Question about Hoover Vacuums
Hoover F6025900 Steam Vac Widepath LS, I own this steam vac and I found bits of rubber under the machine when I turned it on, smelled like burned rubber from a belt? Can you please tell me if there is a belt on this carpet cleaner and if so, how to access the belt? I have taken out some screws and still cant get to the belt? Thanks
  • 1,673 Answers
Well there is no belt, and not sure what the rubber would be from, everything is plastic or metal. Unless it is really an electrical smell, which means the motor is going bad.
Posted on Jun 22, 2008
My hoover steam vac is making a horrible noise and smells like its burning
Something may have jammed the brush roller, preventing rotation. This causes the motor shaft to rotate in one spot on the belt, causing the burning rubber smell. Eventually, the belt will break. You need to find what caused the jam and remove it. It would be a good idea to replace the belt as a burned belt is unlikely to last much longer.
Dec 18, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
I own a hoover steam vac model # F5915900 inside the recovery tank the seal broke. Where can I buy a new rubber seal?
Here is the webpage for vac parts warehouse. This shows a diagram of your steam vac. You pick the part and buy it.
Hope this helps.
Handie Andie
Mar 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Dual V steam vac model F7425-900 won't dispense detergent
Check the spring loaded valve at the bottom of the detergent bottle.
Push it up with your finger or a pencil or some such thing and see
if fluid comes out. If it does, then the problem is the valve or tubing I
would suspect.
Oct 22, 2009 | Hoover F7425-900 SteamVac V2 Widepath...
The brushes on my steam vac won't spin
I used the suggestions found from a previous question found on your site.. thanks though. will recommend your site to all.
Aug 19, 2009 | Hoover Steam Vac Dual V w/ SpinScrub...
Hover steam vac Model #F5897-900
When I use my Hover Steam Vac, it smells like rubber is burning. How do I fix this?
Jun 16, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Water and shampoo run out with the trigger in the off position
From your description, you have a problem with your one of the solenoids that may be stuck open. this would require a shop repair.
Nov 30, 2008 | Hoover Steam Vac Dual V w/ SpinScrub...
Hoover Steam Vac LS F5897-900
get a copy of the manual at this site
Aug 07, 2008 | Hoover F6055-900 SteamVac Maxextract LS...
Drive went out on my Hoover Steam Vac Shampooer and brushes won't turn plus there's a burning smell coming from it. Only used it 6 times - bought it in March - 2008.
Generic problem for all Vacuums
Posted by buster_lls on Jul 09, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me like you have multiple problems with your power drive; a burning smell and the brushes don’t turn, and the dop is on March, 2008 – the Hoover Steam Vac Shampooer has a one year factory warranty and it could be a broken part for the brushes won’t turn or a belt would cause the burning smell. If it is not the belt or broken part it probably is the motor of which you should take it to a authorized Hoover vacuum cleaner dealer in your area or to contact the Hoover factory cust serv listed below or the Hoover website for information. If it is the motor the factory authorized dealer will replace the part for the motor and the broken part for the brushes, if it is the belt that would be an out of pocket expense. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions. Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 09, 2008 | Vacuums
Vacuums Logo
221 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
