Question about LG Prada KE850 Cellular Phone
Will not switch on!
Was working fine, battery almost full; switched off and now will not switch on again. HELP!!!!!!
  • Anonymous Jun 23, 2008
    phone willl not turn on , when i put it to charge there is no signal showing that the phone is being charged
    Brigadier General:
  • 7,752 Answers
CDMA - YOU WILL NEED TO TAKE THE PHONE AND HAVE IT SERVICE FROM A MOBILE SERVICE CENTER.
GUEST - YOU NEED TO HAVE THE USB CONTACTS CLEAN AND TRY A NEW BATTERY AS WELL
Posted on Jul 09, 2008
02 suburbsn wont crank, full battery power
I had a similar problem with a 1999 Chevy Astro. All fuses checked out good. Several posts advised cleaning the battery terminals, checking out the ECU to cutting the yellow wire from the ignition switch, check to see if it'll crank on Neutral, and also checking/replacing the brake switch. I simply removed several keys from the key ring, then shot several bursts of air from an air can (some keys are keyed to the ECU to turn off the Security System when attempting to start the engine), then waited several minutes for any condensation to dissipate, then was able to crank the engine to life.
Nov 18, 2013 | 2002 Chevrolet Suburban
Uses up battery quickly
If the battery works fine on another tool then the problem is in the tool it doesn't work in. Possible problems:
1. battery contacts on the bottom of the switch may be bent or broken (very common) so the tool isn't getting full voltage from the battery. Check that the four tabs are there and not bent.
2. switch may have bad connections internally, again not getting full power to tool. Switch has to be checked with an ohm meter.
3. shorted wires from switch to motor, worn brushes, or burnt windings on the armature or field. Visual and ohm meter checks need to be done to verify these problems.
Dec 27, 2011 | Dewalt Drills
Hi, I am usinh Nokia N72 from past almost 3 years. It was working fine till 2 months back. It used to get switch off after every 5 mins..automatically. Then, we showed it at Nokia service centre at...
The battery may not be charged to full capacity. Does the battery show full charge when you charge it for 12 hours?
The adapter may be faulty. Check the battery indicator on the phone when it is being charged.
Sep 22, 2010 | Nokia N72 Cellular Phone
Samsung ES-17 power problem
This could be a battery problem, as the camera draws more power when switched on, to work the lens and focusing. Try changing the batteries. If its still a problem, you have a camera fault.
Jul 17, 2010 | Samsung L200 Digital Camera
I keep getting the message: Turn the power off and on again. Just bought the Cybershot DSC-W370 tonight and it worked fine, until the battery was charged. ???
Why don't remove the battery? First, switch off the camera then remove the battery. Wait for 5-10 mins then put the battery back on and charge it straightaway. remember to leave the camera off while charging. let it charge full then unplug and switch the camera back on. let me know if this works for you.
Jun 26, 2010 | Sony Cybershot DSCW370 Digital Camera
Put a new fully charged battery in - the camera would lasted for a couple of minutes and then would not switch on. The battery works fine in an identical camera. Put in a second battery - that worked for a...
It is due to some kind of electrical contact failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
Apr 26, 2010 | Canon Digital Rebel XT / EOS 350D Digital...
Nokia 5200 . bty gets discharged immidiately.switches on only when connected with charger. at times bty shows full . but again within an hour or so phone is switched off. pl help
It must be a problem of battery. Buy a new battery and it should work properly. Buy an original Nokia Battery if possible for better results.
Feb 07, 2010 | Nokia 5200 Cellular Phone
New battery for toshiba laptpo 4600 but stillnot holding charge
Two options, though check your user manual (if you have one...):
1) Many modern laptops work fine on mains power without the battery installed. So try removing the battery and switching on just with mains power. And when you switch on, press the on/off switch hard.
2) Many laptops have a reset switch. Sometimes this is somewhere around the keyboard (you may need a needle - the blunt end!! - or similar to press it) or possibly under one of the removable covers on the underside.
Jun 24, 2009 | Toshiba Satellite Pro 4600 Notebook
APC external Backup battery is not working plz
It may just need a new battery. The UPS will do a self test on the battery when you turn it on. It may have tried to read the battery and the result came back as "failed". The batteries last about 3-5 years, even less if you live in an area with bad power. The batteries are very easy to change. You can buy replacements at www.batteryinternational.com/apc-backups-es-be350es-ups-battery-ups-batteries-f1.html
Jun 08, 2009 | APC Back-UPS ES 350 - UPS ( external ) -...
Panasonic lumixDMC-FX7 camera
Could be either. If on switch on again the indicator is full and you get more work done then its a camera fault. If when you switch on again the battery remains flat then this could be the camera fault too the flash capacitor showing signs of distress. On the other hansd the battery could be nearing the end it useful life. How much is a new battery?
Aug 29, 2007 | Panasonic Lumix DMC-FX7 Digital Camera
LG Prada KE850 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
