Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
Buck Bourgeois Posted on Nov 23, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Where can I purchase a thermocouple for a Rheem 50 gallon hot water heater? The pilot light will not stay lit, so this is the most likely thing to change, right?
Anonymous
Level 3:
Genius:
  • Master 1,015 Answers
  • Posted on Nov 23, 2010
Anonymous
Master
Level 3:
Genius:
Answers
1015
Questions
0
Helped
319579
Points
3041
I think you can use any standard thermocouple of the right length. These are available at most hardware stores.Thanks
I have a Rheem m441506191 50 gallon water heater. It had a Honeywell wv8840c1406 gas control with a thermopile (not a thermocouple). The pilot wouldn't stay lit, it turned out the thermopile was giving 140...
The system I am familiar with uses a vapour pressure type thermocouple and if the pilot remains lit the thermocouple is working as it controls the gas for the pilot and the burner at the same time from the same source - if the gas control is ok and the flow isn't prevented by the thermostat then if the pilot remains alight, there should be a flow of gas and the burner should light - unless the gas jet is blocked or something else, some other type of blockage is preventing the flow of gas to the burner...
I suggest you check the gas jet and the flow of gas to it...
Richmond 3360 gas water heater pilot won't stay on
Open following links for pilot and troubleshooting resources:
Problem could be bad thermocouple, thermocouple not sitting in pilot flame, pilot orifice needs to be cleaned, water heater needs more air, dirty air intake, hot attic environment, backdraft blowing out pilot, or bad gas control valve.
If you get flame, then ECO is not tripped.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/How-to-test-water-heater-thermocouple.html
http://waterheatertimer.org/pdf/How-to-replace-thermocouple.pdf
Rheem 22V50F1 pilot won't stay lit. Changed thermo couple & it lit, ran then went out. Let it sit overnight & it lit, ran then went out. What next? p.s. The unit is 5 years old. Thanks
If pilot lights and flame is robust and clear blue, and pilot goes out later, then some suspects can be excluded: air in gas line, low gas pressure, thermocouple is overtightened (finger-tight + 1/4 turn), thermocouple not positioned correctly in the flame, dirty pilot tube.
If flame is yellowish and small: then clean pilot tube and combustion parts.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Remaining suspects can include: air in gas line, low gas pressure, bad gas control valve, tight house so household vent fans pull air down water heater vent that blows out pilot, hot attic with inadequate ventilation, water dripping down vent.
Open following links to read troubleshoot resources.
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
Cannot get the pilot light to stay lit. Replaced the thermocouple and the problem still exists
Burner parts need yearly cleaning, air intake needs periodic cleaning, burner parts cannot be exposed to trace amounts of chemical without damaging parts, no water should be dripping down from vent, vent should be checked for updraft, ample combustion air is required especially in closed basements, tight houses, and hot attic, bleed gas line to remove air, check that gas control thermostat is functioning.
Open following links for pilot light help:
I have a 50 gallon rheem direct vent natural gas heater. The pilot light goes out on an infrequent but aggravating basis. I replaced the thermocouple one time and it got better for about a year but has...
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Since pilot light goes out and can be re-lit, problem is probably not thermocouple, gas control valve, or air in gas line. But these things can factor in as contributing factors.
Problem is likely one of following or combination of following including dirty burner parts, tight house, incorrect vent lengths, negative pressure caused by other venting appliances, condensation dripping down into combustion area, and inadequate oxygen supply due to hot or closed-off room or attic location.
Gas water heaters draw air from surrounding area. If water heater is located inside house, then air has to enter home through cracks and when doors and windows are opened. Other gas appliances and vent fans also draw air from same indoor area. When other vent fans turn on, air can be drawn down the water heater vent and blow out pilot light.
Inspect combustion chamber to make sure there is no condensate water dripping down from incorrect vent that is putting out flame. If combustion chamber is dry, then close doors and windows. Turn on all vent fans and gas appliances that vent outdoors, and see if water heater pilot goes out.
Consult with plumber or product manual about proper horizontal and vertical lengths of vent pipe for your model. Have plumber clean combustion parts and inspect vent termination and check gas pressure and bleed gas line.
Add louver opening to outdoors so air can enter room where water heater is located.
2helpful
3answers
I have a Rheem PG50T9A gas hot water heater. We had hot water this morning. When I came home the pilot light was out and won't stay lit. Any ideas?
Hopefully just the thermocouple. The thermocouple is the small rod right next to the pilot light. The flame on the pilot heats up the thermocouple and keeps the gas valve on. You can replace it yourself. The thermocouple will be connect by a small nut on the underneath side of the valve, and you will have to pull the thermocouple out of the pilot assembly. Not an expensive part, you can get it at any hardware store. Hope this helps you .
3helpful
I have a Rheem 50 gal. natural gas water heater mod#21V50-6A followed all instruction and can't get pilot light to stay lit.
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Top Rheem Water Heaters Experts
Mike Cairns
Mike Cairns
Sean Wright
Sean Wright
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
