Question about Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator
Water Dispenser Quit - MFD2560
This fellow catriv deserves a Guru rating. My better half had reset the temp control for the refridgerator compartment to colder. After a week or so the water dispenser apparantly froze up. I took out the crisper drawers and put some heat to the reservoir with a hair dryer as suggested. Everything is working okay now. THANKS !!!!! from League City, Texas
  • Anonymous Aug 23, 2008
    how do you ajust water flo to water dispencer
How do you ajust water dispencer
Posted on Aug 23, 2008
How big is the reservoir for the water dispenser? Also, what is the normal temperature of the water being dispensed?
??? You never gave make or model and your mouth is that accurate to tell a 17 degree difference in water temp?
Jul 02, 2015 | Refrigerators
My Aman side by side quit dispensing water. It
Does your fridge have a small tank inside the food compartment? If so, the water may have frozen in the tank and the problem can be solved if you take a blow dryer and warm the tank. That's what happened to mine and with a temp adjustment to keep the food compartment a bit warmer, the water doesn't freeze.
May 30, 2010 | Amana 22.6 cu. ft. Side-By-Side...
The meat and veggie compartments are freezing the food and our water dispenser just stopped working. Do we need to manually dethaw the refridgerator (Kenmoore side by side)?
check your thermostat controller, it might malfunctioning that why your refigerator neverautomatically turn off when it reaches the cooling point
Oct 31, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore Refridgerator leaking water into refridgerator compartment from freezer compartment
You most likely have a clogged drain. When you freezers goes into defrost every 8 to 10 hours. The frost that is melted during the defrost drains from the freezer either down through the fridge or out the back and down. Either way it drains into a pan under the fridge. This tube is either clogged or the drain it's self inside the freezer is. Most of the time I find peas stopping the water from draining from the freezer. When the water can't drain it leaks through the bottom of the freezer into the fresh food section of the fridge. You will need to fix this because it will cause other problems. The water that cant drain from the freezer refreezes and will end up destroying the foam in the bottom of the freezer. Water will also leak onto the controls located in the part between the freezer and fresh food section ruining you controls.
Please rate this solution
Sep 01, 2009 | Kenmore Refrigerators
Ice maker quit qorking
The chute where the ice drops through could be icing up, try removing the I bin and cleaning the ice build up out.
Jun 16, 2009 | Maytag MSD2456G Side by Side Refrigerator
Water drains from freezer compartment into refridgerator
If the freezer is on top then empty out the freezer and remove the bottom and back liner of the freezer compartment usually phillips screws. In the back you will see the freezer coils along with a defrost element. Below these two items u will see a drip tray that collects water from the coils on defrost cycle, in the center of the pan will be a drain hole that connects to a hose that leads to a pan under the refrigerator.Normally the water is collected there and evaporated. The hole in the tray in the freezer is clogged. Thaw it and clean it until you can pour water in it and it goes to the pan down below. please rate me
Jan 09, 2009 | Refrigerators
Refridge compartment warm not cooling
I hope the following helps.
Turn the entire control system off for at least two minutes. This will give the computer module time to reset to factory default. Turn of to desired level after two minutes. Should that not work then there is a problem with the timing relay. They relay is brand specific, meaning take the model number to the parts store for a new one.
Your compressor should be fine. You may also remove the power by unplugging the refrig.
CAUTION: Before removing the relay the power to the fridge must be OFF. Failure to have it in the off postion can cause the new relay to short which can lead to mkore problems. So UNPLUG the fridge, remove the relay, replace the relay and then plug fridge back min. Set control to desired cooling level and wait a couple hours. That should do the trick.. IF not then there is an issue with the processor module.
Jan 04, 2009 | Refrigerators
WATER QUIT RUNNING IN DOOR
Okay. My appliance is around four years old. The first time the water quit working was about a year ago (ice cubes / dispenser was fine). I just let it go and didn't worry about it. One day months later, I found it functional again. That lasted about a month or two, then it recently quit again. Tonight, I located the water supply line coupling under the unit on the left side under the freezer door, about five inches from the hinge. I separated the coupling (push lock type) and pressed the water dispenser lever. After a few seconds, the water flowed out just fine. I re-attached the coupling, turned the freezer coldness selector to 0 (off) opened the freezer door and fetched my wife's blow dryer. I ran the dryer along the inside of the freezer door near the black door seal frrom the hinge up to the water/ice dispencer compartment. I also ran it all along the back of the dispenseer compartment to the handle side of the door as I am unsure of where the water line runs. After about ten minutes of this, I attempted to dispense water with no luck. I continued with the blow dryer until the plastic and even the door seal were very warm to the touch. I closed the door and attempted to dispense water once again, and this time it worked. I turned the coldness selector back on. This time I set the freezer to 3 and the fridge to 7. I ran several cups of water through the dispenser since it's been sitting in the line for a while before drinking any. As for the "reservoir," I don't where or if one exists, but heating up the inside of the door from hinge to dispenser worked perfectly. Hope this helps someone!
Cheers!
Nov 26, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
I bought a Hotpoint refrigerator in early 2004 but did not have it delivered until late 2005. After about a year the water dispenser quit working. Ice dispenser would just drag at times. Then the water...
Friend,
ngfam1 At your service!
I came to your service on fixya.com some days ago!
And gave you some good advice!
But, I did not receive a rating from you yet!
Can you please give me a rating at our fixya.com site!
Bless, You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF
Jul 09, 2008 | Hotpoint HSS25GFP Side by Side...
Maytag MFD2561HE Stainless Steel Bottom Freezer French Door Refrigerator Logo
177 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
