Question about Ricoh CL4000DN Laser Printer
Ricoh cl4000dn toner bottle sensor
Says check yellow toner bottle
nothing wrong with bottle
where can i get a toner bottle sensor
  • pkapadia Oct 30, 2008
    I broke the sensor, now i want to buy one.
    all the companies are saying same thing that tech person have to look in to it and they just gona charge you 150 per hour
  • 903 Answers
The toner bottle sensors don't go bad too often. Do you have an extra yellow toner bottle? Try replacing that first. Compare the tray where the yellow toner bottle sits to the other three colors, and make sure nothing where the toner bottle connects is broken or bent.
Posted on Jun 05, 2010
  • 161 Answers
Maybe the contacts are dirty
Posted on May 05, 2009
Life time of ricoh 3002c drums
Toner BK
Print Cartridge Black
Bla 841647
28,000prints/bottle*
Toner Y
Print Cartridge Yellow
841648
18,000prints/bottle
Toner M
Print Cartridge Magenta
841649
18,000prints/bottle
Toner C
Print Cartridge Cyan
841650
18,000prints/bottle
Feb 29, 2016 | Ricoh Office Equipment & Supplies
Where is waste toner bottle on spc420
when you will open the right cover all the way to the down, you will see a black big box, inside is the waste toner, it need eater to be replaced or empty from the the toner inside.
Jan 22, 2013 | Ricoh Aficio CL4000DN, SPC400DN, SPC410DN,...
Ricoh CL4000DN. I recharged the magenta toner using the OEM cartridge. I replaced the chip as instructed and all elements snapped together without difficulty. However, now there is a "check toner...
Hi, the chip on those toner bottles stores information about how much toner is left, so once that chip registers an empty toner bottle, it won't work even if you attach it to a new toner bottle. You'll need the chip from a new toner bottle, or one that hasn't registered no toner.
Jan 22, 2011 | Ricoh CL4000DN Laser Printer
Wher is the Waste Toner for the Ricoh CL4000 DN?
All manuals for this printer can be found here:
http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl40/cl40en.htm
The waste toner bottle is behind the left cover. Follow replacement procedures that start on page 48 of the maintenance manual
Dec 24, 2010 | Ricoh CL4000DN Laser Printer
Code error 307 ricoh CL4000DN
sc 307 is a charge bias error having to do with the yellow photoconductor unit (PCU). Replacing the yellow PCU should resolve your problem. If the problem persists even with a new PCU, you will likely need to have either the high voltage supply board or the drum positioning plate replaced.
Thanks for using FixYa!
Nov 24, 2010 | Ricoh CL4000DN Laser Printer
How to replace waste toner bottle for Ricoh Aficio w3600
1. Lift the original feed unit.
2. Lift the upper unit.
3. Right upper cover
4. Right cover [
5. Loosen the leaf spring and lift it.
6. Toner overflow sensor
7. Toner collection bottle
Once you have it out jsut dump it out (carefully) remove the sensor on the bottle and wipe clean reinstall the sensor re install the bottle and you should be good to go
Jan 21, 2010 | Ricoh CL3000E Laser Printer
Used toner bottle full on a ricoh aficio 400
The sensor is dirty or damaged cleans or replaces. This is not reset.
Apr 08, 2009 | Ricoh Office Equipment & Supplies
SC366 on CL4000DN
I just came across this post, you've likely solved it by now; However it is a "Toner density" error related to your cyan photoconductor. It is a defective connector. Replacing the cyan photoconductor should solve problem.
Feb 05, 2009 | Ricoh CL4000DN Laser Printer
SC 366 on CL4000DN
cyan problem --check if cyan pcu is set properly or replace cuan pcu(drum)
Ricoh CL4000DN Laser Printer Logo
242 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
