Frigidaire Washer won't drain
Hi, My daughter has a top loading washer, fairly new, and it suddenly won't drain all the water in the spin cycle. She said that previous to this happening it kept becoming unbalanced and she would repeatedly rearrange the load. Despite her efforts she could never get it so the drum even looked like it was sitting properly when at rest. Now it won't spin enough to get all the water out, though it does continue through the cycles to the end. She has small children and it sounds to me like there could be a sock or something stuck up under the agitator column. Do you agree and is this a repair she can handle herself? She's determined to try.
  • 38 Answers
Sounds like a bolt on the agitator shaft is broken which is causing the imbalance. Open lid, lift off fabric softener dispenser, pull out plastic cap, take out bolt, lift agitator out(might have to wiggle it a bit). Replace BOTH horizontal bolts holding inner tub to shaft. Tighten all the way. Replace all parts.
If it doesnt spin all the water out, that could be due to a bad bearing. Hold inner tud at the rim and turn clockwise and then anti-clockwise. If it turns bothways, you have a worn bearing. This job isnt for the do-it-yourselfer.
What is happening is the motor is spinning the bearing but it's not engaged to the drum.
Posted on Jun 22, 2008
Frigidaire Washer/Dryer Combo FEX831CS0 won't work
Hello Laura Clark - Does the drain pump make a humming noise? If so, you possibly have a restriction in the drain line or siphoning. Try setting the cycle to spin only and verify if water pumps out. If it does not, the unit could possibly be experiencing an issue with the pump, door lock assembly or timer. Since it is such a complex unit, I suggest contacting a professional to move forward accurately
Dec 12, 2012 | Frigidaire FEX831CS Top Load Stacked...
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jun 25, 2011 | Washing Machines
When doing a load of laundry the washer will stop at the rinse cycle and not drain or spin out the excess water
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
If you are having problems with your front load washing machine then checkout this tip...
heatman101
Jan 03, 2011 | Frigidaire Affinity ATF6000F Front Load...
Won't drain and spin. Cycle completes and all the lights on far right flash. Door won't open. Bottom of washer is filled with water. Tried putting it on drain and spin cycle. Still won't drain. Beeps...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Frigidaire Washing Machines
Daughter washed a feather pillow which fell apart in front load frigidare washer now it wont spin and drain can u help plz?
The drain is plugged...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 30, 2010 | Frigidaire ATF6000ES Front Load Washer
SPIN CYCLE WON'T DRAIN WATER FROM TUB IT RUNS ONTO MY FLOOR
Sounds like you have a bad water pump. Remove the hose going into the water pump and coming out of the pump and the pump should pull directly off the shaft check to make sure it spins freely.
May 01, 2009 | Frigidaire GLWS1349A Top Load Washer
Frigidaire front load washer won't drain or spin
This often is a drain hose that is too low or a drain hose that has been pushed too far down inside the stand pipe....the water is actually siphoning out of the washer. Do not "seal" the drain hose to the house plumbing pipe, this will also allow the water to be siphoned out.
Nov 12, 2008 | Frigidaire GLTF2940ES Front Load Washer
Spin cycle issue
if this is a frigidaire as in the healine , then see if the tub turns over at all. if not then it may be the inverter board located on the bottom right rear. If there is water left in the tub now that water should drain before it will fill again. check drain pump for obstruction/operation.
for the inverter, there is a techsheet in the bottom attached to the wall, It gives info for checking it. Have a multimeter handy.
Apr 23, 2008 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
