Question about JVC Car Audio & Video
I have a jvc 680 head unit and when i put a cd in it turns on for 3-4 seconds and then turns off and when i push the display button it shows the time for a few seconds but other then that i have no display on the screen and no function what should i do
    President:
  • 624 Answers
I am sorry to tell you this , but there is not easy fix for an end user beside pressing the reset switch. That could help by resetting the microprocessor, but I think that the problem you are having is a feed screw in the cd mech that must be re-aligned. That is a common problem with the KD-S680. You only wrote that your model was a JVC 680, but Ithink this is the model you are referring to.
It causes the laser pick up to jam in the outer most position and when you put a disc in it will try to play for 3 or 4 seconds and then shut off.
You will need to take it to an authorized JVC service center so that they will be able to look up the tech reports on that unit. This problem is listed as a common one.
You also said that you have no functions at all. Does that mean your tuner doesn't work as well?
If that is true, you may have even more problems with it.
If the problem is just the CD problem, the repair may only cost $65 or so, depending on the rates of the service center. My shop would only charge $65 if the problem is just the CD.
I know this is not very good news, but it does sound like the problem I have researched for you, so a good rating would be appreciated if this is the problem you are having.
A good rating, even when the solution is not a popular one, motivates the experts on FixYa to still answer questions truthfully even if it is not the answer people really want to hear.
Good luck with getting your problem fixed, and let me know if you need more help, I am here if you need me.
Posted on Jun 22, 2008
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
Please help!! i recently got a jvc kd-sc800 system off a buddy for my car, only problem is it doesnt turn on to be honest. every time i hit display it shows the display for like 5 seconds then seems to...
Please check if the connector of the faceplate and head unit don't have dirty or bended pins, these can produce false contacts between them and can produce fails as the one you have, if this is OK, maybe you have a bad faceplate or head unit.
Mar 18, 2011 | Car Audio & Video
How do you set the clock on a jvc kd-g230 car radio
There is a misprint on manual concerning setting the clock. This is the case for similar JVC mobile head units.
The proper way to set the clock for this unit is:
1.)Hold down 'SEL' button count to 3 seconds
2.)Immediately after release of 'SEL' button hit the '>>|' button
This will allow you to enter 'PSM' menu. Every time you press '>>|' it will cycle between, 'CLOCK HOUR','CLOCK MINUTE', and 'Demo' Mode.
3.)Adjust settings by using the 'turn knob' and make sure 'Demo' mode is set to 'Demo Off' for the clock to stay set.
Nov 17, 2009 | JVC KD-G230 CD Player
Jvc kds641 changing time display
Here ya go,
1.
Press and hold SEL (select) for more
than 2 seconds.
“CLOCK H,” “CLOCK M,” “SCM LINK,” or
“LEVEL” appears on the display.
2.
Set the hour.
1 Using the << / >> button, select “CLOCK H” (hour) or "CLOCK M"
Use the + / - button to adjust the hour/minute
3.
Press SEL to finish.
4.
To check the current clock time or change the
display mode
Press DISP (display)
repeatedly
During tuner operation it will show the frequency or time.
During CD playback it will show elapsed time or time.
Follow this link to download the manual for your unit in .PDF form.
Mar 30, 2009 | JVC AM FM CD DET FACE CAR STEREO
Put the clock
1.
than 2 seconds.
2.
Set the hour.
3.
4.
display mode
repeatedly
Changing the time pioneer DEN2000MP
The solution that worked for me is:
1) turn off the radio.
2) Push and hold the power button down (the dial). DON'T release the button.
3) The unit will display the time on the lcd screen with the numbers flashing, (only hr or min).
4) use the up/dwn, right/left buttons to set the clock.
5) turn off the unit by pushing the power button (again, the dial).
That is it. the clock should be set.
Hope that helps,
Nov 11, 2008 | Pioneer DEH-2000 CD Changer
Don't know how to set the time/clock.
Setting the Clock
Before operating the unit any further, first set the clock built
in this unit.
• When the unit is turned on with CD or tuner selected, press
DISPLAY first to show the clock indication.
1 Press and hold PROGRAM/SET
for more than 2 seconds.
The hour digits start flashing on the
display.
2 Press 4 or ¢ to adjust
the hour, then press
PROGRAM/SET.
The minute digits start flashing on the
display.
3 Press 4 or ¢ to adjust
the minute, then press
PROGRAM/SET.
If there is a power failure
The clock loses the setting and is reset to “AM 12:00.” You need to
set the clock again. If the batteries are inserted in the unit, this has
no effect on the memory.
To show the clock when CD or tuner is selected
Press DISPLAY.
• Each time you press the button, the display changes the clock
indication and the normal indication alternately. (Operating the
unit while clock indication is displayed change the display to the
normal indication.)
Feb 04, 2008 | JVC 10 Watt CD Boombox with AM/FM, Dual...
I c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Apr 30, 2007 | JVC KD-G120 CD Player
Trouble playing JVC KD-S580
i have the same problem in a 2001 mercury cougar. i got power all the way to the back of the radio from the ignition (red) and constant (yellow) wires and the ground wire is good. Think the head unit might be screwed the fuses are all fine. not sure though
Nov 11, 2006 | JVC KD-S580 CD Player
JVC KD-LHX500 has power, but won't turn on!
try taking it all out and put it back in... That happened to me after I jump started my truck I took it out and just put it back in and it works fine now... just a thought
Sep 29, 2006 | JVC Sirius KD-LHX500 CD Player
Car Audio & Video Logo
49 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
