Question about Dometic Rooftop RV Air Conditioner
The unit worked fine last year but now the compressor will not start and after as short while either the generator breaker or the panel breaker will trip. I do hear a relay clicking at the unit when I turn it on at the thermostat.
  • brandonlee Jul 07, 2008
    the fuse blows whether unit is turned on or not. it blows as soon as the breaker is turned on. what could it be?
  • 95 Answers
Possible bad capasitor, or seized motor
Posted on Jun 25, 2008
Sometimes it runs fine and sometimes it overloads my generator
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The compressor is not starting right every time....the problem is probably the start capacitor for the compressor...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 09, 2010 | Dometic Rooftop RV Air Conditioner
It worked fine last year. This year it throws the breaker on the gen. After 2 or 3 min. The fan works on low and high but it trips on low or high ac its a model 6759c707
If all is the same as when it ran good, such as same power cord (no extension, or properly sized extension ) same generator output voltage etc, then I'd check amp draw when compressor kicks in. Good chance compressor start capacitor may be faulty.
Jun 26, 2010 | Dometic Rooftop RV Air Conditioner
Dometic rv air conditioner well not run
unfortunately this is generally a sign the compressor is bad. Not always, but generally. the compressor needs to be isolated and checked for shorts to ground. (it could also be another component or wiring issue that has shorted the unit to ground causing the breaker to trip.
Jul 31, 2009 | Dometic Rooftop RV Air Conditioner
Compressor won't kick off
What happens when started in just fan mode? Sounds like relay stuck.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
RV A/C COMPRESSOR RUNS CONSTANTLY
You must isolate the problem by disconnecting the thermostat wires that go to the unit. If the compressor does not run when the t-stat wires are disconnected, that shows that the t-stat is malfunctioning, or there is a short in the wiring between the t-stat and the ac unit.
If the unit continues to run after disconnecting the t-stat wires, then you'll have to look in the unit for a stuck relay
Jun 11, 2009 | Dometic Rooftop RV Air Conditioner
Brisk air, dometic rv a/c unit I can't get the compressor to start,when I turn it on it bogs down & won't start.It draws so much juice it stops my generator.
you must check the amp draw with a meter to verify if the compressor is locked up. if it draws L.R.A. amps which should be listed on the compressor it is lock up and needs replaced.
Phil
Jun 10, 2009 | Dometic Rooftop RV Air Conditioner
Compressor will not come on. Fan runs great.
I fixed it. I had a dirty connection on the starter relay for the compressor. Thanks again for the help.
May 17, 2009 | Dometic Rooftop RV Air Conditioner
Circuit Breaker and Dometic Rooftop RV Air
Its the watts you plug in too like ither 30 watts vs 50 watts. 30 watts will cause your wires to get hot in the unit. just pull down your breaker box and look at those white ground wires.
Jul 20, 2008 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
523 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
mike cooper
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
