Microsoft Xbox 360 Console Logo
Anonymous Posted on Jun 22, 2008
The tv right i can play games and sound is fine and loading it is as normal but when the main screen comes on when u push the middle button and comes up with the logo xbox 360 it supports to be in colour but mine is grey u can see the colour but it jumps and then sometimes its normal meaning the colour is the right colour is suppose to be but when i turn it off and turn it on again the colour goes again why is this happening is it my console or what some help
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Jun 23, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
111
Points
Could it be your cables to your tv? try it on a differant tv if not try someone elses cables if its neither of those you made need to get it repaired
I have an Hitachi P42H401 72" my son was playing a game on his Xbox360 the othe day the TV was fine and has been in the middle of his game the TV screen went to no signal and the TV shut off and has been...
I did some research for you. This is a known problem with this TV. Remove the back cover, blow out all dust, then disconnect and reconnect all cables leading to and from the power supply. (Do one cable at a time). One of them is not making proper contact. // Your son playing a game is an interesting coincidence. The guy who figured out this ''fix'' had the same exact thing happen. Only in his case it was his niece who played the video game. // Best of luck to you...
Playing MLB the Show on PS3. Game loads fine, franchise I've been playing loads fine. But once I try to play a game, bar starts as game loads then game cuts off and goes to main PS3 screen.
Is your CD dirty or does it have any cracks? It might just be the problem. Otherwise, it could be corrupt game data. Clean the disc, if it still doesn't work I'd try deleting the game utility data and re-downloading it. Hope this helps in some way or another.
5helpful
PS3 WILL play games but NOT Blu-ray or regular DVDs
hold the power button down when it is red till you hear the quick beeps then select the file restore. this is a diagnostics screen...you may have to hold the power button in for several seconds....does your ps3 work on a non hidef tv?
Can not get video to TV
on main windows screen, right click middle of screen, go to properties,
Drag #2 box to the left side of the #1 box, hit apply, enable both displays, hit ok.
1helpful
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Screen goes completely out.
when it blanks out, tuen the lights out in the room, and shine a flash light at the screen, see if you can see the picture, if you can, it is the inverter moard blamking out, thats the board that lights the back lights, if you cant, hit the input button on the remote, if the TV comes back with a picture, it is a problem with the main board, in paticular the componant input on the main board
1helpful
2answers
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
1helpful
Sound but no picture
chances are the scart lead has come out slightly at either end, give both ends a wriggle while on play
Top Microsoft Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
