Question about Akai PT50DL24 Television
Flashing LAMP light; no picture, no sound. HELP!
Model: AKAI PT50DL14X/SMS
We just bought this used TV, get it home and SURPRISE! It doesn't work! We we try to turn it on and the LAMP light on the front just flashes for maybe 30 seconds, then the STANDBY/TIMER light flashes for a bit. You can hear it trying to click on, and it sounds like something inside is spinning. We've tried unplugging it, leaving it off for awhile then trying again but it always does the same thing. We're just hoping someone on here can help before we take it to the shop (Hopefully, we won't have to!).
  • mattcarrara1 May 11, 2009
    I cannot hook up my game consul from hdmi.  its says not in the right mode.  now it wont do anything and just flashes timer and stand by
SOURCE: HELP!!!
I think i have the solution to your problem,
I think that the lamp has gone out in your tv. You should try changing it out. I work with many tv's with DLP's and it almost always is the lamp. YOu can order it online, there is a slot on the side of the tv were you can change it out through there, the lamp should have a number on it. And its pretty simple to do. So there you go..and I could have gotten you a better deal on your Tv.
THE END
Posted on Nov 21, 2008
  • 147 Answers
SOURCE: AKAI 50 inch TV Turns off
Replace the lamp.
Posted on Apr 09, 2009
tvtek
  • 1284 Answers
SOURCE: Akai DLP projection TV. Picture is fine except
The problem is the light tunnel is collapsing. This is a VERY common issue with the Samsung/Akai DLP TV's. It is four mirrors used to transfer the light after it passes the color wheel to the DMD board. When part of it collapses the grey bar that you are seeing is the end result. This is a part that usually requires a technician to replace as there is a little tear down of the light engine itself and you would be handling delicate parts. The part number for the tunnel assembly is BP96-01961A and I have included a link so you can purchase it through the Samsung website. Please take a few moments to rate my answer. Thanks..
http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96-01961A&search%5Fmodel=PT50DL14
Posted on Nov 21, 2009
Testimonial: "Great solution and response time!! Thanks!"
SOURCE: AKAI - PT50DL14X\SMS DLP TV
lamp reset code
Posted on Feb 10, 2011
SOURCE: AKAI PT50DL14X\SMS - LAMP INDICATOR (GREEN)
AKAI PT50DL14XSMS - LAMP INDICATOR (GREEN) FLASHES ABOUT 20 TIMES - CAN HEAR FAN RUNNING AND LOOKING THRU LAMP GRILLES CAN SEE BRIGHT BULB LITE - NO PICTURE COMES ON - AFTER ABOUT 30 SECONDS EVRYTHING SHUTS DOWN
Akai pt50dl14x sms
Linda .....no its not the lamp thats causing the whirring/buzzing sound but the colour wheel, its housed in the light engine you will need to replace the whole light engine cos the inbuilt colour wheel is worn out this causes the buzz hence the lamp may not light up or u may have shut downs flickers on the pix or color issues
Jul 08, 2013 | Televison & Video
Akai rear projection tv suddenly stopped working.
This set with Akai is actually made by Samsung (they own and use the Akai name).
If lamp light etc and you have heard a cracking sound it may be the color wheel.
You can remove the lamp and look where it faces--look and the wheel can be seen----is it shattered or missing plastic pieces?
The wheel commonly fails in this fashion and is turning at over 12,000 rpm. The set will detect if the wheel is stopped or moving too slow and just what you describe will happen.
Wheel is widely available and You Tube has video instructions for replacing them by model number.
Questions?
Mar 28, 2012 | Akai PT5492S 54" Rear Projection...
We recently adopted a Akai TV model PT50DL24 and the sound and the picture is fine but very very dark. I tried adjusting contrast, colour,and brightness but remains a very dark picture. Please help!!
Tv have a word "LAMP" on it front face frame bazel?Yes,than this tv model have a projection lamp it is dying requirement of the projection lamp replacement.Tv can be save.Not no "LAMP" word on it the front bazel frame.Not repairable,because it is using CRTS-tv tubes tech.Sorry it is garbage tv time,those CRTS tubes are dying,not worth replacing and cost almost the same as a new tv itself,if u can buy it refurbish CRTS tubes anymore all.
Jun 07, 2011 | Akai PT50DL24 Television
TV won't turn on. But my model code is a little different it is PT50DL14X/SMS
Please replace lamp in tv to solve the problem.
This has been discussed in chat session a while ago and you found broken lamp in tv.
Thanks.
Apr 06, 2011 | Akai PT50DL24 Television
Akai DLP projection TV. Picture is fine except lamp is not illuminating a 3-4in area on the left side of the screen. You can see the picture over there but it is dimly lit. I can't seem to find a way to...
Nov 20, 2009 | Televison & Video
Nov 02, 2009 | Akai PT50DL24 Television
I have an AKAI 50in DLP rear projection HDTV keeps shutting down
hey there is sounds like your tv is trying to tell you to replace the lamp
the lamp is running out of mercury gas and is starting do give up I recommend you get a new bulb
Jun 19, 2009 | Akai PT50DL24 Television
AKAI Rear Projection 46"TV has a blank picture with sound only
Is it a CRT or a DLP/LCD projector? If not a CRT, a worn-out projection lamp can cause this symptom. When it is a DLP projector, a faulty Colour Wheel sensor can be the additional problem. If it is a CRT projection unit the High Voltage and deflection circuit must be examined...
Please tell me more about your unit...
Thomas
Jan 19, 2009 | Akai LCT2715 27 in. LCD Television
HELP!!!
THE END
Jun 28, 2008 | Akai PT50DL24 Television
Akai PT50DL24 Television Logo
127 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
