Question about Goldstar MV-1501 Microwave Oven
Goldstar MV 1501BQ microwave
Lights,display,fan all work but turntable doesnt turn and wont heat. Had been having intermittent problems with turntable. Thanks
  • gelehu Jun 22, 2008
    Got an email saying there was a solution to my problem posted, but the solution link just takes me to an ad. Whats the deal?
Thanks for the reply but my old microwave is resting peacefully in the dumpster. I think the ultimate problem was that Gold Star or LG, as its called now is junk.
Posted on Jun 29, 2008
  • Goldstar Master
  • 9,047 Answers
It's probably a bad door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Microwaves
One of the door switches is bad, or the alignment is out, I recommend it be assessed for a more serious problem.
Jul 18, 2012 | Goldstar MV-1526 Microwave Oven
Microwave will not heat
If the microwave is 7 years old or less, there are too things that come to mind, defective magnetron, or the inverter board, cost should be considered when going ahead with repairs.
Jun 27, 2012 | Goldstar MV-1526 Microwave Oven
Goldstar MV1502B was working then just quit power to it turn it on and fan goes on but will not spin turntable or cook. i did change the fuse
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
';l';l
Mar 04, 2011 | Goldstar MV-1526 Microwave Oven
Have power, turntable rotates, lights on, timer works, will not heat
Basic
heatman101
Feb 19, 2011 | Goldstar MV-1615 Microwave Oven
Completely stopped working
sounds like you blew the fuse inside
Jun 19, 2009 | Goldstar MV-1526 Microwave Oven
Lights, fan,etc work but turntable does not rotate and oven does not cook.
Sounds like the table motor may have an issue. You might want to consult you local repair depot for an estimate. Sometimes the repairs are more than the appliance...beware!
May 25, 2009 | Goldstar MV-1501 Microwave Oven
Microwave does not head
Ok i had the same problem i took out the switch's and replaced the top one and it took care of the problem. switch part number is vp533aof i hope this helps you
Dec 11, 2008 | Goldstar MV-1526 Microwave Oven
Over the range Goldstar microwave not working????
(If you need more help than this, please reply back with your model number)
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Oct 02, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1501 1000 Watts... Problem:
if micro. new then its defective
if micro. old then you need replacement or service the heating element and turn table motor
Jun 02, 2008 | Goldstar MV-1501 Microwave Oven
Goldstar Microwave
Could be the relay, an internal fuse. With the power off, open up the key panel and search for a fuse. Also, there are thermo sensors black, diameter of a dime and 3/8 inch thick with two wires. Check the fuse and replace if necessary. The thermo can be jumped out to test. Remove the wires, use a paper clip between them and tape it up. Briefly turn the unit on. Replace if it works now. The thermo is generally clamped to the wall of the oven behind the key panel. Never run without the thermo sensor.
Dec 18, 2007 | Goldstar MV-1501 Microwave Oven
Goldstar MV-1501 Microwave Oven Logo
141 people viewed this question
Top Goldstar Microwave Ovens Experts
William Miller
William Miller
SHARCNET-USA
SHARCNET-USA
Mike
Are you a Goldstar Microwave Oven Expert? Answer questions, earn points and help others
