Question about Vacuums
Where do i put the clean water at and the cleaning solutions
Http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=695898
Generic problem for all Vacuums
Where do I put the
Posted by nichole171 on Jun 22, 2008
Where do I put the clean water at and the cleaning solutions
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am not sure what type or brand name for the type of scrubbing unit you have , but the clean water and the cleaning solution generally go into the same container and then it will release onto the carpet or floor.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
Detergent doesn't dispense.
Water will clean carpets but not very well. For the best results don't put any cleanser in your machine. Soap can clogged up the lines in your machine. When you have soap dispensed or or in the water in your machine you are squirting it onto the carpet and sucking it back up at the same time...the soap and water isn't on the carpet long enough to clean well unless you keep going over the same area many times. To clean better it's really important to vacuum thoroughly going slowly in multiple directions to get as much dry, gritty soil and hair and dust out as possible, it's easy to get these soils out when the carpet is dry if your vacuum is working properly. Vacuum, vacuum, vacuum.
Get a spray bottle or sprayer and put hot tap water in it, add the cleaning solution to the hot water and spray enough on the carpets to get the face fibers damp...let the hot water solution sit on the carpets 5 or 10 minutes and then use your machine to clean and rinse the soap, water and loosened soils from the carpet fibers. Repeat if necessary. Your carpets will be cleaner because you allowed adequate dwell time for the soap and water to work on the sticky greasy soils attached to the carpet fibers and stay clean longer because the soap is rinsed out of the carpets. Your carpet cleaning machine will last longer too because the water lines, pumps, spray jets, heaters, etc can't get clogged with soap gunk if you don't put soap in it. The method I'm describing is how the best professional carpet cleaners clean carpets. Hiring a quality carpet cleaner cost more up front but the carpets may stay clean two or three times longer, saving a lot of money in the long run. If you clean your carpets using this dual process method you may do a better job with a small portable home or rented cleaner than hiring the average carpet cleaning professional who is trying to give you the lowest price.
Mar 06, 2017 | Vacuums
It is not dispensing water and solution
Clean Water
Solution Tank
won't dispense.
1. Clean Water Solution Tank
not firmly in place.
1. Make sure tank is securely locked in
position.
2. Clean Water Solution Tank
empty.
2. Refill tank according to instructions for
surface being cleaned.
3. Dirty Water Tank lid not on
correctly.
3. Make sure lid is firmly in place.
4. Pump needs to be "primed"
(when using tool).
4. See "Before Using Tool" section.
Dec 17, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Where do you fill the cleaning solution at on this model?
The formula goes in the SmartMix tank on the side of the machine next to the Water/Solution dial.
Below is a link to the User's Guide.
http://www.bissell.com/VideoRating.aspx?id=1555
Jun 16, 2010 | Bissell 8910 ProHeat Clear View Upright...
Biseell little green machine wont squirt water out
The Pumps on these go bad after a couple of months. They rust and will sometimes spray and other times not then eventually not work at all. If your a handy man pull the top off it and remove the pump motor and replace it yourself. The part number is 603-5029 you can put this number in google shipping and get it to your door for about $15 and replace it yourself or have a friend do it. Ebay has tons of them once again just put in the part number and a list of them will come up.
Thanks and have a good one
Sincerely, CRTN
May 22, 2010 | Bissell THE BISSELL LITTLE GREEN MACHINE...
I need to know what compartments to put the water in, and to put the cleaning solution in.
Hi There,
The Larger compartment is for the clean water, and the secondary tank attached to the larger tank in the back of it is where the shampoo goes. This machine is handy as it will automatically mix the two solution tanks together for you.
Feel free to reply if you have any other questions. Thanks,
Chris Jones
GoVacuum.com
Apr 24, 2010 | Hoover F7425-900 SteamVac V2 Widepath...
Every time i push the steam vac forward it dispenses water
you are having the same problem i am and so far the best solution i have found is i need a new clean tank just got my steamvac today bought it cheap so not complaining much the other solution i found was to only have the cleaning solution tank in for as long as i need it if i put the cleaning solution on the floor then take out the clean tank the dirt tank still sucks up the water
Godbless and Goodluck ...by the way just in case you dont have it here is the manual for your model
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Jun 08, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I HAVE A HOOVER STEAMVAC DELUXE 1500, HOW DO I PUT THE CLEANER IN AND WHAT PART
I have the same series - The steamvac deluxe 1500 has two containers, one that is on top is for putting the cleaning solution/water in and the bottom container pulls up the residue/dirt. The top container has a nozzle that you twist out, you put the water in until it reaches the line which is 3/4's up the way. You then measure the nozzle (it has two lines) and put the cleaning solution in there and then into the water.
Hope this answer's your question.
Jul 15, 2008 | Hoover Vacuums
Bissell carpet cleaner
If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
Water?
There are two tanks on that machine. The lower tank is the recovery for the dirty water and the upper tank is for the clean water solution. You mix the detergent with the clean water and away you go.
Feb 08, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Lost my manuel
you use 5 ounces of cleaning fluid per 1 gallon of water AND you put it in the clean water hole any more questions on this device just tell me
Sep 05, 2007 | Bissell 1685 PowerSteamer Vacuum
Vacuums Logo
49 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
