008 | ViewSonic VA712B 17" Flat Panel LCD...
Viewsonic Monitor problem, blinking LED light, no picture.
you guys......you don't have a software (driver, refresh rate, etc.) problem. When you first power up the monitor, do you get any display at all (ex, "analog input" or "No input signal")? Of course not - that's because you have a hardware problem with the monitor. Go here and watch the youtube video on how to take apart your monitor and find and replace the "domed" capacitors that have blown:
http://www.tomshardware.com/forum/247964-33-viewsonic-vx922-monitor-black-screen-green-power-light-flashes
Fortunately I only had 1 ($1.76 at Radio Shack). I replaced it in less than 30 minutes and my monitor showed "no input signal" upon powerup as expected because I wasn't connected to my pc which is full of all kinds of drivers and refresh settings, etc.
Aug 16, 2007 | ViewSonic VX922 19" Monitor Flat Panel
ViewSonic VX922 19" Monitor Flat Panel Logo
560 people viewed this question
Top ViewSonic Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
