Question about Toshiba Qosmio F45-AV412 Notebook
Burning cd's/dvds every time i insert a brand new disc no scratches or anything, it ejects the disc without burning. i don't know whats wrong never did this before used to always burn the cd then eject. plz help
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 168 Answers
Are you using the same brand of disc? sometimes they can be pretty finicky
Posted on Sep 13, 2009
Cd's appear to burn but do not play
change your burn software and file formats /if there are music files/
Apr 24, 2012 | Dell (1G055) CD-RW/DVD-ROM (Combo) Burner
I have successfully put the music from Vinyl into the machine but when I want to burn the disc it says: Initialising. Nothing happens after 20 mins. or more. What am I doing wrong. Nothing in the...
Used a good CD to burn Check the CD for any possible scratch...that also a problem Try to insert a good CD and play to check if the CDROM/DVDROM is ok If the CDROM is play...suspect the CD you inserted is bad Cd with many scratch on it or unreformatted CD
Buy new good CD...don't forget to check any scratch
Sep 23, 2011 | Audio Players & Recorders
The laptop burned a disc, then ejected as usual. Another disc was place in the tray, inserted as normal but this time a cd was unable to be burned because the laptop did not recognize the disc or any other...
The automatic ejection takes place when the burn process has completed successfully. Have your tried another writable CD or DVD? If your laptop is not recognizing any more writable CDs/DVDs, then the problem might be a failed CD/DVD drive. Otherwise, it is probably a bad CD or DVD.
Hope this helps.
May 26, 2011 | Computers & Internet
The in dash CD player accepts a disc but does not play. It will show track number but it's stuck on 00:00 then it sim0ply ejects the disc. What could be wrong?
i know this may sound dumb but did you check the cd for scratches or fingerprints?
is this a cd that you burned from the computer? if so is it the correct type and in the correct format..
Sometimes when burning cd's on the computer depending on what software you are using if the bitrate is set to high (above 128Kbps) then the cd will not play on normal cd player
Also when burning cds on the computer the session must be closed completely before it can be played on a regular cd player
Try a brand new store bought type cd and see if it works if it still does not play then it is possible that the laser has somehow become "out of alignment" and that is too difficult to fix and better to be replaced
But by your description it sounds more like the cd is dirty or scratched
It is also possible that the stereo is wore out or malfunctioning
hope this info helps
May 20, 2011 | Car Audio & Video
DVD will not play just get a blue plus sign coming down the display after th DVD sign graphic. TV screen shows digital and no disc. Any ideas lease?
is it a burned disk? if so your dvd player might not be able to play that type of dvd... i know sometimes also scratched ones won't play at all as well... of course also make sure everything is plugged in correctly and if it does this with more different dvds then there's something wrong with the player itself... which i hope is not the case as those are very difficult to fix yourself
Jan 13, 2010 | Samsung HT-X200 Theater System
WRONG DISC ERROR WHEN PLAYING A DVD
HI,. this is a lens assembly fault. the lens is malfunctioning or, it may have stopped reading. this wrong disc code is just a universal warning that is concerning a fault if the main board doesn't receive any data(audio,video) when the disc is inserted.
Due to the integrated status of your unit, this will be a costly repair because, the entire assembly is combined together with the vcr section as well.
You will need to replace the entire assembly to fix this issue. the lens has burned out.
you can confirm my diagnosis by preforming a cleaning of the lens with a cleaning disc. if the unit continues to not read or play a CD after the cleaning, this will confirm my diagnosis.
Please rate and have a great day:)
May 23, 2009 | Bush DVD142RC 14 in. TV/DVD Combo
My dvd burner wont burn dvd's it says insert a blank disc and it is already in the burner
try 3 things. ONE AT A TIME. #1 change your burn speed to a slower setting some dvd's will not burn as fast as they say on box.
#2.update firm ware for burner go to manufacturer's web site for your brand of dvds being used.
#3 change brand of DVD used. there are 3 major manufactures for almost all dvds and cd. The people who make disc for Sony and the other 2 companies that make everybody elses. (ie TDK,Memorex, etc....)
Oct 06, 2008 | NEC ND-3540A DVD RW Dual Layer Burner
Burning problem
Try different brand. Your Drive is a sensitive type and it only accepts some DVD-R brands. Also try DVD-RW disc. I had the same problem but not specifically the exact problem. My drive is cd writer only. Same problem, I just used diff CD-R brand like Imation and Philips and the burning works like a charm.
Jul 26, 2008 | Lite On LITE-ON SOHC-5236V COMBO BK OEM...
I am trying to burn photos from my easy share. When I press the burn cd tab the computor ejects the dc and the message is please insert a recordable dd. I am using brand new memorex printable dc-r. What...
if you have made a bad burn the first time you can't use the cd again.
because you have bought cd-r. if you buy cd-rw you can burn over and over one the same disk.
CS.
May 18, 2008 | Computers & Internet
Rpd 552 cd reader problem
Message Possible cause Recommended action
E-01 Dirty disc. Clean the disc.
Scratched disc. Replace the disc.
Up-side-down. Check the disc.
E-02 Focus error. Try ejecting and re-inserting
under normal temperature
conditions.
E-03 Data and focus error. Under normal temperature
conditions, eject and
insert clean, undamaged
disc properly.
E-04 Mechanical problem. Eject and re-insert.
Oct 17, 2007 | Blaupunkt RPD 552 CD Player
Toshiba Qosmio F45-AV412 Notebook Logo
128 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
