Question about Coleman Heating & Cooling
COLEMAN A/C mod. 2436-901 compressor motor hummes but doesn't start. need wiring diagram or info. on starting capactor value inforfation in cover has deteriorated.
    Genius:
  • 3,422 Answers
I am sorry to say this but there is no wiring diagram/service manual avaialable anywhere for this model.You can contaact Coleman at their main support no. 877-726-5362 and ask them to email you a copy of service manual.
By the way here is a diagram for your A/C but its not a wiring diagram.Just in case if you want to know about the parts scroll you mouse on the diagram.Please CLICK HERE
Please don't forget to rate or accept the solution.
Posted on Jun 22, 2008
    Master:
  • 638 Answers
Www.repairclinic.com
u will need the step by step instructions with wiring diagrams .the above link will help u solve ur problem completely.wish u success.
sites for additional information:
www.applianceaid.com
appliance.justanswer.com
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • 19,396 Answers
I cannot find your model, and wiring diagrams for Coleman are not easy to get. I think best solution is contacting Coleman and asking a copy of the service manual
How do I reconnect the capacitor?
Not easy to explain. The capacitor is split, it has two values, or like two capacitors connected internally with a center tap between them. Two capacitance values, maybe 5uf and 20uf, the lower value for the fan motor and the higher for the compressor, with terminals C-common, F-fan, M-compressor.
Capacitor terminal C is the center tap and that takes 3 connections, line (power) - fan line common to capacitor, and Compressor line common to capacitor. Notice the fan and compressor have a power line not common to capacitor, just power line.
Capacitor terminal F has one wire connecting to Fan terminal C, fan may have three or four terminal writes, two for power with one power being common to capacitor connection and the other power alone, two power connection wire leads. Fan motor third line is capacitor, connects to the capacitor alone. Four wire configuration fan motor is not likely your needs. Omit or ask again for further explanation.
Compressor is similar to fan, only with a capacitance value higher than for tha fan motor. Two power leads, one straight power, the other power lead connects to the capacitor power. The third compressor lead connects alone to the capacitor.
The with is to draw a diagram and level the colors of each lead and terminal lavels too. The motors nameplate may indicate wire color code, the a-c nameplate wiring diagram may be present in the control wron wiring compartment, the goal is to find clues or to trace each wire and verify what they connect or do, take notes on your drawing.
Basically the motor has three terminals, L1 - L2 - C, or C- S-R (Common, Start,Run)
Jul 14, 2015 | Maytag Heating & Cooling
When my heat comes on , the blower doesn't blow it just mummes. I can turn the fan by hand and it is free. the out side unit is working . Can it be the coil on top of the fan? It a Model EB17B Coleman
It certainly could be the motor capacitor; the oval metal can located on the blower housing.
8fzzjawtltskcaaaaasuvork5cyii=
These are fairly simple to test with a digital meter that measures capacitance. Also, if it is bulged or has a hole blown in it, you know it is bad. These are available at almost any appliance parts store locally or at Grainger.com
It also could be the motor relay (#12 in the manual)
57v4aaaaasuvork5cyii=
You can download the furnace install manual and wiring diagram here:
EB17B
Grainger Industrial Supply MRO Products Equipment Tools
Jan 26, 2015 | Coleman Heating & Cooling
The compressor would not start so I replaced the starter relay and the compressor started and ran for a while but it was really hot. Now it runs til it overheats and the overload shuts it off. The...
what you need to check is for a locked up or very tigh compressor motor bearings, need to use amp clamp and clamp to the wire on overload on compressor the single common pin that is either top or bottom is where the overload goes. Look on plate/sticker on compressor and find what the LRA (locked rotor amp) is and see if amp draw is at or very near at LRA value
Note ;the windings can be good but the compressor can still be locked up
Aug 13, 2011 | Magic Chef MCWC16MCG Wine Cooler
Compressor draws 50 amps on start and drops out? Mod. 700-800 about 10 years old.
Most likely bad motor. 50 amps is way to much at start. Motor locked up.Nameplate may contain LRA rating which stands for locked rotor amps. If you near or above motor is seized.
Aug 19, 2010 | Coleman Mach 15 Air Conditioner
Motor starts sounding normal then after 2-3 seconds stops & just humms.
I suspect the check valve is stuck closed causing excess high pressure in the cylinder and too much load for the motor. The check valve is OFTEN right at the tank where the compressor output line goes into the tank.
Jun 09, 2010 | Coleman Powermate 11 Gallon Air Compressor
A/c won't start
need wiring for conpassor
Jun 29, 2009 | Coleman Mach III Air Conditioner
Need to install power cord to terminals on 220 AC motor
Ok, read the data plate on the motor. Does it have a zero with a line straight through it. That means it's single phase. Also the plate may list two different voltages 110/220ac correct. On the inside of the panel of the box where the cord connects it will have a two diagrams. One marked low voltage, the other high voltage. You want 220ac so follow the high voltage diagram. Since it's single phase the green wire will go to a green screw in the box. The black wire from your cord is positive and the white negitive (actually neutral but shown on diagrams as negitive). The wire coming out of the motor will have numbers on it's casing. Follow the connection points on the diagram. Don't worry if you hook them backwards the motor just won't turn. It won't hurt anything.
Apr 02, 2009 | Coleman Powermate 60 Gallon Air Compressor
Need copy of wiring diagram
There should be a wiring diagram tucked in a pouch under the bottom of the refrigerator.
If the compressor windings show proper resistance, my first guess would be a faulty start relay.
A 3-n-1 start may fix your problem.
This suggestion is "old school". I've been away from it for a few years.
Mar 20, 2009 | Refrigerators
Coleman air compressor
Should be an electrical diagram on the motor. The motor name plate should also indicate if it is a dual voltage motor. There should be a cover on the end of the motor to access the terminals.
Aug 30, 2008 | Hitachi EC12 Portable Electric 2hp Air...
Heating & Cooling Logo
524 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
paulcarew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
