Question about Amcor PLM-14000E Portable Air Conditioner
Not cold enough
Hi
just got an amcor off ebay and it does not appear to blow the air out cold enough. I thought it should be icy cold, whereas on 18, the lowest temp, it just seems a little cool. Is this normal or is there a problem
thanks
Nero
PS the model I have is the one with a round blue LCD display on the front, similar to the picture on the home page of this web site
    Scholar:
  • 104 Answers
Check the air coming out with a thermometer. It should be approximately 20-26 degrees colder than the air being sucked in. If it is less than that but it is cooling, there is most likely a freon leak in the system causing it to be low on charge
Posted on Jun 23, 2008
Hi, i just bought a second hand amcor air conditioner but it dosent send hot air, what can be the problem?
Air conditioners normally blow cold air, unless it has a built in heat pump. You should post the model with your questions.
Jan 08, 2017 | Amcor Heating & Cooling
Amcor a12000e not blowing out cold air
Halo
Inside of the unit you will find (see attatchment) a feeler bulb witch will be faulty. You might only find 1 feeler bulb witch will be highly rare most of them has two, one for heating and one for cooling.
Now what happens is on the evaporater where it will be located is if on heating the fan does not start until the bulb picks up that the evaporator is warm enough same goes for cooling, only defrence is that it starts the fan when the evaporator is cold enough.
Hope this was helpful.
Regards
Jun 25, 2016 | Amcor Heating & Cooling
Fan works but heat blows cold enough to make icecycles
Heater core is most likely plugged/restricted
Nov 30, 2013 | Saab 9 3 Cars & Trucks
Air Conditioner isn't blowing cold air
There are a few thing's that can cause this, if the evaporator coil in the a/c is blocked a little, you could get a little cool air, it's like having a dirty filter. If the condenser coil is blocked, you won't get cold air. If the refrigerant is low, you won't get cold, cold air.
Jul 19, 2013 | Amcor Heating & Cooling
The unit does not blow cold air any more. Inside is sometimes hotter than outside. will be 85 inside but 80 outside. Have thoroughly cleaned filters, but no change. "comp" light is on
Hi, The compressor has gone bad and it will cost more to replace it then the unit is worth... buy another unit and buy anything BUT an Amcor unit... they are junk!!
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 12, 2011 | Amcor AF9000E Portable Air Conditioner
Laid amcor plm1200e on its side briefly and now it is not blowing cold air. Please helpl
That runs oil into the exspansion device....
let it set upright overnight and it might start again...
heatman101
Aug 30, 2010 | Amcor PLM12000E Portable Air Conditioner
Amcor port. Air cond. Only blows cold air for 30 seconds then just regular air.
Sounds like your compressor is turning off possible due to low charge-high head-bad start or run capacitor need a little more info
Jun 11, 2010 | Amcor 12000 Air Conditioner
Ive got an amcor air conditioner, will it blow hot air aswell as cold,
If it blows hot and cool air, it means that you aircon is
not having an isolation of the evaporator and condenser
air. Please have a technician repair the air leak. Hot air from the condenser must be separated from the cool air
of the evaporator. Hope this will help you.
Jan 04, 2010 | Amcor PLM-14000E Portable Air Conditioner
Amcor PLM-14000E Portable Air Conditioner Logo
544 people viewed this question
Top Amcor Heating & Cooling Experts
Michael Youngman
Michael Youngman
Tim Whalen
Are you an Amcor Heating and Cooling Expert? Answer questions, earn points and help others
