Question about Kenmore 63252 Microwave Oven
721.63263 i have the same problem, will not heat up and say power 100 what is this ,i dont know how you feel this is not the sears i grow up with , there custmer service is awfull ...... wayne
  • sears10269 Jun 23, 2008
    sears kenmore will not heat up it power 100
  • William Miller
    William Miller May 11, 2010
    Please reply back with your brand and model number and precise details on the problem you're having so we can help you.
  • Kenmore Master
  • 19,396 Answers
Test the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode and capacitors can br tested. The capacitor must bealloweddischarge before testing, or you risk to get electrocuted, evenifpower is off. Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts.
Posted on Apr 27, 2009
Maytag Microwave MMV2507BAS will not turn off
faulty power switch will cause that issue, you can have sears come out to fix it, depending on how mush you payed for it you might want to get a new one.
Apr 15, 2008 | Microwave Ovens
My kenmore microwave decided to stop heating!! It's less than 1 year old whats the problem??
Any piece of gear with electronics it can have an early failure. It's possible that the fuse for the high voltage circuit has failed or even the magnetron or the diode that produces the DC for it has gone south. I have the ugly feeling that these don't have a year's warranty anymore but it would be worth checking. I'm growing tired of Chinese quality.
Mar 27, 2011 | Kenmore Microwave Ovens
Type s333 2006 microwave will not heat. Everything is good but the microwave don't heat
this could be a number of things, fuses, megortron, capacitor,
but what ever it is dont try to fix it yourself there is over 1000 volts kicking about inside it and if you tuch this your going to grow wings prity fast, have you ever seen a stun gun working? well inside your microwave it there very big brother!!!! but it dont stun,,, it kills
look at it this way,,, whats your life worth in £????? play it safe,,, call a guy in to fix it for you, ok
Oct 20, 2009 | Panasonic Microwave Ovens
Cuisinart Microwave won't heat food
open the casing and replace the blown fuse.there are several so check them all. probably why the machine was in the auction
Feb 05, 2009 | Cuisinart CWM-100 Microwave Oven
GE Advantium Microwave not heating food
If you want it fixed call sears for service. I would not recommend taking this microwave apart if you dont work on them for a living. only because there are 14 million thing that need to be remove to do a simple repair.
Dec 04, 2008 | GE Advantium 120 Convection/Microwave Oven
My Kenmore 64663 still heats but I don'y hear the fan anymore while heating
If it's the internal cooling fan, you really need to get that repaired before you cook anymore with it. Otherwise, your magnetron will be destroyed.
If it's the hood / exhaust fan, then the problem may be the motor or a problem on the control board.If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
A full Sears/Kenmore model number usually has 3 digits, a dot, then 8 more digits, such as ###.########
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you don't feel confident to tackle it yourself, I would contact Sears for service.
Aug 22, 2008 | Kenmore 64663 Microwave Oven
Sharp Carousel Microwave ESP Sensor R-1451 1.50 w 850wats has load noise and will not heat, what could be wrong?
It's probably a shorted high voltage rectifier diode.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at ourlisting here on FixYa: http://tinyurl.com/yzjozk
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from the Sears link above or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
If you need more help, please feel free to conact me directly through the links at our site.
Dec 18, 2007 | Microwave Ovens
No power...
If the stove was on without the hood fan's being on, it could have put too much heat in the "innards" of the microwave. It may have opened the thermostat or thermal fuse located inside - either on the chassis of the microwave or or the magnetron. It will look something like the one in the attached photo. For helpful exploded view diagrams and to order any needed parts, you can visit the GE parts Web site or the Sears parts Web site at http://www.geappliances.com/shop/prts/ or http://www3.sears.com/ (the 3 is correct) In my profile, you can find a link to my site, where you can find critical safety & disassembly tips. Post back if you need more help.
Dec 23, 2006 | GE JVM1660 Microwave Oven
Kenmore 63252 Microwave Oven Logo
242 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
