Cant find memory card-slot on my CPU
There seem to be a lot of slots at the back of my CPU but i am unable to figure out as to which one can be used for reading a memory card.Also do i need to have any other hardware other than my MMC.The card i am referring to in this case is the one which fits into my nokia n72.Please help me.
  • jbdusbue Mar 04, 2009
    i cant find the memory card slot HELP ME PLZ!!!!!!!!!!!!!
    President:
  • 1,314 Answers
You need a memory card reader to be able to read your MMC. If your computer had one, it would not be located on the back of the tower but on the front. Here is an external solution.
Posted on Jun 22, 2008
My mobo has 4 memory card slots
1) All of your memory must be compatible with your motherboard (DDR, DDR2, or DDR3 and speed and latency). For best results, if you have dual channel capability, each pair of memory sticks should be matched. (Usually consecutive serial numbers indicate pairs from a given manufacturer.) Both sets of memory should be rated at the same speed (or the slowest speed will be your memory speed). Some motherboards may not work with all 4 slots occupied unless the memory was certified to work as a set of 4.
2) Which motherboard do you have? The motherboard manufacturer and memory companies often will have lists of compatible memory. The motherboard manufacturer will also have information on the dual-channel pairing.
My current and previous motherboards have had memory slots in color pairs (blue, black). For my boards, I put the sticks in the blue slots (A2 and B2) first. (Preferably these should be the largest memory capacity.) Then I put the second pair of memory into the black slots (A1 and B1). DIMM slot A1 is closest to the CPU; B2 is the farthest away from the CPU.
Depending on your CPU cooler, you may need to remove it or modify it to use all 4 DIMM slots.
Observe the appropriate steps to avoid static discharges while handling your memory and when inside your computer. For actually inserting the memory, make sure that the locks (white on my motherboards) are fully open (hinged away from the slot). Line up your memory so that the slot in the memory is on top of the key in the slot and the memory is centered in the slot. It will only line up one way; the wrong memory type will not line up. Push your memory stick down fully until the locking clips rotate up and fully engage the memory. (You may need to push down at multiple places to get it fully seated.) You will then repeat the procedure with the rest of the memory.
Note: if you get a memory error, three beeps (on many boards), you will need to remove the memory and test one stick at a time in the A2 slot (for example). Then test pairs of slots. It is not unknown for either one stick to be bad or one slot to be bad. Look at the total memory your OS identifies, if you manage to boot in spite of any issues. Running Memtest may be needed but even that may not identify which specific memory segment is bad.
I hope this helps.
(who has installed or replaced memory since giving an 286 computer a full megabyte of memory. DIMMs are a lot harder to mess up as long as you have the correct memory. Note: most of the different DIMM types have different number of pins; thus sometimes it's very easy to tell that the wrong memory is being used. This isn't always the case.)
Dec 05, 2012 | Computers & Internet
I have this motherboard PACKARD BELL BV GA-T671MG. how much ram memory can it have? can i use ddr3? my pcie port supports a 2.2 graphic card?
System
System : PACKARD BELL BV ISTART F2310 AIO
Mainboard : PACKARD BELL BV GA-T671MG
Bus(es) : ISA AGP PCI PCIe USB
Multi-Processor (MP) Support : 1 Processor(s)
Multi-Processor Advanced PIC (APIC) : No
System BIOS : Phoenix Technologies, 255.255
Total Memory : 767MB
Intel Pentium D 3.00GHz
Packard Bell BV (GA-T671MG)
SiS chipset (Si671V11)
DDR2
1024mb ram
PACKARD BELL BV
Model GA-T671MG
Chipset Vendor Silicon Integrated Systems (SiS)
CPU Intel Pentium D
Cpu Socket LGA775 [Socket 775]
Processor Upgrade ZIF Socket
Max CPU Speed 3000 MHz
System Slots 2 PCI, 1 AGP
Memory Summary
Location System board or motherboard
Maximum Capacity 1024 MBytes
Memory Slots 2
Error Correction None
Use System memory
Maximum Memory Module Size 4096 MBytes
Manufacturer PACKARD BELL BV
Model GA-T671MG
CPU Intel Pentium D
Memory Summary
Memory Slots 2
Use System memory
it seems this might vary i have listed 4
hope this helps
May 17, 2011 | Computers & Internet
I have a problem booting my PC it's not doing anything but the fans are spinning and the on board light is flashing... tried the following and nor was useful: 1-changed the power supply 2-changed RAM and...
to me only one thing seems to be an issue ... and that is the ram slot ...what u can do it is remove the board from the cabinet and remove all periperals connected like ram cpu cards just the motherboard is left.... try to clean the ram slot with the cleaning liquids ...when u are doing the cleaning clean the comeplete board like the cpu slot , card slots use good amt of liquid and use a tooth brush to clean the board and than use a blower if u have one but the blow shouldnt be very high and than leave the board to dry upside down for least 30mins and than put the board back in and than see if u face the same issue ... but i have a guess if that doesnt work than its surely an issue with the ram slot ... doing this will atleast clean the slots if any kind of dust is avoiding the contacts
Jan 30, 2011 | Gigabyte (GA-EP31-DS3L) Motherboard
Unable to read my memory card, it seem to be memory slot problem
i need to open my SanDisk M2 memory card, but my card reader is unable to read it. please help. there are important files on this memory card. thanks in advance..
Oct 19, 2010 | SanDisk 2GB Memory Stick Micro M2 Memory...
Micro sd and 6133 cant be found anywhere in my phone.
As I understand the problem, seems that the phone was unable to detect the MicroSD card, right?
There could be a problem with the memory card or with the card slot on your phone. To isolate the problem, try the steps below:
1. Insert the MicroSD card in to different cell phones to see if other phone will detect it.
2. Try using another MicroSD card into your phone to test if the card slot is working correctly or not.
Apr 08, 2009 | Nokia 6133 Cellular Phone
When I put a memory card in slot A it wont work
take the gc apart and look at the memory card slot number 1 it may have ben bent sumhow idk if u have younger bros or sis's they may have tried to put 1 in upside down or summin
Mar 24, 2009 | Nintendo GameCube Console
Have a dell Inspiron 1525 notebook with memory card reader, compatible with Memory Stick Pro - but i cannot figure out how to insert the memory stick into the memory card reader - an SD card slots in...
the MS pro may need an adapter if it's the mini kind. then that will plug into that slot. it still won't fit the same way as the SD card, so insert it carefully. there should be an indented area for the MSP card to insert.
Aug 18, 2008 | Computers & Internet
Have a problem with xd card
if it formats you will lose all data-sounds like a bad card-i don't know if i would take the chance and even use it if it does format
May 22, 2008 | Cameras
Acer Travelmate 270 Memory Upgrade
Acer TravelMate 270 upgrades:
The official upgrade slot is located on the bottom of the laptop and is easy to find. Just unscrew the small cover and there it is.
The other slot requires you to unscrew the two screen bracket screws. Once you have done this, between ESC and F1, F4 and F5 and F12 and PrtSc there are small plastic rings. Put a biro nib into these and pull down. They will pop down. You can now remove the plastic cover.
Unscrew the two screws marked "L9" on the bottom of the laptop which are located at the top of the memory cover. Now you can remove the keyboard. Underneath the keyboard is the second RAM slot. The SiS 650 chipset supports a max of 1GB per memory slot and since this laptop has two slots that means 2GB of RAM. I've used Kingston DDR400 PC 3200 SODIMMS.
You can also upgrade the CPU - the fastest CPU available is the Pentium-M 2.6GHz. Nothing faster will work - trust me on this. It must be a Pentium 4 Northwood architecture CPU with a 400MHz FSB. Standard P4 Northwood CPUs with the metal shim won't fit - unless you know a way of removing the shim without destroying the CPU. Best to stick with a Pentium mobile (Pentium 4 M) chip. Look on Ebay for these.
Of course the hard disk can also be upgraded - a 200GB 7200RPM 2.5" drive works a treat. Non SATA of course.
You can add wireless and USB 2.0 using PCMCIA carbus cards. I use a StarTech 54mbps wireless card with the RAlink chipset and a NEC USB 2.0 card with 4 USB ports. Both cards fit in at the same time.
The laptop absolutely flies with these upgrades.
Mar 22, 2008 | Acer TravelMate 2702WLMi Notebook
SD card
You just need to insert a Memory card supported by your laptop in that slot and it will automatically show up on your My Computer as a removable drive.
Jan 25, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
279 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
