Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Whirlpool GD5SHAXKB00 side by side icemaker problem
Teflon coating in icemaker is peelin off?
  • 481 Answers
You have to replace the icemaker
Posted on Jun 28, 2008
The ice from my ice maker has small particles in it that look like flecks of paint or metal. I have stainless bottom freezer Kenmore with ice/water in door.
To assist ice from popping out of the frozen mold of the icemaker it is coated with nonstick teflon,just like the teflon on your cookware.That teflon is flaking off of the icemaker mold and the icemaker must be replaced.All you need to do to replace it unscrew it from the side freezer wall,unplug it and instatll new one. The part number is 4317943 you could purchase it at your local appliance parts store on online at;
searspartsdirect.com
repairclinic.com
apdepot.com
assuredparts.com
appliancepartspros.com
Gene
Aug 05, 2011 | Kenmore 73503 Stainless Steel Bottom...
ICE CUBE MAKER LEAKING WATER AT INPUT TO TRAY
I just fixed the same problem on a Maytag icemaker.... the aluminum ice tray had corroded (in 5 years!) so bad it had cracked the teflon coating. I took the icemaker out ( 3 screws, 1 electrical connector) and the thing would leak water sitting on the counter.
Jul 06, 2010 | Jenn-Air JCD2389G Side by Side...
Ice has things floating in it. filer has been
If itis brownish black color substance, its the teflon coating from the mold of the icemaker
Sep 23, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Teflon coating coming off trays and now complete failure
On some ice makers you can replace the parts and on others you have to replace the entire ice maker. Post your model number on this site and you can look at your ice maker diagram and parts avalable. Post back here and I will help if you need me to. http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=GTS18DCPWUWW&pop=flush
Sep 02, 2009 | Kenmore 53642 / 53644 Side by Side...
The ice from the ice maker tastes terrible, the water from the despenser is fine just the ice is a problem
remove icemaker and check that you have no eroding of teflon coating. you may install a quaity charcoal filter.
Jul 25, 2009 | Amana Refrigerators
Teflon coating bubbling in spots
Sadly there's not much you can do here then. If it has started to bubble it only takes one swipe from a utensil to break it open and I had to get rid of my 12 year old tefal pot because of a very similar problem.
Teflon sprays exist on the market to spray light coatings on mechanics. However it is not fit for utensils or anything that may be consumed out of. You should just invest in a new set.
Please rate thanks.
Jul 24, 2009 | Kitchen Appliances - Others
I have a whirlpool refg. with built-in ice maker model# ED25DQXDW02. Everytime the frig. goes to fill the tray it fills it then over flows some. Is this a problem I can fix myself.
probably have to replace the icemaker take it out and look at the mold and see if you have some teflon coating that has come of and or some water deposit buildup under im on heater on bottom of icemaker. this causes it to let the water drip down on the back of im an causes iceblock in the dispenser bucker. you can order an icemaker 1- 877-262-1479
May 27, 2009 | Freezers
Water drips from underneath icemaker and freezes in bucket
If you find the offending part of the ice maker, I've had good luck with these guys when ordering spare parts. Here is a link for your model:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5133512
Jan 01, 2009 | Whirlpool ED2FHEXN Side by Side...
Need to change the ice dispenser motor. How do I get to it?
if alllyou have ot change is the dispensor motor, not aproblem at all, the acess to teh motor cavity is located under 2 screws above the lower freezer door shelf, remove the 2 scres and youll find four more screwsholding in the motor , take all of 5 min, no chance of wrecking anything else, its the only thong on the compartment
Nov 09, 2008 | Whirlpool ED2FHEXN Side by Side...
Whirlpool refrigerator model # ED22PE
The ice coating usually means that your door was left slightly open. Did the ice maker work after you cleaned up the ice?
Dec 26, 2007 | Whirlpool 21.7 cu. ft. Side-by-Side...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
166 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
