Roper REX4634KQ Electric Dryer Logo
Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dryer wont start, I checked the breaker I am getting power to it, just wont start, I appreciate your help. Thanks! and the Model number is REX4635EQ2
Albert Getty
Level 3:
  • Master 547 Answers
  • Posted on Oct 17, 2013
Albert Getty
Master
Level 3:
Answers
547
Questions
0
Helped
261001
Points
1266
There are 2 fuses located one on the heater side at the top and the other at the exaust side at the bottom if you hard wire the one then the other you can figar out witch one it is if none work hard wire both then replace them.
Anonymous
Level 3:
  • Roper Master 43,501 Answers
  • Posted on Nov 26, 2010
Anonymous
Roper Master
Level 3:
Answers
43501
Questions
0
Helped
10843818
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Dryer is not getting power but circuit breaker is
A dryer can not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
Also this tip will help you check the power at the back of the dryer..
Check the instructions in the last paragraph for checking voltage at the dryer...
http://www.fixya.com/support/r4496386-dryer_cord_wiring_dryer_3_wire_or_4_wire
heatman101
DRYER WONT START AT ALL.iS THERE A BREAKER THAT CAN BE RESET OR A FUSE BLOWN ?
Your dryer should be on it's own independent circuit in your breaker box.
Check that first.
If you are getting Panel lights, but it is not starting, then yes, there is a thermal fuse on the machine that may have failed.
If the panel lights are not lit - it is more likely to be the main controller board that has failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
1helpful
Dryer quit working - will not do anything when "start" button is pressed
It would help to have the model number. the model number is on the front panel that the door shuts to. Have you checked your breaker? If your breaker is fine and you are getting power to the machine write back with your model number and I will try to help.
May 12, 2009 • Dryers
Maytag Performa Dryer won't start.
I would suggest checking and probly replacing especially if you cant hear the timer motor.
Whirlpool Cabrio Electric Dryer - No Power
you have to send the model number off of the dryer,also if the dryer hasn't been taken apart and cleaned out also the vent line it could be clogged with lint and you could have popped the thermal fuse or something like that,you'll need a meter,unplug it take it apart and check the t-stats to see if one of them popped,or if it has a belt switch the belt could have broke but if you want to fix it send the model number and more info like any lights coming on but it won't start?if so then you know power is coming to the dryer but it won't start stuff like that.
Dec 26, 2017 • Dryers
1helpful
Kenmore Dryer 80 series will not turn on.
HI thanks for your question. theres a belt break switch on the dryer so that if the belt breaks it wont allow the dryer to start. check that. thanks the appliance doc. please rate my answer .thanks
Emerso Dyrer doesn't give heat
Your issue is;
"I have an Emerson electric dryer model # RED440SQ0. The dryer spins but there is no help. Thanks for any help. "
Based on the information provided above, I am unable to access my database to provide you with exacting information. An invalid model number was returned... However, I have provided some common solutions to help guide you in your search.
This information is for a generic brand dryer only!
My Solution is:
Following this link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides valuable D.I.Y. safety information on the make and model number of your appliance. In order to access your product information, you will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual.
Note: A volt-ohm meter is beneficial in performing electrical tests.
Temperature Switch; make sure a positive heat selection has been made, still no heat, then check these:
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to
Please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Jul 23, 2008 • Dryers
3helpful
2answers
My dryer wont heat up when it drying
Your issue is as follows:
"the dryer works but there is no heat to dry the clothes. model no/stock no- 86983100-69831 kenmore ultra fabric care soft heat dryers"
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is invalid. I have provided some common solutions to help guide you in your search.
This information is for an electric, generic model dryer only!
My Solution is:
Temperature Switch; make sure a positive heat selection has been made, if still no heat, then check these:
Heating element
Thermal fuse
Wiring
Power from the house: Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element: Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse: On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring: A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
In an effort to improve the quality of my answers, please show your appreciation by rating my solution.
Thank you,
Dave E. (Illeagle)
Jul 17, 2008 • Dryers
Whirlpool dryer stops after 5 minutes
Locate the circuit breaker for the dryer. Run the dryer for awhile and with the back of your finger pressed against each of the two switches (it will be a double breaker), see if the breaker is getting warm or wait until the dryer quits then check the breaker for any noticeable increase in temperature. With properly rated breakers, they should not get warm. If getting warm, it is a sign the breaker is bad and should be replaced.
Jun 01, 2008 • Dryers
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
