Intermittent crackling picture and sound - Televison & Video
  • handipop530 Jun 22, 2008
    With out climbing up on the roof to check the antennae, how can I check the input??
  • 6,487 Answers
If you're experiecing this on all channels try checking first the connection of the antenna on the back of your TV and make sure its connected properly and also try moving the antenna on a different direction to avoid signal distorsion.....
Hope that helps.....
Posted on Jun 22, 2008
    Brigadier General:
  • 3,614 Answers
Did you experienced this on all of the channels on your TV...?
    Master:
  • 638 Answers
Check out the bulged up capacitors on the main board if there is any replace it.it is also possible that some ICs get overheated n stops responding.
for all detailed information n step by step troubleshooting link is given below:
http://www.ptdoityourself.net/tl/tl_index1.html#8ab
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
    Guru:
  • 1,894 Answers
Look for the connections and cables as merlin said
also try a different connector that connects the TV from source
also try using a stabilizer for proper power supply
also if this is not a external it can be due to any internal problems in power board
  • 13,433 Answers
Can you be more spesific.
  • 197 Answers
Well..that's most likely due to a problem with the input for the whole system. check your cables for any wear or bad connectors
Vox ac30cc2x fault finding
Check valve you replaced has made proper contact in socket. Plug it in and out a few times to clean pins. Is inteference/crackling noise there when volume is turned down to minimum. This should tell you whether the problem lies before or after the volume control. A good clean can solve many faults. Servisol on pots works wonders.
Ian
Jul 24, 2012 | Radio Communications
Everything I watch on the N150 crackles even after I adjusted sound settings. Is it broken?
It sounds like the speaker connection is intermittent.
Try it on a headset to see if it is still the same.
Apr 03, 2011 | Samsung N150 (36725723009) Netbook
LG 37LC2D HDMI no signal (picture or sound) + crackling on audio
i have the same problem. i think they just get old, i solved the audio problem by taking the cove off the back and disconnecting the speakers, i now just use PC speakers, works grand. i haven't solved the HDMI problem yet..
Apr 29, 2010 | LG 37LC2D Television
Intermittent crackling sounds DPR 1005
This is an obvious thermal problem. Use circuit cooler to isolate the bad part. It could also be a crack in a circuit board.
Alternate warming with hair dryer and cooling one component at a time while listening for the noise.
Feb 16, 2010 | Harman Kardon DPR 1005 Receiver
Screeching/crackling coming from amp
Could be just a bad solder joint somewhere!
Jan 22, 2010 | Audio Players & Recorders
Short crackle sound emits from speaker during scene changes
Actually, it is a failing component. Quick scene changes often place demands on the power supply. I would guess that the noise is more prevelant when the scenes change from darker ones to lighter ones. Since this set is so new, request a warranty exchange. This set needs to be serviced. Return it to the place of purchase and ask for a replacement. Usually if the set is less than 30 days old, they just exchange it for you.
Dan
Oct 08, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Technics SU-G95 Amplifier, Intermittent popping/crackling noise
The heat sink has the power modules attached but also has 2 power transistors that become disconnected from the circuit board when the heat sink moves or flexes. The pins on each need to be resoldered (it helps to bend them a bit too, prior to soldering). Had the same problem on the same amp today and that was the fix. There was no sound other than a clicking when the volume control was rotated.
Jun 09, 2009 | Audio Players & Recorders
Crackling Sound
I just bought a used 60 inch rear projection tv. The picture is fine except I have a crackling sound coming from the front of the tv also. What's the deal?
Jan 16, 2008 | LG RU-44SZ51D 44" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
