Question about GE 27831FE2 Phone
No dial tone on one of the headsets
I have two cordless phones and I switched the batteries and only one head set will dial out. The other says unavailable. What do I do?
  • 3 Answers
You have to put the second phone 20 sec on the base unit. and that its!
Posted on Jan 28, 2009
How to switch from pulse to tone dialing
Well, cannot find ia5862...but from ia5863 which must be similar; Manual at http://www.scribd.com/doc/64707312/Vtech-Phone-Ia5863-Manual-r2, it says... Set the dial mode
If you have touch tone service, the phone is ready to use as soon as the battery is charged. If you have pulse (rotary) service, you'll need to change the dial modee• Press
PROG.
• Press o runtil the screen displays
DIAL MODE:
and the current settings• Press
SELECT.
The current setting blinks • Press or to select
TONE
or
PULSE.
• Press
SELECT
to save
Hope it helps, sounds like the phone should ALREADY be on tone dial out of the box.
Jul 31, 2014 | Vtech 5.8GHz Cordless Phone with Digital...
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
No dial tone
try pulling the batteries out for 24 hours and then putting them back in. It should reset all the software and it should sync back up.
Jul 25, 2008 | Uniden DCT646-2 Cordless Phone
Dial tone
I disconnected the RadioShack phone/answering machine and plugged in an old phone. At first I didn't get a dial tone, but in a minute or so, I did get one. I doublechecked the connection with the incoming phone jack. (I had checked this before, but didn't see anything wrong.) Again, I didn't see anything wrong, but maybe that did it. Also, when I disconnected the RadioShack from the incoming phone jack, I disconnected from my computer (I used to have dial-up connection).
Don't know which of my actions worked, but now I have dial tone on Radio Shack.
Hoooooooray!!!!
Jun 22, 2008 | Radio Shack 433575 Cordless Phone
GE cordless model 26928GE2-A
Dial tone is OK, but can't dial out
• Make sure the tone/pulse setting is programmed
correctly.
TONE/PULSE DIALING
1. Make sure the phone is OFF (not in TALK mode).
2. Use the CID/VOL left (-) or right (+) arrow button to
scroll to 1TONE or 2PULSE, or use the touch tone
pad on the handset to enter the desired setting. For
example, to choose TONE dialing, press the number 1
key. 1TONE is the default setting.
3. Press flash/program to store selection. You will hear a
confirmation tone.
Feb 06, 2008 | GE Cordless Phone 900 MHz
#43-3906
alright check with ringer volume and change the phone cord and reboot the base and check
Oct 09, 2007 | Radio Shack 433575 Cordless Phone
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
How to switch phone to tone
I found a manual from AT&T that had the information I needed. Thanks!
Sep 18, 2007 | GE 26920 Cordless Phone
GE 28111 Twin Cordless Phone "Line In Use"
I had the same problem. I went to each handset and pushed the talk button. After I got a dial tone, I pushed it again to stop the dial tone. The message went away.
Aug 14, 2007 | GE 28111 Cordless Phone
GE 27831FE2 Phone Logo
101 people viewed this question
Top GE Lands Phones Experts
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
