Laptop unable to connect to cable modem
I have an older HP, it doesn't have an ethernet card, but it does have USB ports. I'm trying to use the USB port connection from my Time Warner Cable modem, but haven't been able to make a connection. Am I wasting my time and should I instead opt to use an ethernet card in the PCMI slot?
  • tumblez007 Jun 23, 2008
    I didn't mess with the USB, and used an ethernet card like you suggested and I'm up and working. Thanks for the advice!
    President:
  • 1,314 Answers
Although you can use a USB connection, you have experienced first hand one reason why I never recommend it. Firstly, you have to install drivers for the modem itself, usually included on the install CD. However, if you just purchased an ethernet card for under $15 locally or under $8 on the web, you plug it in, and once it's installed you just go without further complications and it is faster and more reliable as well.
Posted on Jun 22, 2008
  • Kevin Shafer
    Kevin Shafer Jun 22, 2008
    Sorry, the prices I quoted are for a desktop but for under $20 online you can get one for your laptop.
I have an older model armada 7800 that I am trying to get connected to the internet. Where does the ethernet cable go on this model? The only place I see for it is in the back, but the cable does not fit...
It may not have a place for an Ethernet cable. These older laptops required special cards to be attached to them or inserted into a special port for them to work with an Ethernet cable. The port your referring to might be for a phone cable which means it would have a modem and be dial-up only.
Oct 28, 2010 | Compaq Armada 7800 Notebook
Where is the ethernet cable connected to this laptop
This is an older laptop that comes with a modem (RJ-11 on the back), not an ethernet adapter onboard. You can try to get a PC card ethernet adapter (type 2 or type 3 fit the slot) or a USB ethernet adapter. The USB port was not available on models that came with WinNT.
I wish I could be of more help.
Oct 15, 2010 | Panasonic Toughbook CF-27 Notebook
HP 4450 desktop, not have a ethernet port
No you can't.
But you have ywo other options to use broadband connection.
1. Use a USB modem, or
2. Install a network card to be able to use an ethernet cable.
A network card cost around $10.00.
Don't forget to rate this answer if it helps
Dec 27, 2009 | Computers & Internet
What is the difference between connecting a computer to a DSL modem via Ethernet and connecting a computer to a DSL modem via USB?
They are just two different methods of connecting a router. I always choose using an Ethernet over USB if I have the option. USB connections are more prone to problems with drivers.
Sep 23, 2009 | HP Pavilion dv6000z Notebook
Vista desktop won't connect to internet cable modem eithernet
power down cable modem, router, and computer. Connect ethernet cable from modem to router/ and connect ethernet cable from router to PC. Power up cable modem first, after modem shows connectivity, plug in router. After router shows internet connectivity, start computer. Be sure that you LAN card operable
Apr 15, 2009 | Acer Computers & Internet
It sounds like you are setting up your new laptop to connect to your cable modem. If that is correct, your laptop should only have one ethernet port. The other port should be for the modem, but it does look very similar to the ethernet port. I would highly suggest getting an inexpensive router to place between your laptop and your cable modem. The routers come with detailed instructions on how to connect it to the cable modem and the computer. This will provide 2 things for you. The first is ease of connection, and the second is protection from all of the bad stuff on the Internet.
Mar 26, 2009 | Sony Computers & Internet
Problem setting up home network with d-link des-1105. Windows Vista on main PC & Windows XP on laptop. Presently, I have ethernet cable connected on main PC to d-link and usb cable connected to laptop & to...
A router is basically a mini-computer that splits up one internet connections to 4 (or whatever # of ports you have).
Basic Connections to a router:
A Router requires a internet connections, so your broadband modem must connect to the WAN port (theres only one) of the router DIRECTLY. Then Ethernet cables go from the router to the computers on the LAN ports. Don't do something weird like connecting your internet to your computer then your computer to the routers WAN port, it'll most likely mess up.
Once you have connected your router like this, it should work.
If your modem only has a usb port, I have no idea how to make that work out. Sorry. Try getting a new modem from your ISP, or check if your modem does have a ethernet port, if it does just connnect that to the routers wan port.
Also computers should not interconnect with each other with use of a router. Thats what the router is for. Everything gets connected and split up at the router, nothing connects to anything else but the router, basically.
Feb 26, 2009 | D-Link DIR-625 (790069292637) Wireless...
Ethernet cable does not fit
The modem jack is too small because it is for a phone line connection not an ethernet connection. If you want to get online by dial-up, you need to connect modem to a phone line. Ohterwise look for another input jack on the laptop that the ethernet cable will insert to.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Dec 10, 2008 | Dell Latitude CP 56K PCMCIA Modem Card (PC...
Modem usb connection
You can only use the USB connection or the ethernet connection to get it work.  It won't work on both.
What type of router are you using?
Sep 13, 2008 | Arris SURFboard SB5120 Modem
Trying to get router to work
U can use
USB Ethernet Adapters.Visit:
http://www.ramelectronics.net/network/network-cards/usb-ethernet-adapters/c40000-c43000-c43004-p1.html
Dec 27, 2007 | Computers & Internet
Computers & Internet Logo
197 people viewed this question
David Payne
David Payne
