CD drive vibrating and cd's not recognised on computer
Internal cd then you need to tighten screws, external cd unit relocate. not recognized then you need to go into CONTROL PANEL and see if the CD unit is listed. If it is not then do an ADD/REMOVE HARDWARE function.
Posted on Jun 22, 2008
My cd drive does not recognise cds
Okay. First of all is it a cd drive in your computer as opposed to a DVD drive? If you put a dvd into a cd drive it cannot recognize the dvd. A dvd drive can recognize a cd, but a cd drive cannot recognise a dvd.
Does your computer actually recognize the drive as being present?
If the drive isn't recognized by the computer try:
power off the laptop
Physically remove the cd or dvd drive
power -up the laptop without the cd/dvd drive
power off the latop and refit the dvd/cd drive
power it up again and see if the drive is
recognized
If the drive IS recognized by the laptop but won't play any disk it's probably the drive itself at fault. You can try gently cleaning the inside of the drive - the optic that reads the disk. However, the usual cause is failure of that optic which read the disk information. It cannot be repaired.
The alternative to fitting a new drive is to buy a portable dvd drive. They connect via a usb cable. Have a look on Ebay
Dec 21, 2014 | Computers & Internet
DVD drive recognised but disc not recognised
not sure how its recognised on control panel
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
you might have to physically unplug the leads for this cd/dvd restart your computer then plug them back this should activate the found new hardware wizard
if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps you
Apr 05, 2012 | NEC MultiSpin ND-1300A (ND-1300A)...
Will not recognise cdr when inserted.Disk loads on my other laptop
The hardware of your CD/DVD drive has failed. Either replace it, or "network" your two computers together, to "share" the working CD/DVD drive across your network.
Jun 01, 2011 | Teac (CD-224E-A34) (CD224EA34) 24x CD-ROM...
Cd drive on laptop not recognised by OS
If CD /DVD drive is not listed, perform a full scan with your antivirus software to check for and remove viruses. Viruses can sometimes prevent Windows from recognizing the drive.
regards
Apr 26, 2010 | Sony VAIO VGN-SZ330P/B Notebook
My MATSHITA DVD-RAM UJ870QJ ATA will not recognise an audio cd
i tried this and it worked when nothing else would.
http://sites.google.com/site/matshdvdfix/
Feb 21, 2010 | Acer Computers & Internet
When I play a cd the drive vibrates very noisily
The vibration is from the fast rotation of the drive spinning the cd. Many newer drives do this. the only solution would be to place an older slower drive into the computer.
Jun 19, 2009 | Acer (91.48T37.003) CD-RW/DVD-ROM (Combo)...
CD drive does not recognise my discs(Sims 3)
Sims 3 comes on a DVD-ROM, therefore you need a DVD drive on your computer rather than a CD drive. As a test, take a disk that you know is a DVD (like a store bought or rented movie) and see if you can read that on your computer. If you cannot, then you probably have only a CD drive in your computer. DVD drives are inexpensive and easy to replace. You can purchase one at a local computer store.
Jun 05, 2009 | Evesham Computers & Internet
Cd rom recognised as cd audio
They will definately need drivers to be able to give out 100% of the performance.
You definately might have receive a disk while purchased the CD/DVD ROM.
Try that driver once and see the difference.
Jun 03, 2009 | Sony NEC Optiarc AD-7200A IDE Internal DVD...
MY CD DRIVE HARDWARE DISAPPEARED IN THE MIDDLE OF READING THR CD
Wow that is strange.. You might wanna go to your device manager by rigth click on my computer and enter properties once you open the device manager highlight my computer from the screen and click on the tab action and scan for the harware change it should recognise the Cd drive and reinstall it
Feb 18, 2009 | LG CRD 8522B Internal 52x CD-ROM Drive
CD-ROM won't read discs
there is no problem with the system. only you need to clean the lens using CD/DVD cleaner.
Jan 05, 2008 | Gateway (5500778) Internal 32x CD-ROM...
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
