Question about Linksys Wireless-G WRT54G Router
Thank you for your help. Still a problem.
Thank you for your help. Yes, my connection worked before, for 4 months then it quit working. I've already tried your best solution and it doesn't work. However if I plug my modem directly into my computer it works fine. If it's a problem with my network, how do I fix that? Can you help with this too?
Thanks again, for helping.
Christine
  • tracywoo Jun 30, 2008
    Connection works sometimes but not always. Keep getting a message from windows that there is an IP address system or network conflict with another network
    Problem Solver:
  • 12 Answers
My suggestion would be to consult whomever initally set up your network as some of the wireless settings may not be setup or working correctly. Alternativly you may want to get quick setup guide (you can get it from linksys's site if you do not have it anymore. Make sure you print it out as you will be offline and then you may want to reset the settings on your router to do this find on the back of the router there is a settings button, using a paperclip or pen tip hold this in for 30 seconds and let go, the router will blink and reset it self for the next 20 seconds. then connect your computer to the back of the router using a network cable and follow your quick setup guide to get back on. This should get you back up and running. If all else fails contact linksys support for help.
24-hour Technical Support
800-326-7114
(toll-free from US or Canada)
Posted on Jun 23, 2008
How do I fix this: Printing works but suddenly Scan function doesn't work?
I am a Brother employee working for the software technical support department.
We have a solution for your scanning issue posted on our solution site.
Description of Problem 100000024547
I am unable to scan in Windows 7 using the Wireless Network connection. What can I do?
Brother Software Technical Support
http://www.brother-usa.com
Jun 29, 2014 | Brother MFC7860DW AllInOne Laser Printer
I have a 1994 F-250 xl, 5speed Manuel and its a gas job! I've only had it a few month and I've already had to change the release bearing 4 time(about once a month) why would the release bearing...
Release bearing are only supposed to work when you have your foot on the clutch pedal. If it keeps burning out then it is overworking. Some faults can be clutch pressure plate springs too strong. , Worn fingers on the pressure plate. No freeplay between clutch slave cyl and throwput arm. Faulty M/cyl or it can be as simple as driving with you foot resting on the clutch pedal instead of the foot rest
Jan 26, 2013 | Cars & Trucks
Crusie control does not work on 2011 gmc sierra 1500 and I've already replaced the switch?
If the switch is replaced,then it can be wiring issue or faulty cruise control board.But as the switch is replaced,get the voltage at the switch tested to confirm the switch is actually receiving voltage.If no voltage received at switch power supply wire then ,apply external 12 volt power to the cruise control switch wire and then see if cruise control comes ON.If yes,then you know wiring is issue.
On this case, to troubleshoot this problem, there are solved help links. Click the link directly and refer the details to solve this problem yourself, with help of diagrams: ------
Ford ranger cruise control not working? http://technoanswers.blogspot.in/2012/02/ford-ranger-cruise-control-not-working.html
Horn and Cruise control quit working?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working.html
Horn and cruise control not working on Plymouth Grand Voyager?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-not-working-on.html
Horn and Cruise control quit working on 2003 Jaguar S-Type?
http://howtobyme.blogspot.com/2011/11/horn-and-cruise-control-quit-working-on.html
Cruise Control stops working, Excessive cranks to start the engine and RPM goes max 2500
http://whoisbyme.blogspot.in/2012/07/cruise-control-stops-workingexcessive.html
Cruise control stop working on 1994 Ford ranger?
http://technoanswers.blogspot.in/2012/02/cruise-control-stop-working-on-1994.html
Cruise control not working?
http://schematicsdiagram.blogspot.com/2011/12/cruise-control-not-working.html
1996 Ford Explorer: Cruise Control Wiring Diagram?
http://schematicsdiagram.blogspot.in/2012/06/1996-ford-explorer-cruise-control.html
These will help.
Thanks.
Nov 28, 2012 | GMC Cars & Trucks
I just bought a top-end MacBook Air 13.3" 4 GB/256 GB for presentations. I also have a Dell M410HD projector, also quite new (a few months old), which works great with the two PCs (one new, one old)...
They (Apple) might be right. It could be that the projector is damaged, like the bulb, or it could be incompatible with your computer, but I don't think that is the case. Try taking the projector to a computer repair place.
May 17, 2011 | Apple MacBook Pro Notebook
I have a pop up message that states, "This
if you've already restored it, you can take it to the store to have it replaced
Mar 29, 2011 | Apple iPhone 4 Black Smartphone
High-low beams not working
Check for headlight relay and fuse. Some cars have separate circuits for head light flasher and normal high/low beam. From your description, I would suspect a bad connection to/from relay or relay itself.
Jul 07, 2009 | 2006 Hyundai Accent
Nokia 3110 starting prob!
solution for the 3110c when it restarts is connect the cable before it goes of and you have to be quick then its shouls come up with nokia mode - data storage and picture bridge or some times diffrent press data storage over and over until it says transfering data then press quit and your phone would be working...
Sep 03, 2008 | Nokia 3110 Cellular Phone
Black and white
Yes there is. Unless there is a systems mode to turn the reception to PAL, you will not be able to use this set there. Good Luck
Mar 31, 2007 | Westinghouse LTV-19W3 19 in. LCD...
Linksys Wireless-G WRT54G Router Logo
27 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
