AP position error will trigger the 6A00 error code. An error occurred in the AP motor during purging operation. As per service manual, you will need to replace the sheet feed unit, logic board assy and purge unit.
AP position error will trigger a 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board ***'y (QM2-3078), Purge unit (QM2-2925).
AP position error causes the 6A00 error code. An error occurred in the AP motor during purging operation. You will need to replace the Sheet feed unit (QM2-2916), Logic board assy (QM2-3078), Purge unit (QM2-2925).
Hello, AP position error [6A00] means that an error occurred in the AP motor during purging operation. The fault part may be: - Sheet feed unit (QM2-2916) - Logic board ***'y (QM2-3078)*1 - Purge unit (QM2-2925)
you better contact a tech because it is not that simple to fix if you have no tech expirience.
Chek toner for Flashing AP Error C400 polygon motor synchronization problem 1. poor contact in polygon motor connector terminals 2. defective polygon motor 3. defective power supply board or main pcb
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
