Question about Zyxel Prestige 660R Router (91004397002)
Port forwarding I have a linksys BEFW11S4 and a zyxel-660. I am attempting to forward ports and I can not get them to take. I have switched routers and modems thinking that was the problem but obviously as in most cases, its the operator. I have followed guide after guide step by step and its still a no go. Could someone else be of assistance please?
  • p_kat423 Jun 22, 2008
    Even if i turn off the firewall in the modem? There is an option to do that and I have disabled the firewall according to that option.
    Ok I have bridged modem and the linksys is givin public IP like you said it would :) Now however....do i need to configure ports in the modem? And do I still forward them to xxx.xxx.x.100?? or use the public ip its broadcasting?
    Genius:
  • 1,689 Answers
Well to start, your connection would possibly be ADSL and your zyxel is set to provide DHCP address on your network, so its router capabilities could be turned on.
if this is true, you may need to rework the connection settings.
here's a recommendation:
1.set your modem to bridge mode (bridge only)
2.this will then be allowing your linksys to manage your DSL connection through PPPoE
3.after so, your linksys router should get a public IP address for an internet IP when you go to status tab (not an IP address starting with 192.168.1.xx)
after so, you may reconfigure your port-forwarding.
the reason why you will need to set your modem to "bridged" only is that if it is not, your zyxel's firewall is also turned on, provided that the linksys' firewall is always on. so even if you define which port will be opened on the router, it will still be blocked by the modem's firewall.
Posted on Jun 22, 2008
  • marlon john madrid
    marlon john madrid Jun 22, 2008
    well disabling the firewall on the router may not do any good since its (Network Access Translator) NAT is still truned on, so it will be best to set your modem to bridged.
    good luck on this one p_kat, what application are you trying to run anyway?
    no need to do anything in the modem since it is bridged. for the forwarding just forward the ports to the IP address that will use it, like a server perhaps.
Port forwarding on Linksys SRW224G4P
Google took me straight to the manual. This is a Switch not a router so it operates in layer-2 (ethernet). Layer-2 ports are the interfaces on the back of the switch. You want a router that can do layer-3 TCP/IP port forwarding. Layer-3 ports are unsigned 16-bit integers associated with an IP address and a protocol.
Oct 13, 2013 | Linksys SRW224G4P 24-Port Ethernet Switch
Linksys port forwarding
This WEB site shows how to port forward.
http://www.wikihow.com/Port-Forward/Open-Ports-on-a-Linksys-Router
May 05, 2013 | D-Link DSL-G604T Wireless Router
I want to add a LINKSYS workgroup switch EZXS55W behind my wireless routher LINKSYS BEFW11S4 v2 via uplink cable connection. When hardwiring my anything to the switch port 1-4 does not get internet access
Are those 4 ports in different Vlan ?
If you connect your wireless access point to the 1st port are you able to access the internet through 2nd port or 3rd port ?
Are the ports 1-4 admin down ?
Dec 23, 2010 | Linksys Bundle: BEFW11S4 802.11b Wireless...
Port forwarding not working in ok firmware AGL6 or later
According to my very thorough testing some weeks ago, P-660-HW-D1 port forwarding is really very broken.
The worst thing is that not only does the port forwarding work properly, it lets packets to LAN addresses where they're not supposed to go. This means you're not safe behind LAN.
Firewalled or not, AGL.6 or AGL.7 shouldn't be used at all in my opinion, they're unsafe. When in routing mode, and having several LAN machines behind one Zyxel switch port (i.e. separate switch attached), I found that the port forwarding is completely broken.
I have contacted Zyxel Finland about this issue two weeks ago, and they initially thanked for the finding and said they're passing the issue onwards and investigate it.
The best current solution is to downgrade to (also very buggy) AGL.4.
May 13, 2009 | Zyxel P660HW-D1 Router
Linksys BEFW11S4-RM 4 port wireless router
This is an old router. Look at the power light. You must have a STEADY power light. RESET the BEFW11s4 by pushing the reset button for 30seconds. Unplug the power of the BEFW11s4 for 30 seconds. Connect pc to port 2 or 3. pc should get an ip of 192.168.1.x. If you are getting this ip that means that the pc is already detecting the router.
Good Day
Mar 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Port Fowarding
Here is a listing of programs and how to forward them for your router.
PortForward
Feb 01, 2008 | Linksys BEFW11S4 Wireless-B Broadband...
Port forwarding
Please find the URL below which will help you getting the port forwarding done.
http://portforward.com/english/routers/port_forwarding/ZyXEL/Prestige660R-61/default.htm
with regards,
TPV
Dec 20, 2007 | Zyxel Prestige 660R Router (91004397002)
Zyxel Prestige 660R Router (91004397002) Logo
367 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
