Can not connect to the internet when the ethernet cable from my modem is plugged into the Linksys wireless router .Only when I plug the cable directly into the laptop can I conect to the internet. This just happened today - have been uing the Linksys for the past six months.
  • 667 Answers
Hi toniann - Could you tell me please the model# abd version of your Linksys router? It should be on a label on the router. Thanks.
Jeff
Posted on Jun 22, 2008
Can not connect wireless to internet
verify that the cable are conned correctly. now the ethernet cable that come from the cable modem do not need to be plugin to the port that is label Internet, it need to be plug in any port 1 to 4. then access you router via a ethernet cable and setup the router of wireless access.
Jan 13, 2012 | Linksys Wireless-G Broadband Router
I have used the Linksys CD to setup my wireless connection to e1000 wireless router; in diagnostics, I discover that I am connected to the router but not to the internet. I also try setting up ethernet to...
Make sure the Modem is plugged into the correct port on the E1000 (far left port labelled 'internet' on a yellow background). Unplug all the devices power cables and restart them in order from the wall (modem - router - PC/MAC) make sure the modem has link and activity lights flashing, if there is a light for 'internet' wait for it to be on before plugging in the router. You might want to call your ISP and confirm theres nothing funky with the line/modem.
Aug 22, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I am trying to connect a wrt150n wireless linksys router to my dsl. I am using a desktop windows 7 and laptop windows vista. Please help, I have tried everything but it just does not want to work.
unplug everything, including ethernet cables. then work in this exact order.
if you get a wireless signal and no internet, plug a computer in into the router in one of the available ports and check for internet. If no internet, unplug everything and test the modem without the router. If internet available without the router, then follow these instructions
  1. plug phone line into modem
  2. plug power into modem
  3. wait for all lights to become steady
  4. plug ethernet cable into modem
  5. plug other end of same cable into port labled "internet"
  6. wait for lights to become constant on both router and modem
  7. check your wireless device for wireless service.
if you dont get a wireless signal at all, plug your device into the rear of the router and type 192.168.1.1 in the adress bar
the password and username are both "admin" or simply leave the password blank if that doesn't work
navigate to the wireless option and turn on the wireless transmiter.
GOOD LUCK AND PLS RATE THIS POST!!!!!!
Dec 01, 2010 | Linksys Wireless-N WRT150N Router
HOW TO USE INTERNET IN MORE THAN ONE PC FROM LINKSYS WIRELESS G B
You have two ways on how you can get other computer online through this router. First, you can wired them (using an Ethernet cable) to one of the Ethernet ports on the back of the router. They are the ones labeled 1, 2, 3, and 4.
Second is through wireless, but those computers that will connect through wireless must also have a wireless adapter to be able to pick up the signal that this router is broadcasting.
Feb 12, 2010 | Linksys Wireless-G WRT54G Router
I have an internet connection through my desktop that is plugged into a cable modem but when I run the Linksys Easy setup software it says it can't find a internet connection. I have turned off my Norton...
Make sure connections are correct. Cable modem to router with Ethernet cable. then connect router to computer with another Ethernet cable and see if it works.
o this:
1. hut down computer, modem and router.
2. put them on in this order waiting 1 minute between each.
---cable modem
---router
---computer
you also have to check that the router is set up as dhcp
Dec 26, 2009 | Linksys WRT150N Wireless N Router -...
Motorola SB5100 and linksys router connection
The only thing that you need to setup on your Linksys for it to work with cable is to make sure that DHCP is enabled on the router.  You will need to plug your router into the modem via the ethernet cable and then plug your neighbors pc into a link port on the router (the cable modem plugs into the internet port)  You will also need to follow the reboot procedure.  Power everything off.
1: Turn on the surfboard and wait about 1 minute for the surfboard to make a connection with your ISP (the link light should come on).
2:Turn on your router and wait for your router to sync up with the surfboard . 3: Turn on your computer. Whenever you plug anything into a cable modem, you must recycle power to the modem.  It "remembers" the last device that was plugged into it, so it's memory needs to be cleared.
Apr 24, 2009 | Arris SURFboard SBG900 Wireless Router...
Why does this keep happening??? Please advise...
Your modem is set to only allow one main IP address, which it assigned to your laptop.
Connect the cables through the router, then unplug first the modem, then the router.
Wait 45 seconds, then plug in router, wait 5 seconds, then plug in modem.
Give it a few seconds to talk to everything, and you should be good to go.
Dec 04, 2008 | Linksys Wireless-G WRT54G Router
Need to add Linksys WRT54G-TM wireless router with Linksys SPA 2102 phone adapter
your SPA2102-R seems to have one ethernet connection and one internet connection.
your WRT54G-TM seems to have one internet connection and 4 ethernet connections.
What you are trying to achive is; plug a ethernet cable into the ethernet connection on your SPA2102-R then plug the other end into the internet port of the WRT54G-TM
hope this helps, I have assumed that you intend to use a DSL broadband supplier not ADSL.
if you are changing service from DSL to ADSL then your WRT54G-TM needs to be first in line configured and working. then plug the internet port from the SPA2102-R into any of the WRT54G-TM ethernet ports.
Nov 06, 2008 | Linksys Wireless-G WRT54G Router
Connecting to internet
Ok, cable (coax) comes in from wall and attaches to modem. Ethernet cable goes from modem to WAN Port of router. You may have to reboot both devices to ensure that your modem (internet service provider) assigns IP address to your router. If PC is close enough, attach new ethernet cable from one of the 4 ports on your router down to your PC's ethernet adapter. (where your modem used to plug into). Router will now assign an IP address to your PC and you should be able to access the www.
Good Luck and let me know if you have any more questions.
Jul 13, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
96 people viewed this question
David Payne
David Payne
