Question about JVC GR-D350 Mini DV Digital Camcorder
Can't connect my JVC camcorder to my PC
Hi there, I have a JVC GZ-MG50AG 30Gb camcorder. I have had it for about 3 years and so far no problems. Until today. I connected to my PC with a USB cable and the PC recognises an external hard disk for about 2 seconds then the connection drops. It does this repeatedly without making a connection. There is video on the camera that I want to download and then clear it in time for holidays.
Can you help
  • 1 more comment
  • pghc Jun 22, 2008
    Where do I find the driver? And how do I install it? As I said before, the downloading was working fine before but now I can't connect. Can you identify a driver for me?
  • pghc Jun 22, 2008
    I've tried connecting to a laptop as well. But still not connecting.
  • pghc Jun 22, 2008
    I've tried another USB/miniUSB cable but still nothing.
    President:
  • 2,712 Answers
Found this possible solution on a different forum:
"The first action you should take to resolve a USB problem is to disable the Save Power option in the Device Manager for the each of the USB Root Hub entries. Up to five entries called USB Root Hub can appear under Universal Serial Bus controllers. Open the Device Manager by entering devmgmt.msc in the Start => Start Search box. Open each of the USB Root HubSave Power option under the Power Management tab by removing the check mark that enables it.
entries and disable the This can also happen when a USB device is drawing power close to the maximum limit for USB connections. Many laptop computers don't provide enough power for the most demanding devices.
Simply disconnecting and then plugging the device in again often works. You could also try connecting a device that uses less power, such as a USB modem, and then connect the camera while the other device is still connected. Doing that seems to make the USB bus ready to receive the more demanding device.
If none of those solutions work, try connecting the camera through a self-powered USB hub that provides several USB ports by connecting to one of them on the computer. Buy only a high-quality brand-name USB hub, such as the Belkin Hi-Speed USB2 4-Port Hub, because cheap hubs can themselves be a source of problems."
If you are using Vista, you may wish to read this article as well:
http://www.thedave.ca/wordpress/index.php/2008/01/05/windows-vista-usb-device-detection-problems/
Hope that helps!
Posted on Jun 22, 2008
    Genius:
  • 1,665 Answers
It may be only a cable problem with your computer.
Have a look at reviews below
http://www.retrevo.com/samples/JVC-Camcorders.html
    Genius:
  • 3,422 Answers
HI,
Did you try connecting this on a different PC and let me know how it goes.You can also try connecting this via firewire cable if you have a firewire card in your PC.The drivers for this model are not available anywhere for download.But i suggest you to contact JVC and tell them to email you the download link for the drivers of your model.Below are the contact details.
Main support number(800) 252-5722
Email supportproinfo@jvc.com
If you need anymore help let me know.
Please don't forget tor ate or accept the solution.
    Master:
  • 638 Answers
Many Camcorder users have faced problems while connecting
their camcorder to their PC. One of the most common problems is ?no activity? after connecting the camcorder to the PC. The found new hardware wizard does not run and fails to detect the camcorder.
This can mean two things. Either the DV port on the Camcorder
is not working or the FireWire cable is faulty. Try using a different FireWire cable. If the camera is still not detected by the PC, try connecting it to a different PC. If the Camcorder is still not detected, then your camcorders DV port is most likely at fault.
Confirming that the FireWire Port on you PC is working fine You can check the status of the FireWire port from under Device Manager. To access the Device Manager, Right Click on My Computer and then click on Properties. Select the Hardware tab and click on Device Manager. If you cannot see the FireWire port in the list, then it is not inserted properly into the motherboard. If you see a Yellow exclamation mark, then you need to install the drivers, which are usually bundled with a Floppy or CD with the FireWire card.
    Brigadier General:
  • 3,614 Answers
Your dv camcorder needs a firewire connection (ieee 1394) in order to download video to your PC if your computer (PC) did not come with a firewire port, so you will have to buy one and install it, & if your camcorder did not come with a firewire cord so you have to purchase a cord too.
Your camcorder has only a USB cord and that is used for downloading stills from your camcorder, when capturing video just make sure your camera is in playback mode.
Hope this initial info helps you solve your problem...
Kindly rate my solution if this one solve your problem..
Regards,
-micro
    Genius:
  • 1,036 Answers
Please ensure the leads and connectors are not worn, and working correctly.
If the conections are poor, it may recognise the unit, but fail to transfer data.
  • 6,487 Answers
Try using another USB cable just to make sure that its not a cable problem, if its still the same problem if you're using a memory card on that camera try putting that card on a card reader and that way you can get the file that you need..
Hope thta helps...
  • Mark Gil
    Mark Gil Jun 22, 2008
    Don't also forget making sure your battery is full and cable are properly conencted sicne the camera was detected earlier..
  • Mark Gil
    Does your camera has memory card on it?? if YES better take the memory card out and put it on a card reader and that way you can get the save files on it...
    Guru:
  • 1,894 Answers
For time being i would suggest u to use the a friends computer to transfer the media to some device
  • dewan nafees ahmed Jun 22, 2008
    since u said u were downloading fine before few days
    u must be having the drivers in the CD given along with you and u can use the same for re installation
    that clearly states that problem is not with drivers and ur computer.
    PROBLEM IS WITH YOUR CAMERA
    so i would suggest you to make sure if unit is having full charge.
    also try using a different battery
    it can be the low battery issue mostly.
    but please do the step by step trouble shooting
  • JVC Master
  • 13,433 Answers
Try another usb port for example in the back. Also you can attempt to connect the camera to another computer.
  • Ekse Jun 22, 2008
    Please comment back / reply.
    Thank you,
    Ekse
  • Ekse Jun 22, 2008
    ok, do you have the cam connected to a powersource while you connec it to the usb? and it has worked perfectly for the last 3 years? This is startin to sound like a hardware issue, might need service.
  • JVC Master
  • 19,396 Answers
You need to install the drivers BEFORE connecting pc to camcorder
  • Ginko
    Ginko Jun 22, 2008
    If drivers were already working on this pc then it is either a cable problem, a problem with the pc, or a low battery problem, it is unlikely that you have a problem with the camera.
    Try first disconnecting usb and power cable from pc for ten minutes or so, also remove batteries from camera for a while. Then connect everything back and try again. This will solve eventual troubles from electrostatic charges on usb.
    Test a new cable.
    Check that you have enough power on camera batteries.
    If it is none of the above it may be a problem with Windows, test camera on a different computer to verify.
    Regards
SHOWING A HDD ERROR, HOW TO FIX ERROR?
Go to functions and reformat the hard drive. If problem persists you may need a new HDD.
Mar 24, 2016 | JVC Everio Gz-mg37 30gb Hdd Digital Media...
How do [ clear the hard disk error from my camcorder jvc everio hybrid
in the main menu you can format the HDD, if not possible take out the HDD connect with a dock to your computer, format it.
Nov 27, 2015 | JVC Everio Gz-mg130 30gb Hdd Camcorder...
What is the maximum SD capacity that jvc everio gz mg57 can support?
You may use any size SD card. Bear in mind that SD cards only go up to 2GB. This camera will not work with higher-capacity SDHC cards.
Dec 29, 2013 | JVC Everio GZ-MG57 1.3MP 15x 30GB HDD/ SD...
JVC GZ-MG20U
It's definitely an internal problem in your camera and it sounds like you don't have any warranty after 5 years. I don't have a step-by-step help guide for you since I don't know about this camcorder but in my opinion, if the camcorder is really that good, it's worth the repairs. Though HD camcorders are getting cheaper these days...
Jun 29, 2010 | JVC Everio GZ-MG21 Camcorder
I have purchased a jvc camcorder in grand canaria,spain.It is jvc gz-mg330AE.i am led to believe by the sales person that it is a new recent model on the range.Is this so?.Also a more powerful battery...
GZ-MG330 is new series of camcorder with 30GB HDD
Regarding battery, BN-VF808U, if its slim and supplied with camcorder then its OK and other longer life battery must be double then slim battery and of course, model number would be changed.
Click HERE to see 3 different JVC original batteries that will explain it better.
Hope this info will help you to buy extra longer life battery.
Thanks.
Feb 05, 2010 | JVC Cameras
Manual for jvc 30gb hard drive camcorder
Copy and Paste this link in your address bar to view your manual;
www.manualnguide.com/.../manual.../jvc-gz-mg255-everio-hybrid-camcorder-instruction-manual.html
or
camera.manualsonline.com/manuals/.../jvc/hard_disk_camcorder_model_no_gzmg255ugzmg130u.html
Oct 01, 2009 | JVC Everio GZMG255 HDD Camcorder
I cant find the charger to my Everio JVC GZ-MG330HU and wont work
Computer USB output does not provide sufficient power. Look on Ebay, buy a new charger
Jul 31, 2017 | JVC Everio GZ-MG130 Camcorder
Don't know where to find model number
Well, actually, it is only 1 year and 3 months old.
Amazon claims the model number is GZ-MG77US, hope that helps, it doesn't show up on amazon, why do you need to find it on your camcorder anyway; it should at least be on the manual.
Apr 21, 2009 | JVC GZ-MG330 HDD Camcorder
JVC GR-D350 Mini DV Digital Camcorder Logo
229 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
