By formatting your hard drive, you've wiped all the data.
You now need to re-install an operating system.
If you have a Windows installation disk, just put it in your CD/DVD drive and re-boot, follow instructions.
If you don't have an windows installation disk, its a case of buying one, make sure you also get the COA Code of authority, 5 groups of 5 letters and numbers.
If you don't want to pay for a system disk, Download and burn a copy of one of the Free Linux operating systems. Ubuntu is my favourite. Just log onto :- http://www.ubuntu.com/ and follow your nose.
Again, when you have a disk, put it in the drive and reboot.
Turn on your PC and wait for
the "Acer Splash Screen" to appear.
This is the screen that has
the Acer logo and is one of the first screens you will see.
Press the "Alt" key and "F10" keys at
the same time when you see the splash screen until you are brought to the
"Windows eRecovery Options Screen."
Choose the Windows
Installation option from the main screen.
You will be prompted so you
are aware that all information currently on your drive will be lost.
Choose which Windows Operating system you want to
overwrite.
Typically you will only have
one Operating System and you can simply press the "1" key.
If you have, for instance,
Linux as your first OS and Windows as your second OS, you will need to press
the number that corresponds to the OS you are replacing.
Choose to partition your C:/ drive or whichever drive your
Windows OS is installed on.
This will completely reformat
your drive and install a fresh copy of Windows.
Allow the process to run and
your drive will format, and then Windows will reinstall to your computer.
Request a recovery CD from
Acer if the Alt + F10 option does not work.
You can find Acer Support Located
using this link.
http://www.acersupport.com/desktop/articles/multi_2cdcpr_vt10596.html
You will then follow the
exact same steps as listed above after booting the computer with the CD in the
drive.
Hope this helps.
Hello Gordon!
This is not something that can be solved by posting a single question and providing a broad ranged answer.
My solution depends on your answers to many questions. The first one being, what is your operating system?
I also need to know the following:
Did you attempt recovery with "disks", or by using recovery software that was installed on an additional drive on your pc?
Did you reformat with the same operating system that you had prior to this problem or are you changing and/or upgrading to something else?
Do you want to try and handle this via messages through the website? We have other options such as email (direct) or via phone, if either would be ok with you? (No charge. This one is on me)
[email protected]
Please answer my questions and tell me how you wish to proceed ok?
