Question about Samsung Digimax A402 Digital Camera
Fuzzy/ not very sharp pictures
Pictures are not as clear as they used to be. I've played around with the settings and not sure if I've got them off of the original ones that were on there when I bought it
  • 2 more comments
  • bythebay Jul 28, 2008
    My pictures have always been pixily when I print them....
  • janique-ka Nov 15, 2008
    blurry pics
  • aliciarivera Dec 15, 2008
    My camera started to display pics fuzzy and then sharpen up in a second (this is on screen). When I download to my pc or to print the image downloads only the initial fuzzy pic. I checked every setting I could and can't find anything wrong. I hate to buy a new camera over something that could be easily fixed... does anyone have any ideas?
    Thanks!
  • Anonymous Dec 31, 2008
    I ALSO HAVE THIS PROBLEM
Would not work with a memory card
Posted on Jul 19, 2009
    Scholar:
  • 97 Answers
If the photos look pixellated, perhaps you've turned down the resolution/quality setting? Check the manual for how to correct this.
If your photos seem generally hazy, your lens could need cleaning. Use a lint free cloth such as one for cleaning spectacles.
If all your photos have a smooth, out of focus appearance, it could be a camera fault. However, if you've recently been taking photos in poor light without flash, it could also be "camera shake". You can distinguish this from out of focus because the blur is slightly directional rather than being smooth in all directions. Points of light become lines not blurry discs.
Posted on Sep 05, 2008
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
Picture becomes fuzzy and lined, clears with a sharp rap on the top of case.
probably a bad connection on the circuit board inside that heats up over time. the tap on the top probably moves the connection just enough To make it good for short time.
Feb 02, 2018 | Hitachi 60UX54B/55K 60" Rear Projection...
Just purchased tv and the quality of the picture is still fuzzy tried to mess around with the resolution but it still isnt very sharp at all
The TVs produce picture using entirely different methods. Usually the colors and especially level of black color are better on plasma, LCD will have some trouble various shades of gray and black especially shading on peoples faces etc.. This is not a defect in the LCD just a limitation in current technology.
Apr 26, 2009 | Televison & Video
Fuzzy dvd pictures
well it's a bit hard to give comment on the 'usefulness' of this site as no-one seems to reply to anything on the forum....i guess it's yet another scam to get people to enrol on a payment scheme....surpirse surprise. i'd be shocked if i actually got an answer to my problem....
Feb 08, 2008 | Sony KDL40W2000U 40 in. LCD Television
Le40m86bdx picture not sharp
I have a two and a half month old Sharp, LC-19SK24U-W. It was fantastic with fantasic, clear, beautifully colored picture until two weeks ago. All of a sudden, the picture starting getting darker and darker. Nothing had been adjusted from day one when I set up contrast, etc. This comes and goes but most of the time is an issue. I can make it a bit lighter but then it is so fuzzy and grainy it is a very poor picture. Also, while this began, one time the television turned itself off and then back on without a power surger or anything.
HELP!
Jan 09, 2008 | Televison & Video
Fuzzy pictures
Go back to film. Digital SUCKS.
Dec 21, 2007 | Casio Exilim EX-Z50 Digital Camera
52D82U Fuzzy picture
Change your input source. You are probably on Input Source "TV". My HDMI cable is plugged in INPUT 4 so make sure that your TV is set to the right INPUT.
Oct 07, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Fuzzy Picture
Are you using the component (RGB) outputs, and a Sony TV? I believe that there is something in the output of at least some Panny DVD recorders (over the RGB component path), which Sony TVs don't process properly.
Aug 15, 2007 | Panasonic DMR-EZ17 DVD Recorder
Fuzzy picture
when using a video recording programme, the backlighting is normally automatically done for you but in live messenger you have to set the camera up yourself, as the fuzziness you are experiencing will probably be the lack of lighting in the immediate vacinity, so within the camera software before you go online, go into the settings and change the backlighting, most cameras have this option, also check the options in messenger, or make sure you are well lit around youself especially at night.
Jun 17, 2007 | Logitech QuickCam Fusion Webcam
Samsung Digimax A402 Digital Camera Logo
223 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
