Question about D-Link DIR-625 (790069292637) Wireless Router
Cannot get the wireless going
Hey, it won't let me connect to the wireless on my laptop, i know the network key, and it saids that i have 5 bars of strength, but it just wikll not connect, any ideas?
Uninstall and reset everything. you probably had the laptop wireless button in open status when you did initial install, follow the manuf guide guide during setup.
Posted on Jun 22, 2008
I have an acer extensa 5620z and netgear dg834v5 modem/router. I can connect via ethernet, but even though i have set the router without security, the laptop detects the wireless network, but won't...
This is worked for me on Vista:
1. Goto Network and Sharing Center.
2. Click on your Wireless Connection "View Status".
3. Click on Propertes.
4. Uncheck the option that says "Internet Protocol Version 6"
When I did this, my wireless began working again.
Jun 11, 2011 | Acer Extensa 5620 Notebook PC
Tip
How to configure the wireless connection ?
Configuring the Wireless connection
Check the Following
1) Wireless Switch of the Laptop is off (Wifi is Off)
it is located somewhere on the edge of the laptops
or Fn+F2 might turn the switch ON and OFF
2) The setting required to configure wireless connection
Check the following steps
Windows XP
1. Click on the Start Menu, and click on Control Panel.
2. Find and double-click “Network Connections” to open up the list of connections that your 3. computer uses to connect to the internet.
4. Right click “Wireless Network Connection” and select “Properties”.
5. Go to the “Wireless Networks” Tab
6. Check “Use Windows to configure my wireless network settings”, if it isn't already.
7. Click “Add” to add a wireless profile.
* Enter in the Network name (SSID). (It was your desired SSID from Step 6 ).
* Uncheck the box “The key is provided for me automatically”.
* Put in the “Key 1” code from Step 7 into “Network key” and “Confirm network key”.
* Push “OK”
# Open Internet Explorer (with the computer connected to the Router)
# Enter 192.168.1.1 into the Address Bar, push Enter
# Leave the User Name field blank
# Under the password field enter “admin”
# Click “OK”
# Click “Wireless”
# Click “Basic Wireless Settings”
# Enter a desired name into the “Wireless Network Name (SSID)” field
# Write down your Wireless Network SSID, it will be used for later.
# Click “Save Settings”
For WEP:
* Click “Wireless”
* Click “Wireless Security”
* Select “WEP” in the “Security Mode” field
* Bubble “1” under the “Default Transmit Key” field
* Select “128 bits 26 hex digits”
* Enter a desired passphrase into the “Passphrase” field
* Click “Generate”
* Carefully write down the code generated in the “Key 1” field on paper, and store it in a safe place. THIS IS YOUR WEP KEY, it will be needed later on.
* Click “Save Settings”
on Jan 22, 2010 | Computers & Internet
How do i connect to my laptop
If you want to connect your laptop to the wireless router you can do it either wired or wireless, if you prefer to connect it wirelessly you need to know the Network Key (Passphrase) and the Network Name (SSID) of your router. For you to access your router you need to type 192.168.1.1 to he address bar of your browser and it will ask you for a username and password. The default username is "leave it blank" and the default password is admin. Go to the wireless settings page check the SSID and the Network Key. Bare in mind that you can personalize your SSID and network key for you to easily remember it. Now that you already have the information needed go to your computer click on START then CONNECT TO, select the SSID of your router click on connect then enter your Network Key.
Thanks for using Fixya.
Jan 27, 2011 | Linksys Wireless-G WRT54G Router
I had a computer problem and now my netgear won't work. When I got my desktop up and running again and now we can't connect to the internet on our laptop, wirelessly. For some reason the Netgear wireless...
Please follow the below steps to configure settings:
1. Open a web browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually by typing 'http://192.168.1.1' or 'http://www.routerlogin.com' in the address bar.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Select security options as 'WEP (Wired Equivalent Privacy)'. Set the 'Authentication Type' as automatic. Set the 'Encryption Strength' as 64-bit.
6. In Key 1 type a 10 digit number. Apply the settings.
If your laptop has Windows XP then perform the below task:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply.
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab.
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. Under Preferred networks if you see any name in the list then highlight the name and click remove. Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
7. Highlight thee SSID from the list that you want to connect to.
8. Type the security Key here and click on the 'Connect' button.
9. You should have successfully established a wireless network connection.
If your laptop has Windows Vista then perform the below task:
1. Click START, Click Control Panel then click classic view in left hand side
menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
If your laptop has Windows 7 then perform the below task:
1. Click START, Click Control Panel.
2. In the main screen, open up NETWORK AND INTERNET.
3. Click on Connect to a network.
4. Select your network and connect to it. If you have a Password setup on the router enter the security key.
5. This should setup the wireless network.
Hope the above steps allow you to resolve the issue. If you need any further help then revert back so that we can assist you further.
Regards
Anand
Apr 12, 2010 | NetGear WGR614 Wireless Router
I have a new laptop and am unable to access wireless with the linksys router ( it worked on my old pc, before it died) The infor on my router reads: linksys wrt100 range plus wireless router
Check if the wireless security is ON. If yes, then you will need to know the wireless network key.
To check the settings on the router on a connected computer, use a web browser and in the address bar type: 192.168.1.1.
By default leave the username blank, then the password is admin.
Go to Wireless, take note of the SSID.
Then go to Wireless security, copy the pre-shared key/ wireless network key.
On your new laptop, view the available networks, you should see your SSID. It will prompt you to enter the network key, just type the wireless network key.
I hope this helps!
Mar 23, 2010 | Linksys WRT160N Wireless Router
How to connect wirelessly on Toshiba
try going to your device manager, on the network adapter field, make sure you see the wireless adapter and enable it.
Feb 14, 2010 | Computers & Internet
Win xp desktop connected to wrt54gs router wants laptop running win 7 to connect wirelessly
We need to know the wireless settings on your router before configuring the laptop.
To check the wireless settings, access the setup page of the router by using the desktop's internet browser. In the address bar, type 192.168.1.1.
Default login is: leave the username blank, then the password is admin.
Once you are in the setup page, go to the Wireless tab.
Take note of the wireless network name (SSID).
Then go to the Wireless Security tab. Take note of the wireless security settings and the network key (if wireless security is enabled).
On your laptop, in the lower right corner of your screen you will see an icon that looks like this moz-screenshot-1.jpgc147bd5.png.
Click the icon and you will see a list of available networks.
Select the SSID of your router then click connect.
If the wireless security is enabled, it will ask for the security key. Type the wireless network key, then click ok.
It will then connect wirelessly.
Dec 26, 2009 | Linksys Wireless-G WRT54GS Router...
No network code for router want to connect my laptop to it
Hello friend,
i guess that you are talking about wireless code, in this case you will need to connect the laptop to the router via Ethernet cable to configure it and then unplug the cable and use the wireless.
so you connect the ethernet cable between the laptop and one of the ports on the router from 1 to 4. then access to the router web interface which is usually 192.168.1.1. then go the wireless tab and name your wireless access point and put a password to secure your network. After that you can unplug your Ethernet cable and use the wireless on your laptop to connect your router wirelessly.
Best Regards,
Oct 31, 2009 | Linksys Wireless-G Broadband Router
Cannot connect new laptop to wireless network. Belkin Wireless N
The wireless settings on the laptop and the router should match. To check the settings on the router you need to access the setup page by typing 192.168.2.1 in a web browser's address bar.
By default the password is blank.
Click the Wireless tab. And take note of the SSID or wireless network name.
Go to Security, then Wireless. If the wireless security is enabled, copy the network key or security key.
On the wireless computer, you should detect SSID and if wireless security is enabled, connect to it with the correct security keys.
Hope this helps! Good luck!
Feb 22, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Need help setting up linksys with laptop
do not worry about it..
if you are still online with the desktop..
Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router’s IP Address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
If should ask for a user name and a passwd.. if it is not ..try with 192.168.2.1 or 192.168.5.1 if still not..
then for a dsl connection you might have changed the ip address of your router..
To check ipaddress
click start then run and in run type cmd and click ok..
you would be in a black dos prompt..
type ipconfig and press ok.. you would find the ipaddress
Step 3:
Step 4:
then press [Enter].
Step 5:
When the router’s web-based setup page appears, click the Wireless tab.
Step 6:
Look for Wireless Network Name (SSID) and if it’s still set to ‘linksys’ change it to something unique then click Save Settings. or else if the name is changed leave it..
ans below the wireless tab select the Wireless Security sub tab.in the blue bar. check for the defalt transmit key and key 1 if its already setup, then make a note of the key and go to Step 12 if not setb up wireless security first
Step 7:
Select any number under the Default Transmit Key to determine which key you’ll be using. In this example, we selected number 1.
Step 8:
Select 128 bits under WEP Encryption.
Step 9:
Type a wireless network password of your choice such as “MySecretKey”, then click Generate.
NOTE: You should come up with a password that is unique for your network and is a combination of numbers and letters up to 26 characters.
Step 10:
The result will be a string of random characters. Copy the resulting string since this will be the key to your wireless network.
NOTE: Do not give this key to anyone. This will be your wireless network’s key.
Step 11:
Click 3695-017.png.
Step 12:
now go to your latop. right click wireless network connectios icons and click view wireless network.. (if it is xp os)
you would fine the name of the n/w try connecting to it, it would ask for the n/w key enter the 26 digit key which you have setup and click connect, you would go online with your laptop..
Nov 16, 2007 | Linksys Wireless-G Broadband Router
D-Link DIR-625 (790069292637) Wireless Router Logo
52 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
