Question about Denon Audio Players & Recorders
Hi - I have a Denon DM50 mini hifi and the CD tray seems to have jammed. It says Mech Error on the display when I try to open the tray. Completely my fault as I moved it when there were cds in the autochanger. Any ideas on how to sort this out?
  • 2 more comments
  • acharvie Jun 22, 2008
    I'd just like to be able to open the tray and play CDs again, so have tried to remove the front of the hifi and see what I cann do from there.
    Thanks. A CD is definitely stuck in there. The problem that I'm having is that one side of the front casing is being stubborn and refusing to budge. Pretty sure I could fix it if only I could prise the front off! May just have to take it to a pro after all.
    All sorted! Thanks.
  • Jorge May 11, 2010
    What are you trying to do with it?
  • 624 Answers
I think you have a disc in the mechinism that has popped out of the tray.
Taking these apart and getting the disc out can sometimes be a pretty difficult problem. If you do not have some good mechanical skills and are able to remember exactly where each screw goes and how each cable is plugged in, I would not try it yourself.
A repair center could probably fix this for around $75, depending on the rates of the shop. It should only take them about an hour to do this. And normally they will also clean and lube the mech properly while they are already in there.
If you do attempt this make sure everything goes back together exactly the way it came apart.
Once you get the mech out of the unit, look to see if there is are any disc's that are out of place. Sometimes you can push the disc back into the tray without dis-assembling the top part of the mech. This would be the preferable method so you will not need to re-assemble the mech.
If a tray is loaded into the area where the laser pick up is located and a disc is actually clamped into it, do not try to remove that.
It is likely that it is in the proper position.
If you require any further help let me know, and a good rating is always appreciated.
Posted on Jun 22, 2008
Sony mhc- rg 55 MECHA ERROR disc spin then turn off
My mhc-rg 55 shelf system reports a Mech error when I turn it on (after rotating the CD tray to try to take up each CD twice ) Then is shuts down.... I took the unit apart and saw noting obvious... (Of course it was more difficult to reassemble and still doesn't quite fit properly.) But the problem persists. Looks like it over to the repairer. Sorry - No solution here
Nov 21, 2012 | Sony MHCEC99 Mini MP3 hifi system Shelf...
Denon m50 may need to do a manual extraction on that...there may be a reset manual mode on that one..let me check the user guide..but it may require removing the case, and delicately releasing that mechanism from inside..
May 27, 2008 | Denon D-M50S CD Shelf System
Cd player shows error "Mech"
MECH message means a "mechanical communication error", when display on your car cd player indicates that there is a problem with cd player that has do with the mechanism which is jammed up.
You need to open up the player and clean out the dust inside.
Good luck.
Oct 12, 2011 | 2007 Dodge Nitro R/T New Cars
Denon UDCM-M10 CD auto changer Disc slots won't open. Display says 'Err'. Any advice welcome.
These units attempt a "reset" operation when first powered up. This insures that the mechanism is in a known state and ready. Any failure to complete this reset will result in the error you see. Usually this is caused by the mechanism getting out of timing and requires a erbuild of the mechanism to get the timing correct. A jammed disc, or the forcing of the tray can cause this too. Without seeing the actual unit, I can not state for sure what the exact rpoblem is, but a repair for this problem usually costs less than $10 for parts. The cost is int he labor to completely dis-assemble and re-assemble the mechanism.
Jan 22, 2010 | Denon Audio Players & Recorders
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Deneon UD M50 - Tray jam
It sounds like the cd tray has been forced shut and has been damaged when you got the CD's out. If it was me I would of unscrewed the casing and retrieved the CD's that way instead of trying to force the try open which I'm assuming you have done.
It could just be a simple matter of just slightly adjusting the internal CD mechanism so that it can open and close properly without jamming. The error message comes up because the tray cant eject properly. The worse case scenario is that the CD mechanisam would need to be replaced. Not a hard job for a service engineer, if you dont fancy taking the thing apart yourself then a service centre is your best bet.
Nov 01, 2008 | Denon D-M50S CD Shelf System
Denon adv-700 - Mech error
try to disconnect your system from power and connect it again.
Sep 06, 2008 | Audio Players & Recorders
Sharp mini system error code 20
The code CD20 means Tray error. The cd mechanism will have to be reset by a serviceman .
Jan 06, 2008 | Sharp Multi-System Mini Component System...
Denon m50
You can probably fix it yourself but you may need some parts. Here's Denon's link that'll take you to the next step
Nov 24, 2006 | Denon D-M50S CD Shelf System
122 people viewed this question
Top Denon Audio Players & Recorders Experts
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
