You have two water solenoid valves, one hot water and one
for cold. If you switch the hot and cold water hose connections the washer may
fill. If it does, the solenoid valve is defective, and you will need to order a
new one and replace it. If you take off the back panel of the washer you can
follow the hose to the solenoid which has wires connected to it. Did you stick a bucket under the water faucet
to make sure water is actually coming out of the faucet when you turn it on?
The problem is the pressure switch has failed or the hose is plugged up, has a hole in it. These are usually inexpensive and are very easy to replace. Here is a video this will walk you thru testing and replacing a pressure switch. You can also enter your model # for diagrams and illustrations of your specific model. All parts come with installation instructions. Not all models are available.
