Question about Janome D'cor Excel 5018
JI have a Janome 1100, and I have a problem with the bobbin case. I will be into my embroidery project and the bobbin case will jump and turn around sometimes causing my project to turn, and the needle to go into the bobbin case causing rough spots that lead to bobbin case replacement(expensive when done frequently). I have used pre wound bobbins, bobbins I have wound myself. I have slowed down the stitch speed to not cause pulling. I am very careful when threading the machine and keep the machine well maintained. What is causing this problem?
  • Anonymous Mar 31, 2014
    took the whole bobbin section out of machine difficult to get back now needle jams
  • 35 Answers
When you put in the bobbin case, be sure to press it in firmly until you hear it click into place. If you can't press very firmly, or are afraid of hurting your machine, simply lift the latch from the bobbin case, holding it open while you firmly insert the case into the machine. Then release the latch. You should be good to go. Hope this helps!
Posted on Aug 16, 2008
My bobbin keeps jumping up and down in my Janome Platinum 760 and the stitched aren't being formed. Also noisy. Have cleaned out bobbin case etc.
hi have you replaced the bits back in the same way as if fitted upside down or back to front will cause jumping and missing stitches also make sure the bobbin it fitted in it case the shape of 9 if not it will not sew properly hope this helps
Jan 02, 2018 | Janome Sewing Machines
My Janome 8050 bobbin case is jumping out of place. The thread is wrapping around the bobbin case and getting stuck, bunching up, and shutting down my sewing progress. It ties the needle up.
check for the retainer action of the bobbin case to see in there is a part broken off that holds the bobbin in the case or carrier
from what you describe , with the thread bunching up etc, I suspect that the needle thread tension is too loose and causing the problems
if so then the bunching and problems can be from the bunched thread pushing the bobbin out of position
take it in for a service and if necessary , repair
Dec 20, 2016 | Janome Sewing Machines
My new Janome rewound bobbin is jumping as I am sewing. Why and how to fix it?
Make sure it's the correct bobbin for your make and model machine. Very easy to confuse them if you have more than one machine.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Janome Horizon Memory Craft 12000...
How do I fix my MB4 that has locked after thread caught around bobbin. There must still be hidden thread, how can I fix please, regards Pam
IF THE GEARS ARE PLASTIC, THE LOCKING MAY HAVE CAUSED THE GEARS TO JUMP A TOOTH AND THREW THE TIMING OF THE MACHINE OFF. IT MAY NEED TO BE SERVICED.
Nov 20, 2014 | Janome MB4 Four Needle Embroidery Machine
Janome mb4 why does thread ravel whiles embroidery a project
check for burrs on the needle plate and in the bobbin area
also check for burrs in the threading area,like one of the thread guides
Oct 15, 2013 | Janome Sewing Machines
Janome MC11000 - my bobbin case becomes dislodged
My bobbin case was jumping all the time...had it in for repairs and would bring it home and even though the tech had attached a test sew piece with different colored bobbin and top thread I could not get it to sew without the bobbin jumping. I thought that he had lied about that being sewn on this machine...finally, I found that you should start with plenty of thread in your hand when threading machine...so that once you feel it click into the tension...DO NOT PULL the thread, it pops it out of the tensioner...just loosely thread and hold tension with your thumb and forefinger while using the needle threader.
Feb 14, 2010 | Janome Memory Craft 10000
Thread keeps breaking
Have you checked any edge the thread might contact for knicks which should be files or sanded down? Also, I had to replace my bobbin case after a number of years as it had kind of stretched out and allowed my bobbin to pop around and consequently broke many threads.
Feb 07, 2010 | Janome Memory Craft 9000 Computerized...
Bobbin problems
Are you using a size "A" (Class 15) bobbin? If you are using pre-wounds and they are not this size... they will jump around alot. The size of an "L" is very similar, but they are not as tall (height off the table when laying flat on the round side... like when sitting in the bobbin case.) There are tricks to using the thinner bobbins... See if you have a "taller" size "A"/Class 15 and if that corrects the trouble. tjsews2008@gmail.com
Feb 04, 2009 | Janome Memory Craft 10000
Janome 10000 bobbin case problems
make sure you hold the cotton so it doesn't go under and ball up
Feb 03, 2009 | Janome Memory Craft 10000
Embroidery-thread covered by bobbin-thread
Sounds like a bobbin tension problem.  Check to see if a small thread is caught in the bobbin case or try a new bobbine
Feb 05, 2007 | Janome Memory Craft 10000
Sewing Machines Logo
244 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
