Computer beeps 3 time when turned on.
Computer was on line and then went dark. turned unit off then back on got cooling fan and 3 beeps.but, nothing on the monitor. i cleaned out cpu and removed graphic card and restarted all worked well for one day now same problem.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 114 Answers
Normally 3 beeps (might be one long and two short) means it's the video card, try another slot if possible.
If no other slot is available, then clean the contacts off the graphics card with a #2 pencil eraser, taking care not to touch the contacts afterward, and then re-insert the card.
if still nothing, try another video card.
Posted on Jun 22, 2008
Outside unit will only run for a short amount of time with A/C before the fan stops turning and starts humming, squealing/screeching and the top of the outside unit gets hot.
The bearings are bad in the motor and after the fan runs enough it eventually gets hot, making the bearing screech and the fan locks up. Need to replace motor again. See if it has a warranty. The reason it gets hot is because the fan is what removes the heat from the coil and if the fan isn't running there is nothing to cool it off so to speak.
Apr 19, 2016 | Heating & Cooling
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
04 Jeep liberty can only feel air conditoner when jeep is moving the other day the jeep beeped thee times and the overheated engine light was on now its off
Sounds like a fan issue. The engine and A/C are only being cooled when the vehicle is moving and air is flowing across the radiator and condenser. I would start car with hood up and check that fans cycle on as the engine gets warmer and a/c is turned on. Don't let it get too hot, and keep clear of fans and moving parts.
Apr 28, 2017 | 2004 Jeep Liberty
How to repair start-up on my computer
How long is shortly? If it runs and brings up the Windows Desktop and you are allowed to work for 10 minutes or longer then it shuts down, most likely the laptop is overheating. One way to tell if it is overheating is to immediately try to turn it back on after it shuts off. If it will not boot back up, it's overheating. If you let it sit and cool off for a while, then try to boot it back up and it does it successfully, it's overheating.Causes of Overheating:1) Dust all inside the computer. Fans clogged with dust, dust around the vents.2) Fan not working 3) The Thermal Past around the CPU has dried up or is too thin the keep the unit cool.When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 31, 2012 | Gateway Computers & Internet
So I have a Emachine t2984 model... It was working perfectly till out of nowhere I heard two beeping sounds coming out the computer then CPU shut completely off. So I went to tried to turn it back on but...
you have done the right thing by cleaning the dust from your computers fans you should continue cleaning the dust from your computer as dust will cause static which can cause a computer lots of unforseen problems
the beeps are post during post the very first work is done by the ram,all the memory in the ram is first transferred to the hard disk,and remains active untill turned off.
make sure that your RAM is securely seated
test or replace all the leads that attach to your hard drive make sure the connections are secure including electrical extensions + IDE,SATA the ones that attach from your
((motherboard to hard drive))
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps keep up the good work
Mar 28, 2011 | E-Machines Computers & Internet
I get 3 beeps on start up and a continuous dark blank screen
On the IBM Thinkpad 3 long beeps should mean "critical thermal" After it cools down will it start again?
http://www-307.ibm.com/pc/support/site.wss/MIGR-39706.html
Is the fan still working blowing air out the back or side?
Feb 02, 2011 | IBM ThinkPad T40 2373 Notebook
My Thinkpad G41 does not boot up, nothing comes up
Hello
Have you tried swapping out ram modules? This would probably be the cheapest. And, a faulty ram module gives a beep code. Try it, and let me know.
Kind regards
Andrea
Apr 21, 2010 | IBM ThinkPad G41 Notebook
Deep freeze computer inresponsive
it sounds like your computer power supply went bad.
go to your local computer store and buy a power supply, install it and you should be up and running.
that is if you didn't fry everything from running it without the proper cooling.
make sure that you have proper cooling fans in your computer, a fan outside will not do it.
It sounds like your power supply fan stopped working and it just got to hot and died
May 24, 2009 | E-Machines eMachines Desktop PC
Loud Fan, Three Beeps, Black Monitor and No Keyboard response
I have the same model after youlet it sit for a long enough period to cool down it will come back on and work normal, it is a cooling problem called gateway and they confirmed this theproblem I ran in to was what fan this computer has 3. temp fix I used was to remove the tower cover to allow better air flow try this till you can figure out what fan is messing up
Jun 02, 2008 | Gateway GT5404 PC Desktop
Computers & Internet Logo
236 people viewed this question
David Payne
David Payne
