Question about Nikon D40x Digital Camera
Picture is always black
When I try to take a photo, the lens focuses appropriately and the shutter sounds, but the image which shows up on the camera is never there. I have tried hooking it up to the computer to see if there is an issue with the screen, but there isn't.
  • 1 more comment
  • bergench Jun 23, 2008
    Yup. Once upon a time the camera worked great. Also to clarify a bit on the problem, i realized after fussing with it a great deal that it picks up very bright images, such as when i take a picture of a turned on lamp. Even at that however, the image is darker than it should be by a lot. Thank you so much for any advice you can give me!
  • bergench Jun 24, 2008
    i have a can of compressed air but no idea where the sensor is.
  • Tim Babcock
    Tim Babcock May 11, 2010
    Is there a picture on the memory card?
I have the same problem.
Posted on Jul 02, 2008
  • 2,794 Answers
It could be that the sensor might be blocked or dirty. Do you have a way of cleaning those?
Posted on Jun 24, 2008
How do I use my old manual lense with a K200D?
Move the automatic/manual focus switch (on the lower right of the lens mount as you look into the lens) to manual. Focus manually by turning the focus adjustment on the lens itself - align the split image as you would with your old camera and take the picture.
(Use a handheld light meter and set the f/stop and shutter speed appropriately - the K200D doesn't have a visible meter. I would recommend bracketing your exposures -up a stop and down a stop from the 'appropriate' stop.)
Aug 11, 2013 | Pentax K200D Digital Camera with 18-55mm...
My Nikon d3100 only takes black photo's when the lens finder is working but the lcd is showing a black screen but still has icons so what is wrong?
sounds very much like a CCD unit failure. This will require another trip back for repairs and now that it is out of warranty it is going to cost plenty.
Jan 24, 2013 | Nikon D3100 Digital Camera
Camera not displaying images as seen through viewfinder. The screen is black. Image controls and info can be seen but the picture is just black. Takes photos which are also black; but previous photos...
A stuck shutter is another common failure mode for digital cameras, particularly for the SD1000. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife's SD1000 also has this problem every once in a while. I easily fix it by using the following steps from the link: powering on the camera, opening and closing the battery door, and flicking the end of the lens barrel with my fingertip (or you can tap it with a pencil as discussed in the link).
Feb 06, 2011 | Canon PowerShot SD1000 Digital Camera
I dropped my camera and since then I can take photos, the camera focuses, my display is fine when viewing previously shot images and the normal display information but when the shutter is pressed all o see...
When you take off the lens and fire off a shot, does the mirror go up and return or does it stay up? If not, is it possible that it is staying up when the lens is connected? When you fire a shot, can you hear it returning?
Sep 19, 2010 | Canon EOS 400D / Rebel XTi Digital Camera
Lens won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Dec 07, 2009 | Canon PowerShot S2 IS Digital Camera
Virtual tour
the picture is blurry due to lack of focus in the lens.
Im using a fish eye lens. my f\stop is 6.3 shutter is 30.
Im trying to due a virtual tour of my kitchen so its a big picture that i want all in focus. i have tried different settings on my camera but i think im making it worse.
Feb 07, 2008 | Nikon D70s Body Only Digital Camera
AF will not work, manual shots do not show up on CF card
Your shutter curtain is broken. Shutter mechanism last for around 5000 shots, you need professional service to fix it.
Sep 05, 2007 | Canon Rebel XT / EOS 350D Digital Camera
Black screen
It sounds like the shutter mechanism in your lens has stuck closed. This mechanism blocks out the light when you push the button to take a picture, allowing the image sensor to record what it saw just at that moment. If the shutter sticks closed then the image is always dark. You can see the shutter when it is closed from the outside, this is probably what you see when looking into your lens. Fixing this problem generally requires complete disassembly of the camera body and lens to reset the malfunctioning elements. Check with your manufacturer for recalls or technical bulletins, and see if they will fix it under your warranty. If this does not work out you can find good service providers online who can work on your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Sanyo Xacti E6 Digital Camera
When powered up, "Remove lens cover, press button"
The symptom of "remove lens cover" always showing can be caused by two different things. If the lens assembly has become jammed and will not move when the camera tries to extend it - this can cause the message. On some cameras a stuck-closed shutter can cause this message as well. The symptom you describe of seeing two images prior to the failure is strange. I cannot make any kind of conclusion from that information without further elaboration. Does the lens extend when you turn the power on? If not the lens is jammed. Do you see nothing but black all the time on the screen and the captured photos? If so the shutter is stuck closed. Either of these problems will require complete disassembly and re-setting of the lens elements. Check with your manufacturer and see if they will fix it under warranty. If not, there are service providers available on the internet who can service your camera. David Millier Advance Camera Repair
Feb 27, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Camera seems to operate, won't record photos
there are two possible causes for the problem. 1). a bad CCD or 2) shutter not working. in both the cases you have to contact pro. repairer to fix the problem.
Sep 11, 2006 | Sony Cyber-Shot DSC-P92 Digital Camera
Nikon D40x Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
