Question about Linksys WRT54GC Compact Wireless-G Broadband Route Router (LSWRT54GC)
Installation after i hook the box up to my modem it tells me that i have a connection but will not find server when i try to get online
  • marlon john madrid
    marlon john madrid May 11, 2010
    whos is your ISP (internet service provider)? and the brand of your modem?
    Genius:
  • 1,689 Answers
Okay, you may have DSl or cable as your ISP, let me post both for other's use
better if you start off with a clear router.
locate and press the reset button on the router for 20-25 seconds, then let it go, after so unplug the power, then plug it back in after 15 seconds. this router's reset may be hidden, use a paper clip or a pen to do this, it will be tagged "reset" eitherway.
once that is done follow these:
check your PC's IP.
XP
click start>run>CMD> then click "OK"
on the command prompt type in ipconfig then press "enter"
vista
click start(orb)>on start search type in CMD then press "enter"
if your IP address shows 192.168.1.xx (xx being a number from 2 to 253), you may close the window and proceed to the next step.
if your IP starts with 169.254.xx.xx please repeat resetting the device, then the power cycle.
okay so you got a good IP, follow these then.
for DSL ISP (that uses PPPoE)
1.open IE
2.on the address bar type http://192.168.1.1 then hit go
3.it will as you for a username and a password, leave the UN blank and the PW is admin, if that did not work try putting admin on both username and password.
when a linksys window shows up, you will see tabs like:
Setup
Wireless
Security
Applications and Gaming
Administrator
etc
*on the setup tab, look for a line or an item sayiong "Internet connection type" click the drop-down menu then set your connection to PPPoE. you will then see a space for your username and password, type in the UN and PW from your DSL ISP, then click on "save settings" on the bottom part of the page.
-after this go to the Status tab and you will see your internet IP address, if not you should have a "Connect" button on the middle of the Status page.
for Cable ISP
1.open IE
Setup
Wireless
Security
Administrator
etc
on the "Setup" tab, look for a subtab that says "Mac Address Clone" then:
1. enable the clone service
2. click on the "clone your PCs MAC"
3. click on "Save Settings"
once saved, we do a power cycle including the modem.
1.turn the modem and the router off
2.after about 10 seconds, turn the mdoem and wait for the light infront of it to be stable. (like the "online" light should be solid)
3.once it is solid, turn the router back on, then let it sit there for about 15 seconds or modem until the power light is solid
once both devices are on, go back to your Linksys setup page, click on the status tab and you should be able to see an IP address on the internet section, once you have it, you're now online.
Posted on Jun 22, 2008
Modem installation
It is not a lost cause BUT you will have major issues connecting to most websites because the browsers are so advanced now that if you connect, it wont display correctly and there is an issue with some secure servers rejecting you because the operating system can be read and the server wont allow the connection.
http://www.dslreports.com/faq/bellsouth/3.14_Westell_2100_2200_6100_Info#7342
Jul 26, 2017 | Westell Wirespeed Westell Dsl Router Wind...
Linksys wireless prnt server
Based on your post description, I am assuming that:
1. You can connect to the Internet through your 2241 Neptoia modem;
2. You can access your WRT54G V8 Linksys Wireless router @ 192.168.1.1;
3. Both 1 & 2 above could be done through a wireless connection from your PC.
Connect everything as they are supposed to be wired (printer, Print Server, modem, router etc)
Pls try:
a. Connect the Linksys wireless print server using a lan cable to the Linksys WRT54G Wireless AP/router. (Will tackle the wireless connection a bit later)
b. Reset your print server; &
c. Do a diagnostic print-out.
Instructions for b & c are in page 4 of your manual.
You need to verify that:
i. the Power indicator is contnously green
ii. the Ethernet indicator is contnously green
iii. the USB indicator is contnously green
iv. the Wireless indicator may or may not be contnously green
Pls post back with the generated diagnostic print-out before we can proceed with the other steps.
Additionally, try installing the Epson Stylus Photo RX600 direct to one of the USB ports of your PC. Use the installer/driver CD that came with it. Try using it as a regular printer. This will tell us status of the printer.
Good luck and kind regards.
Nov 11, 2007 | Computers & Internet
I HAVE A NEW HP DESKTOP AND AN OLD LINKSSY WIRELESS G
Hi Vivian,
Chweck you cables and where they are conencted.
You will need to make sure that the Comcast modem is providing internet, you can do this by connecting your laptop to it using ethernet directly if it connects to the internet, that will be a good thing.
From your comcast Modem, the ethernet Cable should go to the linksys where it says "WAN". this should give you an internet connection and make your comcast modem communicate with your linksys Router.
Jul 22, 2010 | Linksys Wireless-G Broadband Router
I have an internet connection with cox however everytime i try to set up my router it keeps telling me that the router is not connecting. how can i fix this
Are you trying to set up the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem
then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 07, 2010 | NetGear WGR614 Router
IWon't hook up to my modem
Try getting a different CAT5 cable.
Mar 20, 2010 | Belkin F5D7234-4 Router
My router was unplugged and when I plugged it back in, I get a message telling me that the computer is not communicating with the dns server.
Are you trying to install the router.
Then you need to connect the computer to the router ad the modem to the router.
Click Here for step by step by instructions
Jan 13, 2010 | Linksys Wireless-G WRT54G Router
I CAN'T GET IT TO CONNECT WHEN I WAS SETTING IT UP.
MAke sure that your computer is able to go online through the modem.
Jan 11, 2010 | Linksys WPSM54G Print Server
Ps3 online playing
The servers were down for maintenance.
Jul 18, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Ps2 playing online madden with the network adaptor
  1. Turn off your PS2 console.
  2. Get your CAT5 Cable (link varies based on where your router or modem is).
  3. Put one end of the cable into the port of the Network adapter (or slim PS2 and PSX) port labeled "Network".
  4. Connect the other end in a free port in your router (or on the port on your broadband modem).
  5. Turn on PS2.
  6. Turn on modem (or router).
  7. Put in online game.
  8. Go to the online section in the game.
  9. Create a network Configuration
  10. Load it
  11. Create an ID.
Jan 05, 2008 | Sony PlayStation 2 (PS2) Console
Linksys WRT54GC Compact Wireless-G Broadband Route Router (LSWRT54GC) Logo
96 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
