Phillips HTS3400 blinking red light
A few days ago the speakers started making a terrible noise. Sounded like screaching and a lot of bass. OUT OF THE BLUE. Now the thing won't turn on. I've unplugged it for a few min. but when i plug it back in the standby light blinks kinda fast. We dont turn it off when we go to bed we just turn the tv off. It must have shut itself off during the night.
  • elite18range Sep 14, 2008
    I have the same problem with mine. Except mine started one day when nothing was playing it was just turned on. I heard a noise and noticed the light flashing. I unplugged the system but as soon as i plug it back in it starts back. The power/standby button doesnt respond the only way to turn the system off is unplugging it.
  • maddoxdtd Sep 16, 2008
    How di you fix it? anyone please?
There is a capacitor on the power supply that has gone bad, it is a 1000 mf 16v cap and you will notice the top is bulged up a little bit. there are three in a row and this is the center one. Radio shack replacement part for $1.73 and you are back in business. Tim
Posted on Jan 14, 2009
  • 1 more comment
  • ginoromano Oct 09, 2010
    Yes, you are right. Thanks... I will get the part and let you all know.
  • joseingaran
    joseingaran Jul 21, 2012
    twood95 is right. I have the same problem. Replacing 1000mfd/16v solved my problem. Thanks twood95.
  • Bill Anderson Apr 12, 2016
    I, too, had the blinking red light. A capacitor on the power supply had a bulging top. I replaced it and 4 others in the area ( no good reason for the extras) and now I am humming along with theme music.
  • 4 Answers
Many other users reporting the same problem using different description. Mine was doing this same thing and now just sits there and buzzes until I press the power button and then it's quiet for a few seconds. I've taken my power supply loose, but there isn't anything obviously wrong and is more than likely a $3 part like a capacitor that has gone dry.
There is a user "meelous" that said he had a fix for this, but he hasn't responded yet. Look at the other posts using the HTS3400 and watch for a real solution, other than throwing it away and doing without.
Good luck.
Posted on Aug 30, 2008
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
2000 Subaru Impreza Sedan; Couple different noises
the screaching noise is 1 of your belts needs to be tightened. noise from the right front tire sounds like a bad sturt or ball joint and that needs to looked at
Jan 07, 2013 | 2000 Subaru Impreza
Noise/No Bass in Delco Systems stereo
You have a possible fault in your wiring of the speakers, the Phases of the speakers are crossed over resulting in cancelling of the low frequency- bass frequency. Hence please reconnect the speakers front and rear with the positive/ negative to the corresponding positive and negative of the speakers.If you are unable to fix the marking of the polarity use 1.5 Volt cell to connect to the speakers , if the speaker moves up the terminal on the positve of battery is positive. reconnect and test with a good bass song for result. Helpful. Good day
Jul 05, 2010 | Car Audio & Video
Subwoofer sounds muffled or no sound just started a few days ago put head phones in receiver the bass sounded fine subwoofer has been popping as of late every once and awhile
maybe a defective surrond internal Amp board is defective, send to repair. 1st check for any equal. settings, try on flat equal.
Jan 17, 2010 | Audio Players & Recorders
GK 1001 rb speaker overload, is my guess
This problem is not likely to be a volume control problem. There is a transistor inside that is failing (getting noisy) when heated up. If you have no experience with amp repairs, do not attempt this as it is not simple to locate the defective part. Continued use in this condition can cause problems with the speakers. Please have this serviced by a repair shop with experience with GK gear.
Dan
Jul 29, 2009 | Crown CE1000 2-Channel Amplifier
Printer suddenly stuck while starting up
eww this one can be lots of things!!!
make sure no paper jammed anywhere
make sure the print head is moving
make sure the ink cartridge is set down right
May 24, 2009 | Samsung CLP-300N Laser Printer
LOUD NOISE WHILE DRYING
remove the back cover that covers the lint trap. there is a fan blade back there and some foreign object is probably hitting the fan blade
Jan 01, 2009 | Whirlpool LER4634J Electric Dryer
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Phillips Plasma 42" TV
what model do you have?
Jun 23, 2008 | Televison & Video
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
1,483 people viewed this question
 Grubhead
Grubhead
