Question about Sony PlayStation Portable (PSP) Console
Psp if it boots has no mac try to do anything invalid region error
My PsP 2001 is acting strang sometimes white screen with green letters sometimes it shakes like an old monitor or set to 75hz or too high res i tried everything do you have any ideas
  • 34 Answers
Try downgrading and upgrading to your current version. If it doesn't work then try to sell your piece of junk(even though i have that same piece of junk :p) and get a slim which is actually worth getting right now.
Posted on Jun 30, 2008
PSP E1000/STREET WHITE SCREEN
i have also the same problem with psp e1003. what is the connection of white display to the UMD, that the problem is with the lcd
Aug 09, 2012 | Sony PlayStation Portable (PSP) Console
Psp green light on, but no booting or anything. its not a fault of Software... its Hardware for Sure! any help?
Hello
If the green light comes on, but the unit won't power up, you could have a battery problem.
Clean out the battery compartment. Use a can of compressed air to remove dust, hair and other debris. If you left the battery in while you stored the unit, look around the connectors for any sign of corrosion that could be affecting the connection.
Plug the PSP into the power adapter with the battery still inside. If this doesn't work, remove the battery and see if the PSP powers on with the adapter only. If it does, then the battery likely needs to be replaced.
Boot the unit in recovery mode. The PlayStation Portable is like a small computer with a tiny hard drive. And just like a computer, sometimes it gets scrambled; booting in recovery mode can help you identify or correct the problem.
Determine if your PSP has been "bricked." If the PSP was turned off for any reason during a firmware update, it can cause "bricking," so named because it renders your PSP into a useless, plastic brick. Buying a new PSP or sending yours to Sony for repair are your only options if this has occurred.
Jun 10, 2011 | Video Game Consoles & Games
When i switch on the psp,the power led(green led is seen,but nothin is seen,and when i try to switch off the psp the green light stays as it is and only removing the battery will turn the psp off..soo is...
have you tryed to put the main power cord in and see if it will boot as normal ?
some people have modded psp and there battery could be a parnora battery need for modding psp that will give you the green power light and blank screen
also take out any memery stick
and try
what is your firmeare numbers / letters ?
Sep 29, 2009 | Sony PlayStation Portable (PSP) Console
How do i change the region code setting on my psp ?
I believe it is your converter that is the problem. Try PSP Video 9, it works and it's free.
Dec 24, 2008 | Sony PlayStation Portable (PSP) Console
Psp umd reader spins and lazer activates and tries but no game/movie is recognized on screen
Download this Pandora Deluxe 1.2
And this 4.01 official firmware
Open the Pandora Deluxe 1.2 and install.
Unrar the 4.01 official firmware and place the EBOOT.PBP in a folder on your desktop named 4.01.
Connect your PSP and enable USB. Start the Pandora Deluxe 1.2 program, while it is starting it will ask you if a certain drive letter is your PSP, make sure it is correct and click ok.
Click on the "Load 4.01 firmware" button and it will ask for the location of it. Find the 4.01 folder on your desktop, double click it and it will show EBOOT.PBP, select it and clickk OK. Then check the install box next to it. In the colum to the right select "Despertar Cementerio v7 (4.01m33-2)". Now just below that in the center is a drop down box with DCv7 next to it, drop the box down and select LEFT. In the box right below it check Format + Prepare Memory Stick, If you need to backup your memory stick select it. Make sure that the PSP Drive letter is correct and when you are ready to start press START.
When the operation is complete, disable the USB, disconnect the PSP and turn off. Remove the battery. Hold down the LEFT Trigger while inserting the PANDORA battery and continue to hold until the menu comes up.
Select NAND operations, then IDStorage tools. In that follow the prompts on the screen. Select your region, then turn on wifi switch and pres x to Get Real Mac and continue on till finished.
Oct 02, 2008 | Sony PlayStation Portable (PSP) Console
Sony psp
your sons psp is bricked download this and follow what i say Pandora Deluxe 1.2 and this 4.01 official firmware
Connect your
Sep 29, 2008 | Video Game Consoles & Games
I have a sony 2001 PSP, and I've had it for less than a month and just recently I tried to use it, when i attempt to turn it on I press the power button and the green light (which shows that the PSP is on)...
For how long have you NOT been using your PSP? and did anything happen before you even tried using it AGAIN? Do you have others in your area who has a PSP? if nothing happened to your psp before you tried using it again e.g.accidentally fell or something like that, then just try to use a different WORKING psp battery...if it didn't work, then prolly your PSP went brick and the only solution for that is a pandora kit...
Jul 22, 2008 | Sony PlayStation Portable (PSP) Console
Region code
YOU DO NOT NEED TO CHANGE YOUR REGION CODE
PSP'S ARE REGION FREE
I BROUGHT SOME GAMES FROM CANAda and i livE IN THE UK
THEY WORK PERFECT
Jul 02, 2008 | Sony PlayStation Portable (PSP) Console
Power problems
Hi Gohan102,
Open the battery compartment, and remove the battery.  Look at the bottom inside corner for a little square sticker with has marks on it. is it dark or light,  If it is dark, your PSP has come in contact with moisture. I suspect that your PSP has gotten wet or damp.  If the sticker is dark, you need to keep your battery out for about 2 days, and keep the UMD door open and the whole PSP kept in a dry environment.  Try it after 2 days of drying to see if it is recovered. Good luck Gohan....
Oct 17, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
48 people viewed this question
Top Sony Video Game Consoles & Games Experts
Iron
Iron
Troy Gorman
Troy Gorman
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
