Ps3 defaults to 576p when connected through onkyo 606 receiver
Help Please! PS3 defaults to 576p on HDMI when connected through Onkyo 606 on HDMI to Sony 46x3500 TV I've tried soft reset on PS3 to detect new HDMI settings, but it keeps only finding 576p! (Onkyo picks up audio formats OK though)
When PS3 is connected direct to TV and reset it finds 1080p straight off.
Sky HD is also connected through Onkyo 606 on HDMI and resolution changes to 1080i fine.
I've tried changing around port assignments and cables but same problem consistently happens.
  • nelci_Madrid Jul 24, 2008
    turn off after few seconds i desconect for one hour like the manual said+ remove all the conections and reconect but still not stay on,help.......
  • jerkilroy2 Jan 08, 2009
    got the same problem only the ps3 only will display 480p and no more or my samsung 50" plasma says there in no signal. no one seems to have a clue on what is wrong!
You have to tell the PS3 what the Okyo can do and it probably cannot do 1080P 60Hz (but can likely do 1080P 24Hz).  Try ticking more resolutions in the PS3s setup
Posted on Sep 03, 2008
Ps3 doesnt give out a surround sound output
Hi
In this configration you will not get surround sound. Because tv is not able to reproduse the surround sound through its out put from the HDMI input. You have to connect the HDMI of PS3 to the Onkyo receiver and the HDMI Monitor Out of the Onkyo to the TV. This can only done if the Onkyo AVR Have HDMI IN/OUT option.
If not the connect the Optical out of PS3 to any one of the optical input of the Onkyo receiver.
After that you have to goto the setup Menu the Onkyo and assing the optical input in wich you have conncted the PS3.
Aslo the following setting in PS3
Menu>>> Settings >>> Sound Settings >>> Audio Output Settings >>> Select the connector..= DIGITAL OUTPUT (OPTICAL)
Ajin
May 21, 2012 | Sony BRAVIA KDL-32S2010 32 in. LCD...
I have an Onkyo TX-SR605 , I have my ps3 connected via hdmi and from the amp to a 3d tv via hdmi . when i am connecting through the amp the PS3 does not recognise i have a 3d TV and will not play 3d Movies...
No but you may be able to help me. I have the same amp and ps3. I have HDMI leads from both but cannot get sound or picture. I do get the set up menu which means it recognises the HDMI lead. How is yours set up ?
Jan 25, 2011 | Onkyo TX-SR605 Receiver
Onkyo tx-sr 606 HDMI signals not working anymore...
I am sorry about your issue,. If the reset did not resolve your issue the receiver would need to be serviced. It if was purchased from an authorized seller less than 2 years ago it would be under warranty. Thank you. Onkyo USA
Mar 09, 2017 | Onkyo TX-SR606 Receiver
Onkyo 606 doesnt show video anymore fom ps3 over hdmi
i hate to say it i got the same problem and the only way i sorted was a master reset which means u have to do all the set up again and asign all the hdmi again but since i done that no problems to do this un plug the lot for an hour reconnect everything then push and hold the vcr button and push stand by a message will say clear on the receiver then it is back to when u frist got it out th box hope this helps
Sep 03, 2009 | Onkyo TX-SR606 Receiver
No image/sound when sony ps3 is connected to onkyo 875
I've had problems with my Onkyo receiver too.
Firstly i suggest going into the Onkyo setup menu. Make sure that in "source settings" i think that's the menu option) that the input e.g. dvd is set to receive HDMI. then go into the settings for DVD and ensure that resolution is set to auto, then go into the monitor out settings (option 1 on main seyup menu) and make sure that main monitor out is set to HDMI and auto resolution.
hope this helps,
Aug 13, 2009 | Onkyo TX-SR875 Receiver
Upscale from 480p Signal via HDMI
ok the problem might not be with your receiver it is with your direct tv settings. Double check to make sure you go to the format and set it up to be fixed or 1080i whichever will give you the highest resolution. Check your manual for the direct tv receiver. If this is all correct for the DTV then you must go into the setup on the receiver and at hardware icon toward bottom check on that box, now goto the hdmi settings and make sure it is set to through. this will allow the best picture with no upscaling which will degregade picture for blu ray. so your direct tv will be only 1080i but very impressive. if you still want to upscale you can then you have to change the hdmi settings from before to upscale 1080p . I just hope that your dtv can output 1080i it will give a better picture than 480p even if both are upscaled to 1080p
Oh i forgot to ask if you are connected through hdmi to the tv. Hdmi is the only option for upscaling
Feb 21, 2009 | Onkyo TX-SR606 Receiver
Unsure of audio setting using Onkyo TX-SR606 connected to PS3
The PS3 should default to the DOLBY DIGITAL sound output so your ONKYO should be setup to the Digital input, TV logic is a matrix similated multi-channel and I doubt if any PS software is in the DTS audio format, look at your game software disc`s and they will inform you of the audio capabilities.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Ps3 and onkyo receiver
Hello.
I have a similar setup and am having problems of my own, but i've got it somewhat working at the moment.
I have the TV connected via HDMI to the receivers HDMI output port.
I have the PS3 connected via HDMI to the receivers HDMI input port 1.
I went on the receiver and followed the instructions in the manual to setup the DVD function on the receiver (i chose to call my ps3 a dvd) to use HDMI-1. I can't remember the button combination as i'm not at my hosue right now, but it was in the HDMI section of the manual (page 44 on my manual). Essentially I had to tell the receiver to enable HDMI for the DVD function rather than being defaulted to "No". At that point, with the default ps3 setup, I was able to get video to pass through.
Next, i went into the video options on the ps3 and changed it to 1080p (since my tv supports that).
Where I"m having my problem is that the sound from the ps3 outputs directly to the TV and doesn't output on my receiver for some reason.
How I've rigged that to work is to take the HDMI to RCA cable that came with my PS3 and i plugged in the Red and White wires on the back of the receiver in the DVD section of inputs. At that point the sound comes through the receiver.
What I don't know how to do and would really like to know is how to get the sound to output on my receiver via HDMI only and not with the extra cable.
Anyway, if i'm making sense above and you follow that, you should be up and running (but maybe not in an optimal configuration).
Let me know if you ahve any questions.
Also, if anyone knows the solution to my issue, i'm all ears.
Thanks.
Nov 09, 2008 | Onkyo TX-SR803 Receiver
827 people viewed this question
 Grubhead
Grubhead
