My turn table is and old one my needle is broken would i beable to get a new arm for it
It is a beogram 1202 if that any help thank you
Posted on Jun 23, 2008
    President:
  • 624 Answers
With a model number and the brand of your turntable I could probably find what you need with that information. Without that information there is no way to find the right parts.
I have been fixing turntables for over 17 years and have only needed to replace the arm on 2 or 3 of them in that time. It is very unlikely that you would need the arm replaced. The arm is a little more difficult to find for some turntables, but it is not impossible.
Finding the stylus, and/or cartridge with the stylus is not too much of a problem.
Just supply the needed information and I will take care of it for you.
Posted on Jun 22, 2008
Record player turn table and needle not communicating
1. Check that the cartridge is fitted to the arm properly because if there is a bad connection you will get no sound.
2. If properly fitted to the arm there may be a problem with the cartridge the stylus is mounted in. You basically have to trace it back from there.
Most of the new lower end turn tables I have seen on the market are pretty shoddy and if people are having problems with them I am not surprised. You pay big dollars for a good turn table now like the Thorens. If you want a good turn table that will last a lifetime and be 100% reliable with excellent sound that is what you need to buy.
http://www.thorens.com/turntables/drives.html
Dec 26, 2015 | Audio Players & Recorders
The needle on my sewing machine doesn't move? The needle and handwheel on my Brother LX2500 machine will not move when I press the foot pedal. Everything else seems to be working fine. I can hear the motor...
If the balance wheel is moving when you press on the control then it needs tightening, if the balance wheel does not turn when you press on the control and you can hear the motor spinning then the belt is broken
Jul 31, 2013 | Brother LX2500 Heavy Duty 17-Stitch...
TONEARM DOES NOT RETURN AT FINISH OF RECORD MODEL PS-X7
http://www.youtube.com/watch?v=PS6g9rQRF9M The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own.
Jan 31, 2011 | Sony Audio Players & Recorders
The wires connecting the play stop & cue have come loose on my optimus LAB 1100. I need a diagram to show me where to hook them up PLEASE!!!
The Levitator is a tone arm "auto lifter" for turn tables and record players that do not have an "auto-return" feature, or has one that is broken. If your needle rides in the "wax trail-off" area of a record it can damage the needle, along with making a horrible noise. It is not enjoyable to have to babysit your records and manually take your tone arm off the record the moment it is done. The Levitator does it for you so you can relax and go about your business. When the record is done the tone arm trips the lever triggering the lifter to raise your tone arm/needle off the record. It is designed with adjustable height to fit any turntable. These are available for sale through Ebay,or please see video to order your own. http://www.youtube.com/watch?v=PS6g9rQRF9M&feature=mfu_in_order&list=UL
Jan 24, 2011 | Audio Players & Recorders
Broken needle on thorens TD 158 turn table.
Needle is a term used with 'record players' from the 60's. A turntable has a Phono Cartridge with a stylus. Depending on the brand / model of said cartridge the stylus may be replaceable. The cartridge certainly is. The tonearm is a delicate precision mechanism that will last lifetime if handled properly.
If you don't understand any of this I discourage you from taking any further actions without a knowledgeable mentor / technician looking over your ahoulder.
Mar 22, 2010 | Audio Players & Recorders
Sears Tape deck/Turn table skipping!
Hi the pennies will mess up the stylus. There should be an anti skate setting at the back of the turn table, a round adjustable bit with numbers, increase the anti skate and then use the balance weigth (weight right at the back of the arm that turns to get the weight right. Set the anti skate with the tone arm light, then increase the weight a bit. Hope that helps
Jun 14, 2009 | Technics SL-1210 Turntable
Skid problem.
My first guess would be the weights as well, try and make sure you are adjusting them correctly. I have not seen worn needles skip that bad but some tracking problems can occur. The loss of SQ can be interpreted as the weights being off balance, so as the needle gets further away the sound quality and intensity decreases. That combined with your severe tracking problem makes me believe your weights are off. You should still check into the needles- for two reasons (make sure the tables are on a stable and level surface as well).
1- The needles may not be the right ones (DJ's often switch them around to get different performance)
2.If the needles are subjected to a lot of tracking problems they will wear quickly-Good luck
-Dynami
Mar 31, 2009 | Audio Players & Recorders
Playing songs backwards wit serato scrach live
I got it partially fixed. The black wire from the tone arm was broken so that been solder back on place nd the rca also the song is playing foward on channel 1 only, thats a start! New problem accuring now! Can't use that table to scarch now caus every time i do so the song goes foward only??? No back and forth in the sound??? I'll get a new tone arm and it should get everything better!
Dec 09, 2008 | Panasonic Technics SL-1200MK2 Turntable
Emerson NR305TT - Replacement Turntable Needles
I have the same model. Though I haven't replaced the needle yet, I was able to remove the broken one. You'll see that the arm has a red plastic attachment. It houses the needle in a very thin strip of something like electrician's tape. There is a very small separation on the front (end of the arm facing you) of the tone arm, where the arm (black plastic) and needle "cartridge" (red plastic) come together. I used a metal nail file and pried them apart very gently. At this point the red plastic "cartridge" with the broken needle was hanging but still connected on either side. The red plastic "cartridge" is made with tiny plastic 'bumps' that pop into indentations built into the black plastic of the arm. Again, using my metal nail file, I simply held the arm and pried the red plastic "cartridge" away from one side. It popped off the other immediately and fell away from the arm. Voila!
Hope this helps!
May 29, 2007 | Emerson NR305TT CD Shelf System
81 people viewed this question
 Grubhead
Grubhead
