Question about Venturer PVS1950D Car DVD Player
LOGIK LOGLM101DU DVD/USB/HI FI SYSTEM
I bought a dvd hi fi system on ebay and the player will only read certain discs how can i solve this problem?
  • redraven4875 Sep 30, 2008
    This model has a number of little problems with it. Mine used to refuse to play certain discs, I got this message: "error disc", and on other occassions it would play them after spinning them around for 3 minutes. To be honest it is an unstable peice of hardware, currently the dvd drive has refused to open (this happens alot, so make sure you don't try to play your favourite disks in this model, you may not see them again), and now the machine itself has refused to turn on, (although that could be a problem with the fuse, however the plugs are "fused", unopenable plugs, so not sure what to do about that either.
    I think it deteriorates rapidly with frequent use.
  • Anonymous May 05, 2009
    Same here
5 Suggested Answers
snakehead
  • 1074 Answers
SOURCE: dvd reads only some music videos, no movie videos
Clean your dvd lens they might dirty.if that does not work call in a tech to adjust the lens.or replace them.good luck,
Posted on Apr 04, 2007
SOURCE: car DVD player won't read DVDs
"The DVD player show in the display "No Disc" but the laser diode is clean and the disc when is inside don't turn. I supossed that the motor of the disc is bad or disconnect."
I changed the motor but still the same fail.
Posted on Dec 12, 2007
SOURCE: Invalid disc message
I have the same problem. Very frustrading and my solution was to toss it in the trash. Unfortunately these units don't last past 2-3 years.
Posted on Apr 27, 2008
  • 49 Answers
SOURCE: My portable dvd player will not read the discs. it keeps saying no disc. the door is shut all the way and the disc spins. Plus, the disc is brand new.
The lazer is shot in it,It is not reading the info off the disc anymore, Verry costly to have it repaired,
Posted on Dec 03, 2012
This is a DVD player model SDVD7046 that i want to plug a speaker into the ear plug place?
You can't. They are for headphones only. The output level would be too low to power the speaker. You will need a hi-fi audio system to connect speakers. The DVD player will have hi-fi jacks at the back to connect to a suitable audio system.
Dec 17, 2016 | Sylvania sdvd7046 black - 7 Portable Dvd...
No disc message on a sony mini hi fi system
Bad laser , or scratched disc .try at first to clean the laser lens using cotton ear sticks moistened with saliva.
Dec 08, 2013 | Sony Multi-System Mini Hi-Fi system /DVD...
Kenwood hi fi componenet system no play error for dvd-r disc
Is it a DVD-R or DVD+R disc?
comment says -R just wanted to clarify, alot of players have trouble playing the -R discs. If you have your booklet for system, it should say in there otherwise they usually put a little sticker label, by the DVD tray with what file formats and discs it will play.
Aug 25, 2013 | Audio Players & Recorders
I have recorded a Hi-Fi video onto a DVD using a Toshiba D-VR5SC recorder and I cannot play the DVD on other DVD players. How do I solve this?
have you tried finalising the disc, you should find the section to enable this to be done in your owner,s manual. Usualy once this is done the disc can be played on any dvd player.
Jan 29, 2013 | Televison & Video
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
Got a philips hts3357 some discs play some come up no disc
unfortunately Philips DVD players are more precious/ selective on DVDs than the other brands..it is true especially with "Copied DVD"..normally an original DVD should not cause such problem..however if your DVD disc itself is not clean ( i.e.finger prints ) the reading LASER sometimes has problem to read it..
I recommend to buy a "wet DVD laser cleaner system" and clean your laser on DVD and your DVD discs as well..it is available any HI-FI store..
Take care and please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
Jun 22, 2011 | Philips HTS3357/05 Theater System
I got a LG HI FI SYSTEM. DOES NOT READ DISC.
hello,
it is either the lense of the hi fi system that may be faulty, therefore, if that is the case you take it back to the dealer that sold it to you.
or probably the disc is not compatible with the HI-FI system.
Jan 04, 2010 | Kenwood DV-6050 Multi-disc DVD Player
NOT READING DISC
Don't panic, friend. Likely you've had the unit awhile. Get yourself a CD lens cleaner from your nearest music or Hi-Fi store. Run it a couple of times. That should solve your problem.
Jan 18, 2008 | Sony DVP-NC675P Multi-disc DVD Player
DVD display indicates "no disc"
Try a lens cleaner cd, as when the lens gets misaligned or if it's quite old, it will find it harder to read a DVD as the tracks are much closer together than that of a VCD as they are cd's and their tracks are wider apart and easier to read.
Jan 11, 2007 | Sony Multi-System Mini Hi-Fi system /DVD...
Car Audio & Video Logo
725 people viewed this question
Top Venturer Car Audio & Video Experts
xxxxxx xxx
Are you a Venturer Car Audio and Video Expert? Answer questions, earn points and help others
