SOURCE: i forget my nokia 3120 classic mobile security code so how can i
IMEI(International Mobile Equipment Identity) needed to get you the master code.The imei number is a 15 digit number and with that I can provide you the master code which acts as security/master code.
THE MASTER CODE HAS TO BE TYPED 3 TIMES ONLY , SO BE AWARE.
The master code can be typed as security code,when the phone asks for code.
The pin number is different from this master code,since it is attached SIM(subscriber identity module) card
"OR"
"Give it to the Nokia care centre,they will clear it in 5 minutes(without asking any questions to you)"
SOURCE: I forget restore security code
dear your mobile 3120 fall in bb5 category so mastercode will not work for it.i would suggest 1)download nokia flash tools http://www.mediafire.com/?mudeyqowwc5r868 .install nokia pc suit7.1.extract the folder you downloaded. then frst install jaf setup and then copy nok4model.ini and ogm pkey to the jaf installation folder.ope ogm and hit the go button.select bb5.swicth off the mobile connect it to the pc.select read pm click on sevice button.slightly push the power on of mobile.pm reading will start open pm file go to 308 block and in the 5th line you will see your security cod
