Question about Compaq Inkjet Ij300 Printer
Compaq ij300
Prints triple on page
  • Anonymous Jan 22, 2009
    • 1 1 1 on top of each other.
  • jeturner Feb 16, 2009
    my computer won't let me change it to black and white -- do you know why -- it will not give me the option
Cartridge setting was on color changed that to black and problem was fixed
Posted on Jun 23, 2008
How do you connect a compaq ij300 printer with no cd?
I presume you mean install and not connect,.... Go to Compaq and look under downloads and support, and get new install program for your printer and OS.
Mar 06, 2011 | Compaq Inkjet Ij300 Printer
The print size changed from regular sized to very small. What can I do?
try printing a test page from the properties menu of the printer and see what happens.If it's alright thenit;s what you printed that cause the reduction
Oct 07, 2009 | Compaq Inkjet Ij300 Printer
We have windows vista and when we tried to install compac IJ300 it only goes up to windows 98 - can we install that using vista???
I found this solution on another website, I suggest you give it a try.
Everything works fine since I installed Vista except for my printer a Compaq IJ300 which is a Lexmark Z11 in disguise. I installed the driver for the regular Z11 through the "Add Printer " but had problems.
Went to Lexmark site - downloaded drivers for Z11 Series ColorFine- working perfectly. So far I have no other problems with vista.
Aug 25, 2009 | Compaq Inkjet Ij300 Printer
Triple vertical printing with Z11
Here's what worked for me: (I'm using a black ink cartridge, but my 'printer properties' were set for a color cartridge, thus basically sending a '3-color signal' to my printer; making it print in triple vertical.)
Go to Settings > Control Panel > Printers. Right click on your printer, and click Properties. Click the Cartridge Maintenance tab, then click Install / Change Cartridge. Select the cartridge you are using in the drop-down list, and click Continue. Print an Alignment Page. If this dosen't work, close everything and try it again: I had to do it twice to get mine to work. Hope this helps!
Kerry
Apr 27, 2009 | Lexmark JetPrinter Z11 InkJet Color...
Print from DOS
Try Start --> Programs --> MS DOS
or Start --> Run --> enter CMD
this will take you to a DOS screen
To print a file use the type command and pipe it to LPT1
e.g. type myfile.log > lpt1
Feb 16, 2009 | Compaq Inkjet Ij300 Printer
Compaq Ij300 Power Adapter
The AC adapter for the COMPAQ IJ300 is the Class 2 Power Supply, Model DND-3005, INPUT 120-127V-50/60 Hz 350mA, OUTPUT 30V---500mA, PART # 70D0209, Assembled in China 9933 per my orignal adapter for the COMPAQ IJ 300.
Jul 15, 2008 | Compaq Inkjet Ij300 Printer
Black cartridges won't print. Color cartridge works.
Why dont you go to the store that you bought the printer from and ask one of there people there fix the problem..
Dec 28, 2007 | Compaq Inkjet Ij300 Printer
Will not stop printing
As above my printer will not stop printing. As long as it as paper it continues to run paper though.
Sep 11, 2007 | Compaq Inkjet Ij300 Printer
Printing
Sadly, Compaq printers (rebranded low-end Lexmarks, the X11 in your case) were not robust at all. Since they were originally created to be a free pack-in for new home PC's, they were not really meant to be used for more than a year or so. It sounds like there is some build up around the jet area, this build up will smudge around when printing. You can try to clean it out with a few cotton swabs although if you aren't careful, some cotton fibers might join in the mess. Another trick I have done in the past is run a piece of cardstock through the printer a few times. Sometimes the extra thick paper will help scrape off excess inks.
Aug 23, 2007 | Compaq Inkjet Ij300 Printer
Printing Problems
My compaq ij300 was doing the same thing. I removed the cartridge, took a kleenex and wiped the back of the cartridge until it was completely dry and shiny looking...until no more ink would come off on the kleenex. Replaced the cartridge and aligned it using the printing software. I didn't use the test page, just typed a one-line document and hit Print. That took care of the problem.
Dec 20, 2006 | Compaq Inkjet Ij300 Printer
Compaq Inkjet Ij300 Printer Logo
243 people viewed this question
Top Compaq Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Tony
Are you a Compaq Office Equipment and Supply Expert? Answer questions, earn points and help others
