Question about Danby DWC283BLS Wine Cooler
Not staying cold all of a sudden
It's been working fine a little over a year and now all of a sudden it won't stay cold down to the preset temps. It is at 71 and sometimes goes down to 67 and that's it. I've cleaned out the bottow back and unplugged it 5 minutes to rset and so on. Nothing is working. What do I do?
  • 1 more comment
  • danner Jul 18, 2008
    My Danby cooler worked well for over a year, cooling to the 45-52 or so range it is supposed to.  Then I noticed the temp was in the 60s, and now in the 70s.  Definitely room temp.  I unplugged it for periods of 5 min to overnight but that didn't help.  Setting the temp by pressing the buttons didn't help either.  Seems that I am not alone with this problem.  HELP! please.
  • jimfranp Jul 19, 2008
    Fan at the back of the top shelf not working. Compressor is hot. Temperature is not cold enough.
  • Anonymous Sep 11, 2008
    Compressor is hot, temp wont get below 76- Any suggestions?
  • 126 Answers
THE PROBLEM NEEDS THE ASSISTANCE OF A TECH THER MIGHT BE A PROBLEM WITH THE GAS CHARGE OR THE COMPRESSOR NOT PUMPNG EFFICANTLY.GOODLUCK. MOHAMED
Posted on Sep 17, 2008
Won t stay running when first started. runs fine once its warmed up
This sounds like the temp sending unit for the ecm is bad. There are 2 temp sensors, 1 for the light/gauge and 1 for the ecm. The sensor sends a signal to the ecm to tell it engine temp, the ecm them adjusts fuel mixture for cold or warm engine.This works much the same way as the choke does on a carb for cold starts
Jan 11, 2014 | Dodge Durango Cars & Trucks
2006 f150- temperature gauge stays cold but "check gauges" flashes in mini message center.
Since the temp gauge is not working correctly, you get the warning message.
Could be a faulty temp sensor or a problem in the wiring harness.
Apr 08, 2013 | 2006 Ford F-150
Tappan gas oven won't stay hot
bad flame sensor or check gas pressure
Aug 24, 2017 | Tappan Ovens
Rear hatch will not stay open when weather is cold, temps below 45 affect the vacuum on the rear hatch. works fine in warm weather
Those little shocks are gas charged, thus pressure increases in hot, and decreases in cold. Over the years they tend to seep, or leak a bit, thus, only work good in warm/hot weather. They have replacement ones at autoparts stores, and shouldn't be too expensive.
Dec 04, 2009 | 1999 Jeep Cherokee
Bosch AquaStar 125b ng suddenly goes cold during shower
Does it happen to any other fixture? If not, it's most likely your shower valve and not heater.
Sep 01, 2009 | Bosch AquaStar 2400ES-NG
Fridge not staying cold, periodically
CHECK FAN OPERATION   MOST OF THE TIME IT IS THE THERMOSTAT
Aug 12, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
My ac will not stay on when its at a certain temperture or auto. only if its in on position
this is correct because if you set it to certin temp. when it reaches that temp. it will shut down to prevent over cooling when the temp in the room goes up a preset amount 2-5 deg.(preset by manafatuer) the unit should go back on to drop the temp. to your set temp. Auto works the same way, where just on will cool to the temp the system can cool efficently.
Jul 31, 2009 | Heating & Cooling
Fridgedaire freezer not staying cold. I can
did anyone help you with this problem? i have a similar problem but my freezer works fine in the summer. it does not stay cold enough in the winter. i keep the frige in my garage as a spare but it's not very helpful when it doesn't work! a repair person told me it was too cold in my garage for the freezer to work...not sure why, the frige part works fine. i'm looking into a blanket insulator from appliance zone to see if that will help.
Jul 25, 2009 | Frigidaire FRT17B3A Top Freezer...
Washer is a top load set it hot water and starts with hot and then will go cold willnot stay on hot G E Profile ,model wwa8350g
most new washers sense water temp and will try to adj final tub water temp by alternately running cold or hot as needed ..most hot settings are not faucet temp but a predetermined temp so if your hot water is 140 degrees coming in the control will switch the cold on to bring final tub water temp down to preset ..which could be as low as 100 degrees the industry's way of energy conservation
Sep 23, 2008 | GE Washing Machines
Danby DWC283BLS Wine Cooler Logo
498 people viewed this question
Top Danby Furniture Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Dennis Boxerman
Are you a Danby Furniture Expert? Answer questions, earn points and help others
