Question about Kenwood Car Audio & Video
I have a KDC 316S unit in my 1992 Eagle Talon. When the unit gets hot, which could be from the car just sitting in the sun, the radio receiver stops working and just emits white noise. Once the unti cools down, it will beging to work again. Only the radio receiver is affected. The CD playback works fine. Would a new face plate solve this (unlikely) or is the receiver part of the fixed in-dash installation?
  • rjmmlm Jun 22, 2008
    Although some capacitors could be involved in this, it would seem that, unless the capacitors are specific to the operation of the radio receiver, this wouldn't be it. This is most likely something in the RF frontend/conversion to base-band. At this point that whatever the problem is, I'm assuming that it is not likely to be caused be something in the removable faceplate(?question here). If I run the AC in the car long enough, eventually the radio will begin to work again.
    Thanks
    Genius:
  • 1,665 Answers
See if your manual below helps (download it)
http://www.nodevice.com/manual/newmans/KDC-316Spdf/get14151.html
Posted on Jun 22, 2008
    Master:
  • 638 Answers
Check out the bulged up capacitors on the main board if there is any replace it.it is also possible that some ICs get overheated n stops responding.
for all detailed information n step by step troubleshooting link is given below:
http://www.ptdoityourself.net/tl/tl_index1.html#8ab
feel free 4 further assistance .rate the particular experts solution as fixya that helps u understand n solve ur problem
  • Kenwood Master
  • 19,396 Answers
One of the ICs inside is overheating, find an authoirized Kenwood service in your area and have it checked
  • Ginko
    Ginko Jun 22, 2008
    Changing the plate should not solve the problem, as this will only affect the controls and the security chipset, in your case the problem is located on the mainboard, inside the stereo.
    Probably there is a defective chipset or even just a burnt capacitor in the tuner area of the board.
I have a 92 Eagle Talon TSI AWD and the fan has started to continuously run after turning off the car. How do I get this to stop?
Unless you have a bad engine temp sender this should happen until the engine reaches the programed temperature.if it causes battery failure than you darn sure need to replace the sender
Nov 01, 2009 | 1992 Eagle Talon
Timing belt 1992 eagle talon
Sorry for the severe delay.
I am personally going back to answer your unanswered question.
I do not know if you still need the answer, but I am going to answer it in case you still do.
Click on the following direct Link. It has the Timing Belt Diagrams that you will need. Plus additional Instruction and Directional Diagrams you should use.
Again my apologies...
Let me know if this helped, or if you have additional information or questions. Feel Free to contact me at FixYa.com!
http://www.2carpros.com/car_repair_information/year/1992/make/eagle/model/talon/1992_eagle_talon_timing_belt_diagram_marks.htm
Oct 26, 2009 | 1992 Eagle Talon
What a yellow house icon mean on the dash board of eagle talon
that is a light that means to put more radiator fluid in the over flow tank
Sep 21, 2009 | 1992 Eagle Talon
I have a 1992 eagle talon tsi im trying to hook up stereo
there is a "remote" wire that turns it on-sounds like you hooked it up to your lights. It needs to be hooked-up to the ignition so your radio turns off and on with the engine. Your power wire can go to the battery if you absolutely can't figure out which 1 it is that old radio used, but the remote wire must be hooked up right to turn it off so you don't leave it on and run the battery down.
Aug 31, 2009 | Car Audio & Video
1992 eagle talon white smoke
check for pcv valve and vent for blockage ,should be vacuum. valve train could be stopped up and not draining down ,or u need a ring job rebuild
Jun 27, 2009 | 1992 Eagle Talon
What is the radio wiring diagram for 1992 eagle talon
1992 Eagle Talon Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/Black
Car Radio Accessory Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Green/White
Car Stereo Dimmer Wire: Black/Yellow
Car Stereo Antenna Trigger Wire: White/Black
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): White/Blue
Left Front Speaker Negative Wire (-): Black/Blue
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Black/Red
Car Audio Rear Speakers Size: 6 1/2′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Positive Wire (+): Yellow/Blue
Left Rear Speaker Negative Wire (-): Gray/Blue
Right Rear Speaker Positive Wire (+): Yellow/Red
Right Rear Speaker Negative Wire (-): Gray/Red
Mar 29, 2009 | 1992 Eagle Talon
Fuel pump relay
I can not say for sure but I found the relay for a similar year car in the trunk behind a small panel.
Jan 30, 2009 | 1992 Eagle Talon
92 eagle talon tsi hard to start
i think mostly its hard to start because its a 92 eagle talon.. might be time to put 'er down.. ;)
Jan 16, 2009 | 1992 Eagle Talon
Car Audio & Video Logo
43 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
