Question about Dishwashers
My diplomat Dishwasher ADP8342 beeped 10 times, stopped working and the water has not drained. Any suggestions?
  • louise brady Dec 20, 2008
    ADP8342 beeped a few times now no power and wont drain. Help can't afford a new one yet.
  • 3422 Answers
SOURCE: Diplomat intergrated dishwasher error code FA
The wash cycle finishes too early and
the p / 6 indicator light flashes
(fault code F A appears in the
display)
– the drain hose is kinked
– the drain pump is blocked
* Turn the program selector to the f
*STOP" position (the fault code goes
out).
* Correct the fault.
* Pump away the water and start the
program again (see additional
program "DRAIN" and "Switching
on").
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 03, 2008
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
ukvacfan
  • 328 Answers
SOURCE: candy nova cd112 dishwasher fills with water then stops working
Sounds like the main pipe is clogged - or the food filter. Check that the filter is completely clear.
Posted on Feb 20, 2009
SOURCE: Diplomat Dishwasher ADP8352 Will not complete wash Cycle
My Diplomat ADP8352 when running a cycle it will run for ages, doesn't seem to get hot. If i switch off the m/c then switch it on again it dumps the water left in the m/c?
any ideas?
Posted on Aug 18, 2009
  • 3 Answers
SOURCE: Diplomat ADP8352 Integrated Dishwasher
I have the same issue how did you fix it?
Posted on Aug 13, 2010
Haier dishwasher HDW9WHT beeps 5 times and won't wash what is wrong with it can I fix it or should I get someone in
7 results (0.54 seconds) Search Results
    Haier HDW100WH / HDW100SS - ProductReview.com.au
    www.productreview.com.au > ... > Dishwashers > Freestanding > Haier
    Rating: 1.7 - ‎30 votes
    Haier HDW100WH / HDW100SS: 30 customer reviews on Australia's largest ... 1.7 out of 5 stars for Haier HDW100WH / HDW100SS in Freestanding Dishwashers. ... I putthis review in to do my part for what I think is a great consumer service you ... it it keeps beeping 10 times telling me doors open??and won't begin cycle.
    Haier Dishwasher Error Fault Codes - Lights Flashing ...
    removeandreplace.com/.../haier-dishwasher-error-fault-codes-lights-flash...
    Dec 21, 2015 - Haier dishwasher error codes - flashing lights - beeping ...Dishwasher keep filling water and draining at the same time ... Fix Washing Machine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note 5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The Refrigerator ...
    Dishwasher Has Beeping Sounds Blinking Lights - How To ...
    removeandreplace.com/.../dishwasher-has-beeping-sounds-blinking-light...
    Dec 21, 2015 - At times your dishwasher may need to be reset. ... Haier DishwasherError Fault Codes - Lights Flashing Beeping Sounds My Haier ... Fix WashingMachine That Won't Drain - Washer Not Draining Water .... 2015; Samsung Galaxy Note5 Quick Users Guide September 25, 2015; My Freezer Is Cold But The ...
    How to Troubleshoot & Repair a Dishwasher ' HomeTips
    www.hometips.com/repair-fix/dishwasher.html
Jan 19, 2016 | Haier Dishwashers
FA is a problem with the tubidity sensor. By holding down the power button, it stops, but just repeats everytime you try a new wash cycle. So keep doing it and you can atleast use it. If you want to go one step further and find a permanent solution try feeling around in the sump (where the filter slots in) being careful for any broken glass. Other than that it will probably be a strip-down job to examine the internal hoses and the pump; not a DIY job to be honest.
Feb 03, 2008 | Dishwashers
Diplomat ADP8342 won't fill with water
Assuming the water tap is open and the water pressure is correct, it is likely the inlet water valve in the dishwasher is faulty. If you hear a click at the time the cycle starts but still there is no water then the inlet valve needs to be replaced. Also check the inlet hose for any kinks or blockage of the filter attached to the tap inlet.
The inlet valve looks like this item
Diplomat ADP8342 Solenoid Valve
Aug 05, 2014 | Dishwashers
Dishwasher not working but deeping twice
This is just a guess but it sounds like there is a flow meter on the drain hose somewhere that is bad.
Dec 10, 2013 | Dishwashers
Diplomat adp8322 dishwasher has start button flashing 7 times and rinsne cycle light on what does this mean
This is stating that no water is entering the dishwasher.
My solution was to turn the power off at the wall and wait for 10 minutes.
Turned it back on. Pressed the Start button and held til it beeped and reset, then started as normal and all was fine.
Jan 02, 2010 | Dishwashers
Diplomat dishwasher bleeping showing FA
We have just experienced an FA audible error on our Diplomat ADP 8332 dishwasher...after pulling the dishwasher out and removing the low front panel we found the drip tray full of water. We tipped the dishwasher onto it's front and removed the drip tray and found a float pressure switch...it appears that once the drip tray is full the float switch activates and causes the FA fault (prevents the dishwasher from continuing) drain off your drip tray replace all covers and you should be good to go!!
Sep 16, 2009 | Dishwashers
any ideas?
Jan 04, 2009 | Hotpoint 18 in. DC28 Slim-Line Built-in...
I have a Diplomat ADP 8520 dishwasher (possibly SMEG manufacture) which will not stop trying to empty. There are 4 leds lit reading left to right and it beeps. I have read on some forums about pressing the...
fault is probably water in the bottom tray operating the anti-flood device. take bottom front panel off and mop out the water and it will work. if fault reoccurs then you have a leak
Nov 05, 2008 | Dishwashers
Dishwashers Logo
70 people viewed this question
Top Dishwashers Experts
