Question about Maytag Neptune FAV6800AW Top Load Washer
Maytag neptune washer
Washing machine wont unlock on the right side.I reset it but
it still has the light that says its locked even when both sides are in the
unlocked position.
  • Jordan Crosby
    Jordan Crosby Jan 16, 2014
    i just had this same problem! i fixed it by unplugging the washer, lifting the top and removing the screw holing the lock in place. then unplugged the lock and popped all the tabs and pulled it apart. it looked like some softner had gotten into the mechanism. all the little parts popped out but be careful, there are small wires comming off the coils you CANT break. then once all apart i cleaned it as best i can and scored all the copper parts to make sure there was a good connection. put it all back together and it worked. you can try that. only took about a half hour total. BE CAREFUL when your cleaning it though.
  • 96 Answers
The lid lock is on the right side but the switch that senses if the lid is locked is on the left side. Could be that the sensing switch is loose or faulty. You could try to bypass it BUT only to see if that is the problem. NEVER leave it in the bypassed position.
Posted on Jun 25, 2008
Eratic, sometimes door lock doesnt activate, when it does wahser starts but stop mid cycle and wont continue. Replaced door switch and pump
Repair needed on Maytag Neptune washer - Home Improvement ...
www.dslreports.com > ... > Home Improvement
DSLReports
Aug 5, 2007 - 19 posts - ‎8 authors
Forum discussion: We have a Maytag Neptune front-loader washing machine that ...the drain/spin cycle after a wash even though the timer continues to ... related circuit board failure" their Neptune washer will lock the door, turn on the ... then will either not start tumbling or will stop operation mid-spin cycle.
How To Fix A Washing Machine That Is Not Spinning or ...
removeandreplace.com/.../washing-machine-or-washer-dryer-is-not-spin...
May 13, 2013 - The absolute first thing to do to your washing machine that will notspin or drain (whether it. ... I was so fed up with the machine sometimes refusing to spin or drain the .... I just did a load and it stopped midcycle with e and f error codes.... I tried different cycles but all that happens is the door lock engages ...
Maytag Washer Troubleshooting - YouTube
Dec 02, 2015 | Maytag Washing Machines
Maytag neptune tl...shows op code but the lid is closed and locked and will not unlock.
my he maytag makes a squeaking noise and it wont fill up. could there be a sock stuck in there or something. and the lock wont lock.
Oct 26, 2013 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune TL, it won't unlock and still shows 22 minutes left to wash...I just would like to get in unlocked for now, and take my clothes out...Thanks you!
If the Lid Locks won't release you can release the Washer top from the base. You need a putty knife and press in to release the.
Un plug the washer from the 120VAC outlet.
Insert a plastic putty knife in line with the lid seam and
push in to release catches on the left and right side.
Yhe top cover is hinged at the rear.
See Pic fpr putty knife insertion point;
Ypu can get the Service Manual for here Neptune TL Washer FAV6800AWW
5 post doen in the sticky.
Apr 03, 2011 | Maytag Neptune FAV6800AW Top Load Washer
The doorlock will not unlock. how do i reset it.
unplug washer,remove lower panel,put hand behind rear of front panel on right side and pull a small level while opening the door.
Feb 09, 2011 | Maytag MAH6700AWW Neptune Front-Load...
My maytag neptune is locked... will not start... will not unlock... code nd??? can you help.. i tryed to unplug. reset . nothing
To unlock the door, follow these instructions: 1) unplug the power cord 2) shut off all water connections and remove hoses from source.
3) unscrew the metal access panel on the back side of the touch pad console on the back/top of the unit.
4) unplug the white, three pin connector(red, blue, & yellow wires that are in this order from left-to-right when looking from the back of the washer to the front)
5) plug the power cord into the wall receptacle
6) press the "delicates" & "heavy soil" buttons at the same time for 3 seconds(this puts the unit into the "service mode"
7) press the "extra rinse" button(this will UNLOCK the door Note: I am sending this to MAYTAG as well, although they and their lousy service system and their authorized service affiliates would not even think of offering such emergency help on any web site ....xkellyx
Nov 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
Wont complete the cycle reads Lr how do i unlock the door
maytag had many problems with this issue. "Lr" is a locked rotor in the motor. there is actually a motor control conversion kit maytag put out to fix this issue. And depending on the series number (first to numbers in the serial #) of your washer, there is a 10 year warranty for this kit. the kit is a new dc motor, motor control board, and harness. you should call maytag to see if you machine qualifies for this, the kits are expensive if you have to buy it. if you door wont unlock, and you need to get cloths out, open the lid for the detergent. look on the right side and the front inside where you put detergent in. you will see a green or red cord, that is the door lock release. if you pull on it, it will unlock the door, just dont pull to hard. good luck, shane
Sep 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Bleach wont drain during washing
You may have a clog on that side where the water comes into it, or the dispenser valve is not opening that side.
There is a service sheet inside the bottom of that front lower access panel on the right side wall, you can go through the diagnostics to test the water flow to that side of the tray.
Feb 13, 2009 | Maytag Neptune MAH5500B Front Load Washer
Top load washer
1. Remove top. 2. remove left side lock accuator. 3. open accuator case. 4. Solder small broken wire back to diode. 4. reassemble 5. enjoy.
Oct 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
MAYTAG NEPTUNE TL WASHER
If you are not getting any error codes pertaining to the door lock and you are getting wash and rinse then the problem would seem to be that the water is not draining. Machine will not go into SPIN if the pressure switch senses that there is still water in the basket.
Jun 04, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Front load washer
LO means bad door lock switch or conrtol board. to get it open unlock manually by pulling plastic cable located in dispenser where soap is put in.
Oct 29, 2007 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune FAV6800AW Top Load Washer Logo
620 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
