New Tefal One Cup, and it has stopped heating the water, FAQ says it needs descaling, but it is only two weeks old ???
  • jasonandanna Jul 11, 2008
    had the same problem so returned it to curries. Most helpful. Second machine stopped producing hot water on only the fourth cupper. Couldn't believe it despite doing everything the instructions said. Now my wife is really nagging me!ha. In the process of liaising with tefal.
    Scholar:
  • 104 Answers
Sounds like Mfr defect. Do not recomend trying to repair since it is new and could void any warranty. Recomend returning to where you bought to get a new one.
Posted on Jun 23, 2008
The iron has been all descaled, however we cannot get any steam when pressing the button. It is a Tefal express generator model 3 years old.
Once you have descaled the boiler and refilled your frontpiece of the iron itself (hopefully with distilled water - any supermarket) you press the "reset"/ "restart" button on the back end of the steam generating unit. When the water is hot enough press steam button & turbo button a few times - WARNING: make sure iron is facing downwards and cover ironing board with old rag because initially brown steam splatter will come out on first few steam releases.
Feb 14, 2015 | Tefal Irons
How to descale tefal express boil
I was searching for this solution then I found the manual in a draw so to help anyone else with the same problem the method is:
Descaling should be carried out every 3 months.
Fill the appliance to max. Dispense maximum size cup to a large cup.
Add descaler to the cup then pour back into appliance.
Dispense the mixture in the appliance into the cup and disgard.
Continue until applance is at minimum water level.
Empty the appliance then refill with water and run it through the machine and disgard until its at minimum then empty the appliance again.
It should be ready for use. You can use 1ltr white (and only white) vinegar instead of the descaler and water mixture.
Jan 24, 2012 | General Kitchen Appliances - Others
Tefal quick cup kettle water coming out in slow spurts,have changed filter but no improvement.
If you are in a hard water area you may need to descale the heater element. Try adding 1 cup vinegar to 3 cups water and run the machine should clear up the scale. Rinse thoroughly before use.
Sep 12, 2010 | Tefal Kitchen Appliances - Others
Hello tefal quick cup water is no longer hot only
we had to return our first one for the same problem Gavin. Tefal (surprise surprise) claimed that nobody else had EVER had that problem. 2 years down the track though, and i've discovered that mine turns itself on at random intervals, and floods the kitchen bench. My advice - get a refund while you still can...
Mar 03, 2010 | Tefal Kitchen Appliances - Others
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Tefal Express 1750 has water dripping from it when using steam
That means that water is not heated properly and does not produce steam.
Try a complete descaling, often this happens because the water reservoir and heating element is covered with scale.
Feb 17, 2009 | Tefal Irons
Tefal Quick Cup
ALERT :- Tefal Quick Cup can TURN IT SELF ON. Tefal know about this but it is a potential fire hazard. Mine turned itself on and dispensed the water reservoir over my kitchen. Dread to think if I had been out shopping what could have happened. Tefal know about this problem but are not doing anything to advertise the fault!!
Jan 19, 2009 | Kitchen Appliances - Others
Tefal quick cup - descaling problem
Push red and black for 5 seconds to lunch descale then unit resets light at end oy cycle
Hampshireman
Feb 25, 2008 | Kitchen Appliances - Others
Braun Aromaster 10 coffee maker
time to descale the machine not with vinegar but with descaler product 1part descaler 1 part descaler fill the water tank put machine on for few minute stop it for few minute start untill empty rinse very good a few water container and that it if our coffee does not stay warm after that at the bottom of machineinside check the element contactsometime the contact overheat they get some corosion on less power go trus them = less heat i say not to use vinegar vinegar remove calcium in little piese you might block the machine descaler melt calcium thanks for using fixya pierre
Feb 04, 2008 | Coffee Makers & Espresso Machines
Saeco Royal Digital won't brew coffee
normaly descale it gonna affect the water . in the waste cointainer do you have coffee that goes there i tink the brewer is the problem the pvc thing inside the machine that can be remove .remove check it visualy something blocking it cheers
Jan 11, 2008 | Saeco Royal Professional Espresso Machine
Heating & Cooling Logo
104 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
